Go Back   Forum 4Tuning > Tuning Motor & Mecanica > Dyno Tuning > PowerTech Performance
Old 22-12-11, 17:52   #1
450yfz
450yfz's Avatar
Default Bmw 530 E60 235Hp manual&automat
Modificari - DPF OFF
- Powertech Chipped
Automat - 301,8 Hp
- 680,5 Nm
Manual - 306,7 Hp
- 724 Nm
Name:	BMW 530D E60 235HP_AUTOMATIC- MOD POWERTECH.JPG
ID:	2269894   Click image for larger version
Name:	BMW 530D E60 235HP_MANUAL- MOD POWERTECH.JPG
450yfz is offline   Reply With Quote
Old 22-12-11, 21:26   #2
bikks
bikks's Avatar
[Mitsubishi]
[Pole Position Racers]
Default Re: Bmw 530 E60 235Hp manual&automat
Salutare.
Performantele astea sunt atinse doar cu o remapare sau sunt si ceva interventii mecanice?
Merci.
bikks is offline   Reply With Quote
Old 22-12-11, 23:03   #3
450yfz
450yfz's Avatar
Originally Posted by bikks View Post
Salutare.
Merci.
Eliminare DPF si Soft ATAT!
Old 23-12-11, 07:27   #4
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Foarte corect frumos si elegant ar fi sa afisati si graficul cu puterea de serie.
Eventual suprapuse, ar fi excelent.
Succes!
Old 23-12-11, 09:24   #5
bitnet
Succes!
Adica astea?
Name:	BMW 530D manual-stock.JPG
ID:	2270361   Click image for larger version
Name:	BMW 530D automatic stock.JPG
bitnet is offline   Reply With Quote
Old 23-12-11, 09:28   #6
bitnet
Succes!
Sau astea...
Name:	BMW 530D manual- comparatie.JPG
ID:	2270367   Click image for larger version
Name:	BMW 530D automatic- COMPARATIE.JPG
Old 23-12-11, 18:58   #7
TURBOSS
TURBOSS's Avatar
frumoase valori cu soft+dpf-off.
rezista vibrochenul la o "chinueala" mai tare?
TURBOSS is offline   Reply With Quote
Old 24-12-11, 12:04   #8
DEVIL's Style
DEVIL's Style's Avatar
[Toyota]
pot sa confirm si eu ca cel putin la modelul cu , cutie automata , pierderea de putere este cat se poate de reala , e valabil si pentru 530d si pentru 535d. Ca ne place sau nu , atat pierde bmw ul e60 , grafic valurit am mai vazut iar singura explicatie logica care o pot gasi acum , e ca masina a fost testata cu rotile de iarna [ gresesc? ]
Repet : puterea la roti e reala , nu am de ce sa ii tin partea lui bitnet aici. Si daca la e60 pierderea o considerati exagerata , masurati un a6 3.0tdi quattro cu 320 de cai la motor [ resoftat ] sa vedeti ala ce pierderi are. o sa ramaneti uimiti.
DEVIL's Style is offline   Reply With Quote
Old 24-12-11, 12:08   #9
kathalin
e60 530d cu 235cp stock?235?
Si intrebarea mea este cat de safe este la cutia automata ?
kathalin is offline   Reply With Quote
Old 24-12-11, 12:36   #10
bitnet
Nu gresesti, masina cu cutie manuala a avut anvelope de iarna.
Old 24-12-11, 12:39   #11
bitnet
Da, 173KW. Masina in configuratia in care a fost masurata a participat si la dragracing si nu au fost probleme cu cutia. Timpul obtinut: 13,4s/402m
Old 24-12-11, 15:50   #12
cristi_407
cristi_407's Avatar
E normal ca o masina 4x4 sa aiba mai multa pierdere decat una spate respectiv fata.. nu vad rostul comparatie facuta de DEVIL's Style intre 2 masini care nu au nimic in comun..
Peugeot 407 & Vw GTI & A4 B6
cristi_407 is offline   Reply With Quote
Old 24-12-11, 15:52   #13
DEVIL's Style
[Toyota]
Faceam referire ca si alea au pierderi destul de mari in categoria lor , nu tractiune spate vs 4x4.scuze de neintelegere.
Old 24-12-11, 15:56   #14
cristi_407
cristi_407's Avatar
Caz cu care m-am intalnit S5 4.2 v8 quattro 356cp pe dyno motor/ 260 roata.. Felictitari Binet pt realizare.. Am vazut un 530d facut de tine si chiar merge foarte bine...
Old 24-12-11, 16:41   #15
bitnet
Cel cu cutie manuala este chiar din Bacau.
