Old 15-04-14, 09:53   #5071
andreigame
andreigame's Avatar
Default Re: Topicul posesorilor si pasionatilor de BMW E21 (rechin)
1.8 K-jetronic rebuild
segmenti goetze
cuzineti palier king
cuzineti biela mahle
set garnituri si simenringuri victor rienz
chiulasa rectificata complet
baia ulei sudata(din varii motive)
+ spalat curatat piesa cu piesa
2 saptamani de foc ...bagat la somn doar pe la 4-5 dim dar intr-un final a meritat tot.
Multumesc lui Daman pt sprijin si bataia la cap,Mitza tov meu cel mai bun ,colegul lui de munca Dan si lui Interceptorul(bmwutu) pt ca a venit si ma ajutat sa trag mot la punct ca sa ii pun in oridine corecta aprinderea.
In continuare caut :
radiator apa 1.8m10 modelul de rechin
masca 2 faruri mari simple
aparatoare faruri pe interior dreapta
bara fata spate cromata drepte
ID:	2971926   Click image for larger version
ID:	2971927   Click image for larger version
ID:	2971929   Click image for larger version
ID:	2971930   Click image for larger version
ID:	2971932   Click image for larger version
ID:	2971933   Click image for larger version
ID:	2971935   Click image for larger version
ID:	2971936   Click image for larger version
ID:	2971938   Click image for larger version
Dacia Sport B-179-UAP Simple is Enough!
andreigame is offline   Reply With Quote
Old 15-04-14, 14:56   #5072
runceanu alecs
runceanu alecs's Avatar
Cine are traseu m20 ??...galeria o am...de sub masina imi trebuie...e21
runceanu alecs is offline   Reply With Quote
Old 16-04-14, 09:19   #5073
MON-u
Old School Cars
MON-u's Avatar
segmenti goetze
Nice job ... dupa munca si rasplata.
MON-u is offline   Reply With Quote
Old 16-04-14, 09:25   #5074
opia
opia's Avatar
Salutare. Ma poate ajuta cineva cu butonul de avarii pentru e21? Am releul ars in el, si din cauza asta nu merg nici semnalele nici avarile. Multumesc.
opia is offline   Reply With Quote
Old 16-04-14, 19:32   #5075
RacingParts
RacingParts's Avatar
Daca e cineva interesat de ulei MOTUL CLASSIC 20w50, sae 50 si 300v competition, mai am cateva bucati ramase pe stoc.
ID:	2972933   Click image for larger version
ID:	2972934   Click image for larger version
RacingParts is offline   Reply With Quote
Old 17-04-14, 09:35   #5076
andreigame
andreigame's Avatar
Nu cred ca ar avea nevoie cnv de el....Fiindca pe M10 merge ulei 5w30 si 10w40
Eu unul am baga Motul 8100 X-clean Plus 5w30 si merge bine
Old 19-04-14, 15:17   #5077
RacingParts
un mic proiect de sarbatori
Carburatoarele imi fac in continuare probleme...daca vreau sa le accelerez putin mai brusc imi baga prea multa benzina si motorul da sa se inece, imi arunca benzina afara din ele. Jiglerele sunt ok (130 bezina, 180 aer), flotoarele le-am facut astfel incat nivelul in camera de umplere sa fie la 27 mm fata de jiglerul de aer, aprinderea e setata cu lampa stroboscopica, distributia e in regula, am pus si regulator de presiune ca sa nu bage presiune prea mare pompa electrica.
Daca are cineva vreo idee , raman dator
Oricum, Sarbatori fericite tuturor !
Old 19-04-14, 20:23   #5078
daman
daman's Avatar
misto proiectul o sa incerc si eu asa ceva si referitor la carburi.... nu stiu ce sa zic. Sarbatori fericite!!!
daman is offline   Reply With Quote
Old 23-04-14, 14:39   #5079
runceanu alecs
De vanzare motor m10 complet + cutie 70 euro !!! 0747242996
Old 24-04-14, 11:06   #5080
andreigame
andreigame's Avatar
Mister...vezi ca tu mai mult ca sigur ai problema la pompa de benzina.....fiindca tu ai pompa de benzina de presiune si nu de debit.
Iti trebuie o pompa de benzina cu debit si nu cu presiune....eu am pus pompa de benzina Facet
--(Facet Electric Fuel Pump 1.5- 4psi with 2x 6mm unions Classic Kit Car Weber Carb)--
Dupa ce iti cumperi asa ceva ai sa vezi ca dif e mare si o sa'ti mearga masina.
Trecand de la una la alta...as dorii daca poti sa ma ajuti si pe mn cu lampa stroboscopica sa'mi pot regla si eu delcoul la al meu 1.8m10 K-Jetronic...bineinteles daca se poate :P
Old 24-04-14, 11:56   #5081
RacingParts
Sigur, da-mi un pm cu nr de telefon si te astept intr-o zi la garaj
Old 27-04-14, 08:05   #5082
MARY4N
salutare.vad multa miscare pe aici ceea ce ma bucura tare de tot.trageti tare cu "roabele" sa iasa treaba buna .eu am dat masina si imi pare tare rau (((( dar poate intr.o zi.....Bafta tuturor
MARY4N is offline   Reply With Quote
Old 28-04-14, 16:05   #5083
Yetisaurus.Akjas
Yetisaurus.Akjas's Avatar
Question Re: Topicul posesorilor si pasionatilor de BMW E21 (rechin)
A cumparat cineva cumva de curind piese de E21 de la: www.onauto.ro, www.al-padrino.ro, www.ingaraj.ro ?
Vreau sa cumpar de la ei elemente de caroserie si de suspensie si as vrea sa stiu daca sunt de incredere.
Stau in provincie si nu stiu daca merita sa comand de la www.wallothnesch.com daca le pot comanda din Bucuresti.
Multumesc.
Yetisaurus.Akjas is offline   Reply With Quote
Old 28-04-14, 17:11   #5084
andreigame
andreigame's Avatar
Caut si eu cablu kilometraj.....1.8m10 ... help meeeeee :P
Old 28-04-14, 21:59   #5085
AxYJamaicanu
Old School Cars
AxYJamaicanu's Avatar
[Suzuki]
[CHEVROLET]
iti recomand sa iei unul nou de la Unix ... costa cam 80 lei daca nu ma insel. Au 2 modele, alege-l pe cel mai ieftin, ala scump e o porcarie
1981 BMW 316 E21
Sharknose or no nose !
AxYJamaicanu is offline   Reply With Quote
