Old 28-03-13, 23:53   #46
B39738
B39738's Avatar
[Streetline-CCC]
Default Re: How to Lie With a Dyno
Si ca sa mai diversificam, sa ma apar si eu ca tot m-a acuzat Racing Code si sa mai dam jos si Mustang-ul ala de pe piedestalul imaginar:
I Hear That Dynojet Dynos Inflate Numbers, Is That True?
Postby TillmanSpeed on Fri Jul 25, 2008 8:35 pm
Absolutely not. A good amount of thought was used by competing dyno brands to think of different reasons to steer customers from Dynojet. Every single brand of dyno has a thick packet (about 15+ pages) of reasons why they're the best around.... except Dynojet.
When we were researching the best dyno to choose while we were in the market, everyone had their opinions on everyone else's dynos. The common misconception is "Dynojet numbers read higher, therefore misleading the consumer."
Let's start with the facts. The largest competition for Dynojet would be Mustang Dyno. They claim that the inertia dyno (referred to as non-loaded style dyno) that is manufactured by Dynojet is inferior to their eddy-current dyno (referred to as loaded style dyno). Traditionally, Mustang Dyno produced eddy-current and Dynojet produced inertia dynos. It is a fact that BOTH Dynojet and Mustang dyno manufacture and sell inertia style dynos today. If inertia is so bad, than why would Mustang Dyno produce them? Dynojet offers an eddy-current ADD-ON, which we have, that allows you to still utilize the same eddy-current braking for loaded sweep and step testing, and then turn it off with a click of a button!
Justin Starkey, of VMP Tuning said it best "Mustang Dynos can be tuned, and some tuners spend more time "tuning" the dyno than the car. Dynojets can not be "tuned" to read higher or lower."
The rumor is that Dynojet can "mess with" or "skew" numbers so that they are higher, and in the end make the customer happy, and their dealers look better. This is untrue. The only manipulation of numbers that can be done in Dynojet's software is correction factors. The shop can switch from SAE, STD, and a few other correction factors that take into consideration Altitude, Climate, Temperature, etc. These correction factors read within approximately 2% of each other. Most experienced custom tuning shops use SAE corrections, as per the Society of Automotive Engineers. The electronic stack on the Dynojet automatically takes these parameters and factors your correction and even prints them on EVERY DYNO SHEET. Dynojet owners CANNOT remove the correction factor and smoothing level from your sheet. This is so that dealers, racers, and consumers can compare apples to apples. DYNOJET DOES NOT USE A CORRECTION FACTOR TO ACCOUNT FOR NOR CONVERT LOAD AND NON-LOADED PULLS.
Keep in mind that this weather-station box is standard on all Dynojet models. It is an OPTION with Mustang Dyno. How many un-educated MD owners didn't opt for the additional costs because they had no knowledge of what it does?
Air fuel ratios, timing, etc. Can all still be dialed in 100% correctly on an inertia dyno. The difference is that you have a faster pull, and a smaller window. This means that the tuner must be fairly good. Most end up prefering the Dynojet brand for life after their experience. In most cases, the air fuel ratio and boost levels are IDENTICAL when run back to back loaded and then unloaded on our dyno. What does that prove? I know what it dis-proves!
Another classic quote from Justin @ VMP Tuning: "To further lend credibility to Dynojet...remember the 99 Cobra fiasco? The cars did not make the power that was claimed, they were only putting down 250-260RWHP on Dynojets (the industry standard). The cars were rated at 320 crank HP, with a 15% drivetrain loss they should put down at least 270 HP at the wheels. Attention was brought to the issue, and Ford acknowledged it and fixed it. Do you see people suing Ford because their new Mustang GT only made 220RWHP on a Mustang Dyno? Nope. No one would take them seriously. Ford rates the car at 300 crank HP, and it truly makes that much power or more when ran on a real dyno."
The Dynojet 224xLC is the most reliable and efficient dyno on the market. The inertia part of the dyno only has two bearings and one roller. No other working parts that can wear out, sensors to calibrate, etc. Real simple, the weight of the drum, accellerated over a period of time, and that's the science. It's exact math. We know the weight of the roller, the time that it takes to get to a certain speed, and that's the method. And if we want to, we can put load against it, too.
EVERY DYNOJET READS WITHIN 1% OF THE NEXT DYNOJET. Can other brands say that? No. Try it out and see the results.
The software and Datalogging capabilities speak for itself. Dynojet is the only company with an OBDII datalogging system that can be printed right on the graph!
We at Tillman Speed put alot of research in when we were deciding on which dyno was right for us. And we believe, and so do others, that Dynojet was the best decision that we could have made.
Just as Honda, Kawasaki, Ford, Harley Davidson, and the THOUSANDS of other Dynojets that are currently up and running.
