Originally Posted by dj4u
nu am computer de bord...
intri in diagnostic mode si la meniul 5, submeniul 5.0 iti arata consumul mediu mixt
Put key into ignition and turn it to position 1 (instruments activated).
a2) If you intend driving with diagnostic mode active, start the engine now.
b) Press and hold the trip reset button. This is the button sticking out near the speedometer.
c) Your LCD display will show "test 1.-"
d) Immediately press the reset button every half second until you get to "test 19.-". (19.0 allows access to diagnostic mode)
e) The display will now show alternating "Log 1 -on" / "Log 1 -off"
f) While it shows "Log 1 -off" press the reset button and. .
g) With no delay press within a half second (repeatedly if necessary) to get to the required section.
h) The screen will appear similar to the earlier one, but is a different series. Keep pressing every half second to select one of the following functions (there is no title on screen):
1 Car, Engine and cluster data
1.0 VIN serial number
1.1 K-number
1.2 Cluster Part Number
1.3 Coding (04)/diagnosis (52)/bus index (10)
1.4 Week of manufacture (eg. 1200 = week 12)/year of manufacture (eg. 2000)
1.5 Hardware number (eg. 09) and Software number (eg. 11600 = 16.0) of IPK.
1.6 Injection Status-number of cylinders-motor number
2 Cluster System Test
2.0 Activates the gauge drivers, indicators and LEDs to confirm function.
When function 2.0 is selected, the instrument pack provides a check of the warning lamps, major and minor gauges, displays and illumination functions. The gauge pointers are driven through their full arc and back again to check operation. All warning lamps are illuminated to check that none of the LEDs have failed. All yellow and red pixels of the message centre are flashed on and off in a chequered pattern to check that all elements of the display are functional.
3 Service Inspection (SI) Data
3.0 Fuel Used (in liters) since last Service Inspection
3.1 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 Momentary fuel consumption in litres/100km (eg. 0145 = 14.5 litres/100km)
4.1 Momentary fuel consumption in litres/hour (eg. 0018 = 1.8 l/hr)
5 Distance Gone Consumption
5.0 Average consumption in litres/100km (eg. 082 = 8.2 litres/100km)
5.1 Calculate distance ( km) to refuel (momentary distance to go)
6 Fuel level sensor outputs in litres (Fuel tank has left and right side sensors)
6.0 Fuel levels both (eg: 109330 means left half sensor = 10.9 litres; right half sensor = 33.0 litres)
6.1 Total tank level (eg: 0439 is 10.9+33.0 = 43.9 litres)
6.2 Indicated value with diagnostics: The Test Number (6.2) is preceded by 1, 2 or 3 (eg. 1-6.2 or 2-6.2 or 3-6.2)
If first digit is 1 - both sensors are OK. This is followed by three left signal digits, then three right signal digits.
If first digit is 2 - one sensor has an error. Side in error will display - - 0 . Functional side will show its three digits
If first digit is 3 - no sensor signal, no display. Probably - - 0 - - 0 (Needs confirming -TC)
7 Temperature and Speed
7.0 Coolant/Engine temperature - changes every whole degree Centigrade. (eg: 021+ is 21°C)
7.1 Ambient/Outside temperature - changes every 0.5 degree Centigrade. (eg.125/130/135 is 12.5°/13.0°/13.5°C)
7.2 Engine speed / Current (RPM)
7.3 Vehicle speed / Current Speed (km/hour)
8 Values of 7.0 to 7.3 in HEX form (Unknown)
9 Battery
9.0 Battery Voltage (eg: 137 = 13.7v)
