Old 03-08-11, 21:41   #3466
toby75
toby75's Avatar
Originally Posted by marfafranta View Post
buna seara.v-am adresat si eu urmatoarea intrebare :am si eu o noua intrebare.am vazut ca se poate face un test pt clima tinand apasat pe auto + butonul care regleaza unde sa directioneze aerul.am facut acest lucru azi dimineata si mi-a aratat fc 0.apoi dupa amiaza am mai facut odata si fi-a aratat fc 21 si fc 22.stie cineva ce semnifica aceste coduri ? 2. DEASEMENEA VREAU SA STIU CAND SE FACE ACEST TEST LA CLIMA ,CE ANUME TESTEAZA ?MULTUMESC.SCUZE PT INSISTENTE DAR AM UN 75 DE DOAR 2 ZILE.CDT DIN 2002.MULTUMESC ANTICIPAT
este ceva problema cand apar acele coduri fc 21 si 22 ? dar fc 00 ?
doresc daca se poate sa-mi raspundeti si la intrebarea nr 2 .va multumesc anticipat
11 senzor temp interior
12 senz temp externes
13 senz temp evaporator
14 senz temp apa
21 senz solar stg
22 senz solar dr
31 motoras flapsuri stg
32motoras flapsuri dr
33 motor distribuitor aer
eroare 21 si 22 ai facut testul pe intuneric sau in garaj
00 totul e ok.
toby75 is offline   Reply With Quote
Old 03-08-11, 22:17   #3467
marfafranta
SALUT.AM INTALNIT O PROBLEMA FOARTE MARE AZI.VA ROG ,DACA V-ATI INTALNIT CU ACEASTA PROBLEMA SA-MI COMUNICATI SI MIE REZOLVAREA.PROBLEMA ESTE URMATOAREA IMINEATA M-AM URCAT IN MASINA ,AM INCERCAT SA PORNESC ,DAR NU PORNEA.SE AUZEA EXACT CA ATUNCI CAND NU AI MOTORINA (REZERVORUL ERA JUMATATE).AM MAI INCERCAT DE CATEVA ORI SA PORNESC SI FACEA LA FEL.PANA LA URMA A PORNIT SI IN 3 SECUNDE S-A OPRIT SINGURA.AM REPORNIT,A PORNIT ,DAR IAR S-A OPRIT.A TREIA OARA A PORNIT SI A RAMAS ASA.AM PLECAT CU EA SI AM MERS APROX 30 MINUTE .IN MERS NICI-O PROBLEMA.DUPA CE AM OPRIT SI AM STAT IN JUR DE 30 MINUTE CU EA ORITA ,LA PORNIRE S-A REPETAT CE AM SPUS MAI SUS.AM FOST CU EA LA UN SERVICE SI MI-AU PUS TESTERUL PE EA.AU SPUS CA NU SE FACE SUFICIENTA PRESIUNE LA SENZORUL DE LA POMPA DE MOTORINA.L-AU DESFACUT ,AVEA CATEVA GUNOAIE PE SITA ACEEA MINUSCULA ,L-AU REMONTAT.AU PORNIT SI TOTUL ERA OK.AM PLECAT ,AM AJUNS ACASA SI DUPA CATEVA MINUTE CU EA OPRITA,GAND AM INCERCAT SA PORNESC ,LA FEL CA SI INAINTE.
VA ROG FRUMOS SA-MI COMUNICATI SI MIE DACA V-ATI INTALNIT CU ACEASTA PROBLEMA SI CUM A-TI REZOLVAT-O.MENTIONEZ CA LA BORD NU ESTE APRINS NIMIC.VA MULTUMESC
marfafranta is offline   Reply With Quote
Old 04-08-11, 13:18   #3468
i like mg
i like mg's Avatar
Originally Posted by player1 View Post
setarile se activeaza/dezactiveaza cu testerul T4
adica se poate seta asa ceva (blocarea usilor la plecare) ?
i like mg is offline   Reply With Quote
Old 04-08-11, 13:59   #3469
marfafranta
da.eu am avut un rover 75 din 2000 .la plecare ,toate usile se blocau automat cand masina atingea 5km/h.
