Old 29-05-09, 20:47   #1
kempo
Default ALEGERE MOTOR PENTRU MONTAT TURBO
SALUTARE! AM SI EU O MICA MARE PROBLEMA...AM TOT CITIT PE AICI DAR NU AM GASIT NIMIK SA MA LAMUREASCA..ASA K O SA PUN O INTREBARE SI SPER SA NU SE SUERE NIMENI!
AM UN E30 CARE INITIAL A FOST UN 1.8 M10 CARBURATIE...ACUM E UN 2.3 JETRONIC....IDEEA E K AS VREA SA TREC PE TURBO SI NU STIU CE MOTOR E CEL MAI BUN PT ASA CVA.... MA REFER MODIFICARILE DE PRINDERE PE CAROSERIE SA NU FIE DIFERITE SI NICI COSTURILE SA NU FIE FOARTE MARI
IDEEA E CA VREAU SA FIE DUS UNDEVA IN JURUL A 300HP...MA GANDEAM ORI 2.3, 2.5 (12V) ORI DE PE E36 UN 2.5(24V) SAU AM AUZIT CVA DE CELE IS K AR AVEA DEJA PISTOANELE FORJATE, ETC
kempo is offline   Reply With Quote
Old 30-05-09, 02:03   #2
sTAILLL
sTAILLL's Avatar
Default Re: ALEGERE MOTOR PENTRU MONTAT TURBO
2.5 12v sau 24v sunt cele mai bune pt turbo , la 2.3 e foarte greu de reglat
sTAILLL is offline   Reply With Quote
Old 30-05-09, 08:57   #3
kempo
bun! deci in principiu ar ramane 2.5 24v... ideea era cu cele IS...am inteles k scapi de cheltuieli forte mari dak pui turbo pe ele pt k nu necesita schimbarea pistoanelor, axei cu came, suape, etc
Old 01-06-09, 17:00   #4
dj05fmx
dj05fmx's Avatar
turbo fara cheltuieli nu exista la o conversie...
dj05fmx is offline   Reply With Quote
Old 03-06-09, 16:15   #5
VENOX
CITROEN Driver
VENOX's Avatar
[Nissan]
[CITROEN]
Sau mergi pe un motor de Nissan Turbo:
un CA18DET 1.8Turbo sau SR20DET 2.0Turbo
ID:	947993   Click image for larger version
ID:	947994   Click image for larger version
VENOX is offline   Reply With Quote
Old 03-06-09, 17:17   #6
kempo
SINCER VREAU SA-I LAS MOTOR DE BMW K ALTFEL MA GANDEAM LA MOTORUL DE PE VECHEA SUPRA ALA DE 3000 TURBO/BITURBO
SI STIU K TURBO FARA CHELTUIELI NU EXISTA (MINIM 2000 EURO)MA REFEREAM SA NU EXAGEREZ CU COSTURILE
Old 07-06-09, 21:46   #7
leonard
leonard's Avatar
alege un 2.5 24 v , 24v sunt mai eficiente decat 12v ... dar nici m20b25 nu e rau ....
din 24v poti scoate 300+ cp fara sa schimbi internele ... si fara sa fortezi motoru prea mult .
e o poveste ca 1.8is ar avea pistoanele forjate .... intradevar are unele piese mai "intarite" ... dar nu rezista la o presiune f mare la turbo ..si fiind de o cilindree mai mica ... puterea nu va fi spectaculoasa in comparatie cu un 2.5
din 1.8is fara interne schimbate mai mult de 250cp si sa fie si fiablia nu prea poti scoate.
leonard is offline   Reply With Quote
Old 08-06-09, 01:13   #8
kempo
ms mult! deci pana la urma ramane 2.5 24v...ma gandeam si la v6 sau v8(nu stiu sigur care e) de m5
Old 08-06-09, 13:48   #9
leonard
leonard's Avatar
e 6 in linie (v6 din cate stiu eu nu s-a pus pe bmw) , 3.6 sau 3.8 de pe m5 e34 , se preteaza iarasi foarte bine la turbo dar si costurile de achizitionare plus conversie turbo sunt cam duble fatza de 2.5 24. gandeste-te ca doar motoru de m5 costa 4 , 5 mi euro..
Old 09-06-09, 15:04   #10
Victor_WRC
Victor_WRC's Avatar
1 motor de supra mk4 3.0 l twin turbo e in jur de 1500 de lire in Marea Britanie dar nu e asta problema , problema e ca o cutie pt ea de 6 trepte e vreo 2000 lejer ...dar ai 330 de cai......ceea ce mi se pare o prostie e sa pui pe 1 BMW alt motor de exemplu cum a postat cineva mai in sus motor de Nissan pe BMW.... cel mai bun pt o conversie turbo si costuri mai mici de la BMW este 2.5 24v
Old 10-06-09, 09:14   #11
kempo
exact victor! e aiurea sa deschizi capota si sa vezi alt motor...chiar dak e potent! cat despre potorul de supra oricum nu ma complicam sa iau motorul si cutia k stiu k ajungeam undeva la vre-o 4000! am gasit cacalau supre la 3000 (toata masina) si eventual dak tot ii puneam alt motor ii luam si restu de pe supra )) in principiu motorul de 2.5 24v ramane. am auzit k merge sa-i pui turbo fara nici o modificare dak mergi pe o presiune mica
Old 10-06-09, 15:59   #12
Victor_WRC
Victor_WRC's Avatar
o fi nus tiuc e sa zic dar eu in principiu cat am stat sa caut toyota supra mk4 nu am gasit mai iestin de 5000 de lire twin turbo , 6 viteze manual
Old 11-06-09, 23:09   #13
Petrucio
Petrucio's Avatar
Eu nu prea sint de acord cu 2.5 24v la e 30!ca are cam aceleas interne ca si 1.8 is+ 2 cilindri!Dar greutatea pe fata masinii? si atunci degeaba mai are 300 cp daca tot demareaza pe loc,si cind accelereaza cu fata ingropat in asfalt!!! si fara schimb de interne (pistoane cu cr mai mic) si ecu stand alone nu prea mare treaba o sa faca! de oarece e greu primii 300 cp dupa care urmeaza dorinta de mai multi si mai multe!un 1.8 is are potential de 400-450 cp la nevoe si 600+ cu bani grei bagati in el!De pinde pentru ce scopuri il vrei!Cu un ecu bun poti avea 2 rejimuri! ca de exemplu 200cp zilnic-400+ la nevoe! Principalul e sa fie drept repartizata greutatea pe axe!!!pentru o acceleratie mai buna!
BMW 318 IS TURBO COUPE 1997 Garrett XXXL NEW SETUP coming soon
Petrucio is offline   Reply With Quote
Old 12-06-09, 08:21   #14
da_joint
da_joint's Avatar
Nu vreau sa mi-o iei in nume de rau...dar ai mers cu vreuna din masinile mentionate mai sus?
adica 1,8is turbo si 2,5 24 v turbo? nu spun ca nu are potential si 1,8 is-ul...dar pentru o putere de peste 300cp ,is-ul deja este in presiune cam mare...
da_joint is offline   Reply With Quote
Old 12-06-09, 11:18   #15
bimmer3
blasfemie
motoarele alea sunt super ok dar pt nissan
gandeste-te ca pasionatii de bmw nu pun motoare chinezesti nici sa-i pici cu ceara cum nici tu n-ai pune pe nissan bmw
bafta
bimmer3 is offline   Reply With Quote
