Originally Posted by valy_leo
Salutari tuturor! Cine ma ajuta si pe mine cu niste informatii....stie careva vreun service in bucuresti care are tester ptr rover 75? In afara de Bavaria desigur.Am o problema cu aerul.Am freon(l-am schimabat si freonul si uleiul aferent) , se aude cum cupleaza compresorul dar in habitaclu tot aer cald (la temperatura celui din exterior) baga. Releul si siguranta sunt bune...Ce oare sa fie,...ma dispera fara clima...e sinucidere curata... In plus sunt si in criza financiara si nu am nici un chef sa ma duc la bavaria si sa ma coste o avere...S-a confruntat cineva cu un astfel de incident?? Daca stie cineva vreo informatie care ma poate ajuta il rog sa mi-o comunice,inclusiv vreun electrician sau service priceput cu tester de rover 75.Mersi mult anticipat!
SAL,
Pentru aer nu ai nevoie in prima faza de tester.
Exista o procedura de auto test al ATC - unitateaa de aer . clima
Mai jos ai cum se face:
1.Press and hold the AUTO and Air distribution buttons and keep them depressed
2. Whilst depressing the above buttons switch the IGN key from position 0 to position II
3. Release buttons when diagnostics have started (indicated by an audible tone and flashing
of the display icons)
4. Once diagnostics have completed the ATC unit will display "FC" in the LH window and the
corresponding fault code in the RH window. If multiple faults are present the ATC display will
cycle through these faults at a rate of 1 per second. Please refer to the table of codes shown
5. To cancel diagnostics press the off button or switch the IGN key back to position 0
Note: Remember the unit will indicate a sunlight sensor fault in low light conditions. (21+22)
00 No Fault
11 in car temp sensor fault
12 K Bus error
13 evap sensor fault
14 heater coolant temp sensor fault
21 sun sensor (left) fault
22 sun sensor (right) fault
31 lh temp servo motor fault
32 rh temp servo motor fault
33 distribuition serv motor fault
Daca da eroare 21 sau 22 inseamna ca nu este destula lumina pe parbriz...deci nu este o problema...
eu am facut testul la a mea rov 75...cdti si la fel nu baga deloc rece
...a facut testul...culmea nu a zis ca nu are freon....si nu avea...am bagat si merge super ok....
nu am la indemana toate codurile de eroare care pot aparea...dar mai pe seara le pun pe toate
...am sa vorbesc cu cei care sau ocupat de a mea cu aerul...daca vrei...sunt in zona Brancoveanu....
dupa ce pornesti aerul cam la 3 ~ 4 min porneste iti porneste ventilatorul mare de la radiator ?
...tine-ma la curent si sper sa o rezolvam rapid....
Stima,
M
ps. cu testerul pentru rover intradevar este o problema
nu stiu sa existe inafara de bavaria......
se poate folosi cu succes de 98 % cel pentru bmw...dar atentie sunt cateva coduri pe care le citeste gresit....
din pacate nu stiu care sunt alea.....