Old 04-08-11, 14:25   #3470
player1
player1's Avatar
garantat
player1 is offline   Reply With Quote
Old 04-08-11, 20:28   #3471
marfafranta
Old 04-08-11, 20:32   #3472
marfafranta
am fost cu masina astazi la service.am descoperit pana la urma ca problema nu este de la senzorul de la pompa.pompa trage aer fals.toata ziua au cautat si nu au gasit de unde trage acel aer fals.stie cineva sa ma ajute si pe mine cu aceasta problema ? masina am lasat-o la service ca maine s-o luam de la capat.
Old 04-08-11, 22:00   #3473
toby75
toby75's Avatar
Dar cum si-au dat seama ca trage aer fals pentru ca pompa e in rezervor ! Or fi bule de aer in rezervor !!!
Old 04-08-11, 22:28   #3474
marfafranta
daca te pricepi ,nu vrei te rog sa-mi lasi o adresa de mes ca sa discutam mai concret ? se manifesta astfel : in fata sub capota ,in partea stanga se gaseste cred ca pompa ii zice ,o piesa cilindrica ,care trage motorina.din cate spuneau ei ,trage motorina pe doua furtune.unul din furtune impinge motorina in filtru.au scos turul si l-au bagat intr-o sticla.in momentul in care puneam contactul ,motorina nu venea continuu ci intrerump,mai mult spuma.cu foarte multe bule de aer.apoi au tinut strans unul din furtunele pe care tragea motorina si jetul a revenit la normal.astfel ei au zis ca trage aer fals.cunosti fenomenul ?
Old 04-08-11, 22:37   #3475
Mihai Apricopoae
Mihai Apricopoae's Avatar
Buna,
Aceeasi problema am avut-o si eu (tragea aer fals) si a fost de la pompa de motorina, cea care face legatura cu filtrul de motorina, avea o fisura...
Sper sa fie de folos.
Mihai Apricopoae is offline   Reply With Quote
Old 04-08-11, 22:39   #3476
marfafranta
Originally Posted by Mihai Apricopoae View Post
Buna,
si a trebuit sa schimbati pompa ? daca da ,cat a costat?multumesc
Old 05-08-11, 07:55   #3477
luttecodrut
DEZMEMBREZ ROVER 75 2000CDT Vind piese auto din dezmembrari pentru rover 75 cdt motor de 2000 diesel calculator motor , airbag portiera , motor , cutie de viteza , alternator , compresor de clima , injector tdi , pompa de injectie , calculator , capota , pavilion , prag , lonjeron , punte fata si spate , tragar , radiatoar , scaun , abs , airbag , planetara , jenti , telescop , ventilator , geamuri laterale , chiuloasa , vibrochen , piston , volanta , electromotor , scaune , bancheta , egr , compresor de clima , scaune , bancheta , egr , vibrochen , piston , volanta , electromotor , scaune , bancheta , egr , debitmetru , compresor de clima , alternator calculator , punte fata , spate , pompa tandem , pompa servo , caseta directie , butuc , , spate , tragar , jamta , , chiuloasa , vibrochen , piston , volanta , electromotor , scaune , bancheta , egr , debitmetru , compresor de clima , alternator piese motor . turbina , PLANETARA CHIULASA -INJECTOR -TURBINA -GRUP SPATE -CAPOTA SPATE -BARA SPATE MOTOARE -MACARA DE GEAM ALTERNATOR -ELECTROMOTOR -PIESEL AU GARANTIE SI SE POT LIVRA IN TARA PIESELE AU GARANTIE !! . etc
0720758664 sau email lutte_codrut_champion@ yahoo.com
luttecodrut is offline   Reply With Quote
Old 05-08-11, 21:26   #3478
wiily
mar interesa bordul comp da sa fie compatabil pentru navigation si la ce pret
wiily is offline   Reply With Quote
Old 05-08-11, 21:48   #3479
toby75
toby75's Avatar
Da aia e pompa secundara mai e una in rezervor. Cind pui contactul asculta in spate sub bancheta ar trebui sa o auzi daca nu i seamna ca e defecta si trage numai aiaa secundaraa ea nuaare putere atitaade mare. Vezi incearca! Adr de mess tobytoby63@yahoo.es
Old 05-08-11, 21:56   #3480
toby75
toby75's Avatar
Principiul e urmatorul pompa principala din rezervor pompeaza motorina pina la FBH si pina la pompa secundara, care la rindul ei o trimite la pompa de injectie. Demonteaza furtunul dinainte de pompa se undara si vezi dacaavine motorina.
