04-09-09, 14:08
#196
Member of: [PARTICIPANT CURSE] [Style in Motion]
Re: CARPuter...sau cum sa facem din nimica ceva bun pentru masina
04-09-09, 14:14
#197
pot aduce eu urmatoarele variante:
1. In-Dash TFT-LCD Touchscreen VGA Car Monitor
7 inches fully-motorized in-dash car TFT-LCD monitor with TV and touch screen for car PC
Display Size: 7.0 inches (16:9 )
Physical Resolution:800*480 RGB Supported Resolution:1024*768
Visual Angle:40(l) ,30(u) Brightness: 400 Contrast: 250
AV Chromatic System: PAL/NTSC (auto switch)
Working Power: DC11.5V-13V ( 900mA) Electronic Consumption: 10W(max)
Operation Temperature: -20-60℃
Input Port: Double-channel video input, one TV input ,one VGA input,one USB input ,one power input
Function : OSD menu ,touch screen for PC,TV, AV(CD,VCD,DVD,GPS,camera),rearview system
Output port: Double-channeal TV audio output
Accessories:Remote controller, English instruction manual ,one CD disc,one touch pen, cables
890 ron (nu include TVA)
2. CAR PC 1DIN dedicat (sursa automata, pornire-oprire automata la contact, standby fara descarcarea bateriei, consum 42W, amplificare 4x45w). Diferentele fata de solutiile home made sunt evidente daca aprofundati putin problema alimentarii si a opririi pornirii sistemului in combinatie cu monitorul, contactul, etc.
Lilliput Car PC DVD Player With 7" VGA Monitor Combo
Product Remarks
1-DIN IN-Car Automobile Computer & Media Player
Function:
Car PC
Media Player: DVD, VCD, CD, MP3 (Off OS)
Wireless Internet Access (Optional with PCMCIA Card)
DVB-T Player (Optional with USB Accessories)
Remote Control
CPU Up to 1G
Memory Up to 1G
HDD Up to 80G
Front Panel USB, MIC, EAR Port
Back Panel USB, MIC, EAR, LAN, PS2 Port
Portable & Handy, Easy for Installation
Low Power Consumption
Antivibration Design
Anti Noise Design
Special Heat-elimination Design
Key Specification:
Model: TC1000
CPU: 1G
Memory: 256M
Hard Disk 30G
Rom: DVD Rom(CDRW & DVD COMBO Optional)
USB: Front Panel*2, Back Panel *2
Power Supply: DC 11-16V
Power Consumption: <42W
Dimension (mm): 208W x 177H x 54D
Weight (kg): 1.55
Accessory:
Remote controller 1PC
Car power adapter 1PC
Instruction manual 1 PC
7-Inch 15:9 Wide Screen In-Dash TFT-LCD Touchscreen VGA Monitor
Function:
In-Dash mount, motorized
Adjusting vertical angle
Touchscreen : USB
Universal TV tuner: PAL/NTSC/SECAM
AM/FM radio
4-track 45W audio amplifier
2 videos incl. one for rearview system display.
PAL/NTSC color system
High resolution- up to 1024x768 (H x V) formatted
VGA input (15 pin D-SUB)
On Screen Display Control (Multi-language)
Full function infrared remote control
2 RCA video inputs, Audio input
Speaker (for video mode) built-in
Backlight control available
Key Specification:
Screen Size: Diagonal 7 "
Dot Resolution (RGB): 800(H) x480(V) = 1,152,000 (dots)
Aspect Ratio: 15:9
Contrast: 250:1
LCD Brightness: 350cd/m2
Viewing Angle: 45/60(U/D),65/65(L/R)
Operating Voltage: DC 11-13V
Power Consumption: <10W
Dimension (mm): 1DIN(179W x 49H x 190D)
Weight (kg): 1.86
Accessory:
VGA Signal Cable with 9 holes
A/V Cable
Remote Controller
Drive Disk(Matcheh With Touch Function)
Operation Manual
pret 2500 ron (nu include tva)
04-09-09, 14:36
#198
mersi de oferta , 1 din nu vreau , vreau un car pc 2din cu unitate incorporata sau separata . atasez cateva poze sa ti faci o idee de montaj .afisaju cu clima si meniu masinii trebuie montat sus la grila de aerisire ca n prima poza .
