Old 06-06-07, 15:18   #166
panaitescud
panaitescud's Avatar
Default Re: Tuning Motor Ford
mii de multumiri lui <<blabla>> mai rari asemenea oameni. am luat acel 2.8
panaitescud is offline   Reply With Quote
Old 06-06-07, 19:49   #167
florin_cars
Old School Cars
florin_cars's Avatar
Felicitari, dar am auzit k nu ajunge tuningu pi el...topicul asta e di tuning
florin_cars is offline   Reply With Quote
Old 07-06-07, 14:14   #168
panaitescud
Thumbs up Re: Tuning Motor Ford
e tunat si fulgerat destul ....a stat afara aproape 2 ani tuning ? hmm ...ramane de vazut.
bafta silencer si codrin
Old 07-06-07, 14:36   #169
florin_cars
Old School Cars
yheeaa..poate am ajutat putin si am impulsionat tuningu in 2.8i
Old 07-06-07, 14:42   #170
panaitescud
dar ramane fara injectie. clasic pe carb.cu admisia de 2.3
Old 07-06-07, 14:55   #171
Silencer Power
Silencer Power's Avatar
o poza putin mai clara
Silencer Power is offline   Reply With Quote
Old 07-06-07, 16:27   #172
florin_cars
Old School Cars
ai planeizat-o? k pare mai curata acum
Old 08-06-07, 20:04   #173
Silencer Power
da, am planat-o
Old 16-06-07, 13:37   #174
codrin44
codrin44's Avatar
silencer-distanta intre supape e 2,32 mm, masurata asa, in joaca. supapa de admisie e mai mare cu 2,5mm in diam iar cea de evacuare cu 1,5mm deci...1,25+0,75=... ma rog, ideea e ca ramane intre supape 0,2 mm cat firul de par de pe spinarea broastei. so,m-am gandit eu sa-i maresc doar admisia ca e mai lejer si pe evacuare am sistemul si asa destul de larg...
~~~~~~~~~ F o r d C a p r i ~~~~~~~~~
don't just get older...they just get faster
codrin44 is offline   Reply With Quote
Old 20-06-07, 22:21   #175
blablabla
baieti, am gasit un ford taunus din 74 in 2 usi tabla e in stare buna necesita o revopsire, masina e radiata cred ca se poate reinscrie, are motor diesel de mertan 2000 cm. ce ziceti?
blablabla is offline   Reply With Quote
Old 20-06-07, 23:00   #176
Silencer Power
Am masurat si eu dinstanta dintre supape, ce-i drept, nu cu exactitate, si am masurat 4 mm intre cee 2... supape.
Uitandu-ma pe burton si oldcars am observat ca se pleaca de la stage 1 - a42.2 si e36.1 pana la stage 3 - a44.5 si e38.1
Evident ca la noi in tara nu as lasa pe nimeni sa lucreze pentru stage 3, dar un stage 2 mi se pare realistic.
Am tot citit si am observat ca 2.8-urile astea sunt limitate mult din evacuare, asa ca as fi mers pe o marire a portului supapei de evacuare, dar pe de alta parte am observat ca pana la stage 3 nu creste decat admisia, ceea ce ma face sa cred ca or stii ei ceva.
Totodata, singurul loc unde am gasit valve mai mari este burton, dar, din pacate supapa de admisie, cat si cea de evacuare sunt pentru stage 3. Prin urmare am/avem 3 variante, admisie, evacuare si admisie si evacuare.
Ce facem?
ps: 101.4 lire - supapele de evacuare... 101.4 lire cele de admisie
Old 29-06-07, 13:11   #177
Silencer Power
Mi-a sosit timing set-ul... sunt fericit si ma simt bine cu atat mai mult cu cat roata axului este muuult mai usoara decat originala, eu aproximez o diferenta in - de 1-1,5kg, dar le cataresc cand ajung acasa ca sa nu vorbesc prostii.
ID:	295294   Click image for larger version
Old 29-06-07, 20:43   #178
Silencer Power
hi hi hi se pare ca am gresit putin
asadar, avem urmatoarele valori:
timing original
1. pinion ax: ~1910g
2. pinion vibrochen: ~810g
total: 2720g
timing comp:
1. pinion ax: ~825g
2. pinion vibrochen: ~725g
total: 1550g
Old 03-07-07, 14:36   #179
AlliedComposites
de la ce masina vine motorul? asta e partea cea mai importanta... 150 de cai dintr-un motor V6 e complet bataie de joc sper ca-ti dai seama... mai orice are atata acum, deci nu stiu daca merita sa indesi o tona de bani intr-un motor varza.... sper ca nu e de la un mustang V6 ca alea sunt asa o varza... daca luai un motor de 4L as fi avut toata stima
AlliedComposites is offline   Reply With Quote
Old 03-07-07, 19:05   #180
Silencer Power
Am spus eu pe undeva ca vreau bolid sau te-am intrebat pe tine daca merita investitia sau nu, sau ti-am spus care sunt motivele mele pentru care fac investitia asta, sau la cat se va ridica investitia si ce putere va avea motorul...?
- Copyright 2025 4Tuning -
