Old 25-01-09, 01:28   #301
IONUT-GBP
IONUT-GBP's Avatar
Default Re: PROBLEME cu PC-ul
da am ,am dat reset la bios , Lan Boot era pe disabled ...degeaba ... singurul lucru care ma enerveaza este ca trebuie sa apas mereu F1... daca as scapa de asta ar fi OK...nu ma intereseaza placa de retea onbord
IONUT-GBP is offline   Reply With Quote
Old 25-01-09, 08:01   #302
dolb
cum ai dat reset? ai scos bateria?
Old 25-01-09, 11:28   #303
IONUT-GBP
IONUT-GBP's Avatar
nu...defapt am dat revenire la setarile din fabrica
Old 25-01-09, 11:51   #304
dolb
pai ia incearca sa scoti bateria bios-ului stii care e nu? cea de pe placa de baza! o scoti .. o lasi 5 secunde si o bagi la loc
Old 25-01-09, 12:08   #305
StreetStyle22
StreetStyle22's Avatar
Sa nu uiti sa scoti si pc-ul din priza.
StreetStyle22 is offline   Reply With Quote
Old 25-01-09, 12:18   #306
dolb
merge si daca isi opreste doar sursa si pune mainile pe carcasa recomand sa folosesti o surubelnita
Old 25-01-09, 13:16   #307
IONUT-GBP
IONUT-GBP's Avatar
degeaba
Old 25-01-09, 13:28   #308
StreetStyle22
Ai probleme cu Bios,uite aici, http://www.devhardware.com/forums/mo...1t-119353.html . Cred ca trebuie Update la bios. Din ce am inteles eu,el a avut 2.40 versiune bios a trecut la 1.60 dar sistemul era instabil si a recuperat adresa MAc,dupa aceea a trecut la 2.40 din nou si ia ramas adresa mac.Asrock Dual Vista LG775 motherboard, VIA PT880 Pro/Ultra chipset.
So I resorted to flashing the bios back to an older version. 2.40>1.60. In 1.60 they addressed some sort of mac address problem so I figured it was the most appropriate. When I did so, I got my mac address back! Hooray! Except like always, my stable was very unstable, loading apps or trying to play games. So I flashed to 2.40 again and I still have a mac address now. Anyways I'm trying to test system stabability, I haven't reset the cmos yet either, frankly I don't want to unless absolutely necessary.
Old 02-02-09, 14:46   #309
extrm
extrm's Avatar
nu`mi merge messul deloc .. l`am instalat si dezinstalat de "n" ori, diferite versiuni, am reinstalat chiar si windows`ul. Dau dublu click pe icon si pur si simplu nu se intampla nimic, de asemenea este singurul program care nu merge din pc .. toate celelalte functioneaza perfect Stie cineva care ar fi problema ?
extrm is offline   Reply With Quote
Old 02-02-09, 14:48   #310
dolb
probabil sa ai firewall
oricum poti folosi o varianta foarte apropiata de messenger care iti pastreaza si log-urile si am impresia ca poti face si transfer de fisiere.
http://webmessenger.yahoo.com
Old 02-02-09, 14:51   #311
extrm
extrm's Avatar
am dezactivat si firewallu .. degeaba tot nu vrea
Old 02-02-09, 14:52   #312
dolb
ce PC ai.. ce windows pui pe el?
Old 02-02-09, 14:54   #313
extrm
extrm's Avatar
Sp2 l`am avut din totdeauna .. pana acum aproximativ 2 sapt, mergea messu perfect
Old 02-02-09, 15:56   #314
dolb
pai ce sp2? vista, xp, ME .. original? copie? indian?
Old 02-02-09, 19:23   #315
extrm
extrm's Avatar
pai Xp Sp2 ... si e cam copie ...