04-09-09, 15:07
#199
sunt improvitatii si nu as face asa ceva...daca e un kit retrofit cu cocoasa respectiva pentru clima putem face.
04-09-09, 16:04
#200
nu este nici o improvizatie daca este bine facut ,cum spuneam cap-coada , acel capac de sus cu afisaju climei se cumpara de la peugeot dealer ,este pe dotarea de 407 coupe din UK ,trebuie mutat sus acolo vine ca la el acasa :d ,si de restu sa se ocupe cineva priceput ...
04-09-09, 16:06
#201
atunci cumpara piesa respectiva, alegeti un 2din cu pc integrat din oferta si iti pot recomanda pe cinva sa se ocupe de montaj.
07-09-09, 16:55
#202
Audi Driver
Faci cinste???
Am exact omul de care ai nevoie
06-10-09, 07:51
#203
Originally Posted by bluey
Faci cinste???
Salut.
Sunt nou pe aici dar, citint acest topic, am si eu o intrebare:
cum pot monta un un Multimedia DVD-CAR la o Mazda 5 din 2005 , model care are display-ul navigatiei in partea superioara a bordului nu pe partea frontala cum sunt noile modele de Mazda?
Ma gandeam sa schimb unitatea DVD-Navtec din torpedou si acolo (1DIN) sa amplases unitatea multimedia. Problema este cum fac sa schimb display-ul original cu unul touch si legatura cu unitatea multimedia?
si cine poate sa-mi faca aceste modificari? Trebuie un cunoscator ca altfel, daca incerc eu, cine stie ce iese!
06-10-09, 07:56
#204
Audi Driver
Exista solutii si pentru asta desi e complicata treaba pentru ca acolo ai un conector flexibil si trebuie sa te legi la el acesta fiind o panglica din plastic cu metalizari.
Se poate face !
Stock is for woosies
Smoking is for woosies
06-10-09, 08:01
#205
Se poate face !
Exact, asa m-am gandit si eu.
ma intrebam daca nu cumva as putea conecta un display-touch , monitor prin usb sau ce conector ar avea unitatea multimedia, daca are, pentru iesirea monitor exterior.
Caut acum pe met modele de multimedia cu iesire pt monitor touch externt. poate exista si atunci e mult mai usor, probabil...
06-10-09, 08:20
#206
Audi Driver
Pai monitorul nu are treaba cu touchscreenul decat mecanic.
Interfata de touch se monteaza practic pe un monitor standard si se conecteaza pe usb.
06-10-09, 08:26
#207
Sa inteleg ca pot folosi acelasi display, original de la bord si cumva sa folosim legaturile lui cu unitatea din torpedou?
Cred ca legaturile originale sunt mai simple, doar video.
Nu stiu, nu ma pricep la asa ceva...
06-10-09, 08:34
#208
Audi Driver
Nu ca displayul masinii nu are aceleasi conexiuni ca cel din torpedou.
Ma refeream la posibilitatea de a-ti lua un alt monitor fara touch screen cu aceleasi dimensiuni ca cel din torpedou.
06-10-09, 08:40
#209
In principiu, ideal este sa folosesc monitorul touch cu care este dotata unitatea multimedia si sa incerc sa o potrivesc in locul display-ului original de pe bord si, cumva sa prelungesc (cred ca cu vreo 30-50cm) pamblica de legatura sau s-o inlocuiesc cu cablu din cel cu 5-7 fire de cupru, care este si ecranat.
06-10-09, 08:45
#210
Audi Driver
Nu iti ajung 5-7 fire acolo
