am o problema de ceva vreme am pus vac comul pe masina (golf4 2,0 benzina) si imi da
VAG-COM Version: Release 409.1-US
Control Module Part Number: 1C0 907 379 E
Component and/or Version: ESP FRONT MK60 0103
Software Coding: 0011266
Work Shop Code: WSC 31414
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
00285 - Shareware Version. To Decode all DTCs
012 - Please Register/Activate - Intermittent
pornesc masina totul ok merg 2,3,10 km si mi se aprinde abs si dupa el si esp astea sunt erorile pe care le am ,daca otresc si pornesc revine la normal si sta si cate o zi 2 si merge ok
