Old 03-04-11, 18:49   #91
GTA
GTA's Avatar
Default Re: Maşina mea: Opel Calibra C20LET FWD (proiect)
Radiatorul de ulei unde este?
GTA is offline   Reply With Quote
Old 03-04-11, 19:00   #92
Andu_focus
Andu_focus's Avatar
in portbagaj.....treb sa il montez si pe ala....(multumesc pe aceasta cale lui Dropy)
Andu_focus is offline   Reply With Quote
Old 07-04-11, 23:36   #93
Andu_focus
Andu_focus's Avatar
achizitie noua capac delcou Beru cu lulea tot Beru....
Old 08-04-11, 17:27   #94
electric_style
electric_style's Avatar
[Oltcit]
cat a costat delcou cu lulea cu tot ?
electric_style is offline   Reply With Quote
Old 09-04-11, 02:11   #95
Andu_focus
Andu_focus's Avatar
poze cu finalizarea taseului....sap viitoare va urma reconstruirea capacului de admisie din aluminiu si pe 63mm.....
ID:	1956217   Click image for larger version
ID:	1956218   Click image for larger version
ID:	1956220   Click image for larger version
ID:	1956221   Click image for larger version
Old 10-04-11, 14:33   #96
club_opel_vectra
club_opel_vectra's Avatar
salutare baieti si felicitari pentru proiectul vostru.eu am un opel vectra A si am inteles ca se poate pune si pe el turbo?stie cnva sau a auzit ca costuri implica?
Ms
club_opel_vectra is offline   Reply With Quote
Old 10-04-11, 14:41   #97
Radu ERD
AfterDark Racing Member
Radu ERD's Avatar
[AfterDark Racing]
Vad ca la noi toti care mestersesc pe la LET-uri si baga destui bani nu cumpara asa ceva si fac tot felul de improvizatii ...
TXautosport 76mm 3" inch bore tophat inlet pipe
High Flow 76mm 3inch bore
Polished Stainless Steel
Dump Valve pipe allows fitiment of dumpvalves, standard size
Sensor Hole
Idle Control valve pipe inlet
Increase airflow and Throttle response
Costa 60 de lire + transport dar eu zic ca e altceva ...
ID:	1958778   Click image for larger version
ID:	1958779   Click image for larger version
ID:	1958781   Click image for larger version
Cielo C20XE DIS - BUILT not bought
www.toyotires.ro
Radu ERD is offline   Reply With Quote
Old 10-04-11, 15:59   #98
Esperache
Esperache's Avatar
Nu te supara Radule, stii ca ai intentii bune, dar teava asta de la TXAutosport e fix frectzie ! Este mult prea bombata si trebuie tesita deasupra ca se poata inchide capota si, cel mai rau, materialul e de tot rahatul ... pana si chinezii fac un inox mai bun.
Esperache is offline   Reply With Quote
Old 10-04-11, 17:16   #99
Radu ERD
Radu ERD's Avatar
[AfterDark Racing]
Nu ma supar dar cea care i-a venit lui Cosmin era deja tesita sus f putin de ei ca sa se inchida capota. Sunt de acord ca se poate un material mai bun dar e oricum peste improvizatiile de pe forum, iar ca forma vine pe toata suprafata clapetei (si la cea mica si la cea mare) nu cum am mai vazut pe aici facuta o flansa in care vine un cot direct unde e clapeta mare iar la clapeta mica pauza. Are si umflatura aia facuta acolo unde intra furtunu in ea ca sa poti strange colieru si sa nu te trezesti cu surpriza ca dupa 2 rafe nu mai ai boost ...
Old 10-04-11, 17:33   #100
Andu_focus
Andu_focus's Avatar
eu il fac din aluminiu ca sa nu se incalzeasca asa de tare..inoxu se incalzeste mult mia repede si tine temp mai mult timp,oricum toata partea de traseu care duce in admisie va fi imbracata in folie ceramica care este un scut termic destul de bun....sper sa iasa cv rezultate din treaba asta...insa akm am niste probleme,face presiune prea mare turbina (10 PSi ) si imi taie alimentarea pe la 5000 rpm....am mai scazut presiunea si anume la 0,7 bari iar astazi la fel mi-a facut....urmeaza sa o pun pe un tester si sa alimentez pompa de benzina direct pe bateria masinii cu un buton on/off deoarece curentul care ajunge la baterie indica decat 9V....si nu in ultimul rand vreau sa desfac si corpul clapetei de acc si injectoarele cu admisia k sa curat totu si sa etansez toata treaba pe acolo deoarece e cv umezeala pe la clapeta de acc...
stiu k ce am akm e o mare gospodaria....asa am cumparat masina si am mai carpito pe parcurs,dar asa cum am zis anterior o sa refac cat se poate de mult capacu...si o sa il fac din aluminiu tot,cotu ala care iese din flansa de la clapeta o sa fie din tabal de 2 tot Al,am 2 modalitati de al reconstrui pana acum....sper ca la sfarsitul sap sa fie gata....
Old 10-04-11, 18:11   #101
Radu ERD
Radu ERD's Avatar
[AfterDark Racing]
OK, spor la treaba, astept sa vad cum iese.
Old 10-04-11, 23:21   #102
DarKane
DarKane's Avatar
vezi ca am rezolvat de aluminiu.contact me cand esti hotarat
DarKane is offline   Reply With Quote
Old 21-04-11, 10:42   #103
Andu_focus
Andu_focus's Avatar
gata capacu de admisie si izolarea cu banda ceramica a traseului de IC care duce in admisie... +decuparea barii pt o racire mai buna a IC si radiaotorului
ID:	1974508   Click image for larger version
ID:	1974509   Click image for larger version
ID:	1974511   Click image for larger version
ID:	1974512   Click image for larger version
Old 21-04-11, 10:49   #104
Esperache
Esperache's Avatar
Cool Re: Maşina mea: Opel Calibra C20LET FWD (proiect)
Very nice !
Old 21-04-11, 21:43   #105
MIHAI_NEBUNU
MIHAI_NEBUNU's Avatar
treaba asta e turbo?
MIHAI_NEBUNU is offline   Reply With Quote
- Copyright 2025 4Tuning -
