Old 20-02-07, 13:12   #1
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
Default 2007 Ferrari F430 Challenge Stradale
F430 Challenge Stradale, ce va intra pe piata spre sfarsitul acestui an, a fost surprins in timpul testelor. Aveti mai jos fottografiile "spion".
Cu un motor V8 de 4.3 litri, F430 CS va dispune de 525 cai putere la o turatie de 8500rpm si de un cuplu de 475nm la 5750rpm.
ID:	219974   Click image for larger version
ID:	219975   Click image for larger version
Old 20-02-07, 13:17   #2
Andreus
Andreus's Avatar
Default Re: 2007 Ferrari F430 Challenge Stradale
Ferrari ramane Ferrari.....oricum cred k i`ar fi stat mai bine pe roshu
Andreus is offline   Reply With Quote
Old 20-02-07, 13:25   #3
Tzus
Tzus's Avatar
Corect...pe roshu ar fi cu totul altceva...oricum masina e bestiala...ce poti sa spui despre Ferrari?
Tzus is offline   Reply With Quote
Old 20-02-07, 13:28   #4
Luigyy
Luigyy's Avatar
arata bine , dar motorul ala de 525 bhp face totul
Luigyy is offline   Reply With Quote
Old 20-02-07, 15:30   #5
z3r0m3CSL
z3r0m3CSL's Avatar
Da ii fain, de ce nu is la fel gentile din fata cu alea din spate ?
z3r0m3CSL is offline   Reply With Quote
Old 20-02-07, 15:37   #6
Donnyro
Donnyro's Avatar
[SEAT]
Dupa nume(challenge STRADALE)cred k e conceputa pt liniutze.
Donnyro is offline   Reply With Quote
Old 20-02-07, 16:26   #7
F430
F430's Avatar
cat poate sa fie de fain si motoru ala te innebuneste e bestiala masina ca un ferrari
F430 is offline   Reply With Quote
Old 20-02-07, 17:26   #8
Bemelo
Bemelo's Avatar
nu chiar.. ca si la modelul precedent acest Ferrari o sa-si arate valoarea pe circuit..
Bemelo is offline   Reply With Quote
Old 20-02-07, 18:24   #9
boy_wonder
boy_wonder's Avatar
Sa vedem cum va arata varianta finala..
Old 20-02-07, 18:37   #10
RoSonic
RoSonic's Avatar
[4 Speed Squad]
Pentru ca e o masina aflata in teste.... modelul jantelor e total irelevant...
Old 20-02-07, 18:57   #11
Sasha_z
[Crazy Drivers]
o daaaa nemaimpomenit... !!!!!
Sasha_z is offline   Reply With Quote
Old 20-02-07, 19:06   #12
-LEXION-
cu 100 kg mai usor, si un sunet extraordinar, F430 challenge stradale va fi lansat in toamna 2007
-LEXION- is offline   Reply With Quote
Old 20-02-07, 19:26   #13
solo24
solo24's Avatar
e misto unde are evacuare,la o curba te apropi de el si sa vezi cum te parlesti un pic(la propriu)cred ca iti arde un pic vopseaua
misto
solo24 is offline   Reply With Quote
Old 20-02-07, 19:26   #14
Todorutz
Todorutz's Avatar
ferrari continua seria sportivelor cu acest nou F430. au o istorie in spate pe care trebe sa si-o consolideze, dar se pare ca n-au probleme in a o duce la capat. fiecare model te lasa cu gura cascata doar la design, fara sa vorbim de motor si acel sunet specific....o minune pe 4 rotzi
Heartbroken by a Skoda Fabia WRC!!!
Todorutz is offline   Reply With Quote
Old 20-02-07, 20:06   #15
caroletho
caroletho's Avatar
o masina foarte reusita, doar e ferrari. imi place mult spatele care aduce a F1 prin pozitionarea evacuarii si prin agresivitatea deflectorului de aer.
caroletho is offline   Reply With Quote
