Old 12-12-12, 00:24   #316
Ursan2.5
Ursan2.5's Avatar
Default Re: E30 - CJ 89 LOW
Originally Posted by motzu View Post
ooooooooooooooooooooooooooooooooo dar ce avem noi aici??????
pt aspectul asta mi s-au lungit degetele de 3 saptamani incoace))
Ursan2.5 is offline   Reply With Quote
Old 12-12-12, 00:35   #317
motzu
motzu's Avatar
[CSR]
te cred.........darrrrrrrrrrrrrrrrr..............a meritat!
motzu is offline   Reply With Quote
Old 01-01-13, 19:33   #318
tabokubmw
tabokubmw's Avatar
Piesa au iesit rotile!
tabokubmw is offline   Reply With Quote
Old 08-01-13, 15:26   #319
tabokubmw
tabokubmw's Avatar
Edit:Am urcat si o poza
Old 08-01-13, 22:46   #320
ar88kos
ar88kos's Avatar
faina,faina.....spatele ala...
ar88kos is offline   Reply With Quote
Old 09-01-13, 00:43   #321
tabokubmw
tabokubmw's Avatar
Ochiu.....
ID:	2654857   Click image for larger version
ID:	2654858   Click image for larger version
Old 09-01-13, 02:47   #322
alexxpassat2003
alexxpassat2003's Avatar
omg is perfect
alexxpassat2003 is offline   Reply With Quote
Old 09-01-13, 05:17   #323
Ursan2.5
Ursan2.5's Avatar
Originally Posted by alexxpassat2003 View Post
omg is perfect
Ehhhh, departe de asta. Ms oricum!
mai sunt multe de facut pana in vara, mi-am conceput eu 2 praguri foarte simple, se vor schimba unele elemente de caroserie care nu sunt OEM si nu dau la linie cum ar trebuii, am cumparat ceva stickere pt luneta,trebuie terminata buza de VR care a fost modificata si multe altele...
urmeaza sper un vopsit integral si din nou un 24v de la 2.5 in sus...
Inoculat cu virusul ///M
Old 09-01-13, 14:56   #324
motzu
motzu's Avatar
[CSR]
foarte bine da combinatia de vopsea masina jante
sa vina calduraaaaaaaaaaaaaa....................
Old 09-01-13, 15:35   #325
Roly94
Roly94's Avatar
Ce bengos arata,imediat fac pe mine de fericire,jur!!!!
Roly94 is offline   Reply With Quote
Old 15-01-13, 20:10   #326
///sby
///sby's Avatar
ai stagnat loW?
///sby is offline   Reply With Quote
Old 15-01-13, 23:07   #327
Ursan2.5
Ursan2.5's Avatar
Originally Posted by ///sby View Post
ai stagnat loW?
nu, cu ursu ma misc incet dar sigur!
mai lucrez si la 2 motociclete "custom" in paralel cu ursu
Old 03-03-13, 10:30   #328
topolino009
Default Re: E30 CJ 89 LOW
nu sunt chiar nou, urmaresc partea asta a forumului non stop, am detinut si un ursache cabrio, dar se poate spune ca sunt nou fiindca m-am hotarat sa-i fac si eu un topic intre voi k asa se cade bine
multumesc mult!!! iti doresc la fel si tie si tuturor de pe aici!!!
salut. am nevoie de ajutorul tau. te rog adaugama pe mess topolino009 astept sa vb cu tine
topolino009 is offline   Reply With Quote
Old 16-03-13, 00:33   #329
Ursan2.5
Ursan2.5's Avatar
Salut tuturor!
Incet, incet vine primavara si cu ocazia asta mai punem mana si pe ursache.
dupa ce am tot stat pe ganduri pt a alege un motor, M50/M52/M54 am achizitionat weekendul trecut un M54B30 de pe E46 CI automat.
am luat odata cu el, instalatia completa a motorului, EWS, cheie contact+ cititor, ECU,galerii de evacuare pana la mijlocul masinii continand toate 4sondele lambda si pedala de accelaratie electrica+fire( care a din pacate am inteles k nu o voi putea folosii.
instalatia cutiei automate+calculator a ramas toata pe masina donatoare.
va urma multa bataie de cap si multe intrebari daca este cineva dispus sa ma sfatuiasca( chiar si contracost)
daca nu voi putea folosii acceleratia electrica, de pe ce motor cumpar clapeta de acceleratie mecanica?
evacuarile vor ramane astea complete cu cele 4 sonde?(am acasa si 2 galerii de 2.8 ramase de pe fostul motor,M50)
am urmarit ceva swapuri la nemti si am vazut montand pe un E30 cabrio motorul M54b30 cu galeriile de evacuare originale pana la prima imbinare pastrand toate 4 sonde lambda, nu credeam sa incapa de H...etc fara modificari
cutie de viteze, care ar fi cea mai recomandata pentru rapoarte?
ce ambreiaj(volanta,disc placa de presiune) este recomandat pentu motorul asta?
mecanic o sa fac eu cam tot, fiindca nu observ mari diferente fata de M50.
suporti M50 E36,baie de ulei M50 E34, sorbul ramane asta si se modifica,tampoane e34, cardanul l-am pastrat de la vechiul m50b25,timoneria la fel...etc
La partea electrica din cate am inteles va fi distractie maxima, eu nu ma descurc deloc deci la momentul respectiv voi apela la cineva priceput contracost.
pana una alta vreau sa fiu sigur k am tot ce trebuie si ce nu am sa cumpar intre timp.
Multumesc si imi iau angajamentul sa fiu foarte recunosctaor celor care ma ajuta sa deslusesc misterele...
Old 16-03-13, 00:52   #330
tabokubmw
tabokubmw's Avatar
Salut tuturor!
Bine Nicule! Abia astept sa il vedem pe LOW cu noua inima.