There is none other like it."
End of story.
Šjure: MY RENAULT5 AND MY KADETT TURBO WERE STATUS SYMBOLS, THEY WERE SYMBOLIZING ME BEING POOR.
www.completechip.ro
www.anulare-dpf.ro
B39738 is offline   Reply With Quote
Old 29-03-13, 06:04   #47
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Originally Posted by SEBASTIAN View Post
Replica mea pentru acel topic este aceasta si imi pare rau ca oamenii de acolo nu pot suporta o discutie tehnica incercand sa duca totul in derizoriu singura sansa sa ascunda mizeria sub pres.
Nu e vorba de Maha e vorba de bitnet&co si latraii.
Pe principiul chelul isi pune mana in cap reactionati si voi aici:
https://forum.4tuning.ro/678-powertec...ml#post5414657
, iar exemplele voastre sunt menite sa va acuze nu sa va disculpe.
Pierderile afisate... ce e asta, poate pierderile masurate.
Asa este afiseaza, de fapt masoara pierderi mairi insa pierderea se judeca in concordanta cu viteza.(macar atat trebuia sa stiti)
78 hp pierdere la tine la 158Km/h
in fisele celelalte ai pierdere de ;
82hp pierdere la 206Km/h pentru GTI MK6
76hp pierdere la 224Km/h pentru Scirocco
Imi cer scuze daca voi credeti ca am ceva cu voi, dar eu discut despre prostiile pe care le afisati si sustineti.
Oricum sunt convins ca nu aveti un proces verbal de tarare, de punere in functiune a dyno din partea producatorului sa a unei firme autorizate MAHA.
Si ca sa vedeti o fisa dyno a unui tuner ai mult decat consacrat in zona VW am sa va expun o fisa a unui S3 tunat de un tuner grec cu Maha.
La ei la 4x4 nu ajung pierderile la cat le afisati voi la viteza apropiata.
Ai sa vezi ca la 160Km/h are tot 80hp pierdere ca la tine. Cum iti explici asta ca la aceeasi viteza ai pierdere de 4x4 tot pe MAHA si dupa cum vezi oameni afiseaza si Qv pe fisa.
Iti spun eu sigur ca firma asta care a obtinut rezultatul din graficul asta nu are nevoie sa fure.
Si nu mai stergeti posturile care sunt la subiect!
Sau inainte sa emiti ineptiile pe care le sustii invata sa citesti o fisa dyno si o sa vezi ca devi penibil in fata celor care inteleg asta.
Domnilor daca aveti ceva de spus va las sa continuati discutia si sa dati explicatii pe intelesul tuturor si nu copy/paste aberante.
Este un subiect punctual care merita sa primeasca un raspuns.
Professional DynoTuning
[email protected]
0723691731
Old 29-03-13, 06:20   #48
ct77pia
ct77pia's Avatar
[Anonymous Motorsport ]
ca de obicei cand nu mai are argumente schimba topicul si scoate la iveala rahatul ala de biblie unde se incadeaza perfect
ct77pia is offline   Reply With Quote
Old 29-03-13, 06:38   #49
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Donmilor Ginel alias bitnet,ct77pia, B39738 acel articol pe care nu sunteti in stare sa-l cititi indica un IQ cu mult peste al vostru si va rog sa ma scuzati ca spun asta chiar cu riscul de a le insuma pe ale voastre.
Inainte sa va ganditi si sa va puneti astfel de intrebari raspunsurile erau deja date. Asa ca pentru tot ceea ce e explicat acolo atat de bine si de logic, verificabil in amanunt cu formule fizice de clasa 7 nu pot sa ma aplec sa va mai dau inca un raspuns. Acela este raspunsul complet si daca aveti argumente tehnice puteti sa-l demontati altfel continuati sa latrati, tare, mai tare, puteti sa faceti si ca lupu si ca trenu-n gara...
Stiu si ma bucur ca intrebarea mea legitima, v-a enervat, asta insemna ca am atins un punct sensibil si acum este mai greu sa deformati adevarul.
Ala rau fuge de tamaie voi fugiti de Biblia Dyno:
https://forum.4tuning.ro/175-dyno-tun...rile-dyno.html
Dar eu nu am venit sa ridic in slavi Mustang si nici sa critic dinojet sau maha si vad ca dai intr-unl tipa doi precum ceata lui Pitigoi.
Intrebarea mea nu vizeaza maci de dyno ci anumite fise care in opinia mea si a fizicii denatureaza adevarul, dar intr-o directie care va convine voua mereu, fapt care ma face sa cred ca zicala: "Omul sfinteste locul" are si reversul medaliei.
Old 29-03-13, 07:41   #50
bitnet
Nu te mai apleca, ai vazut cat de periculos este, nici doctorul Bacalbasa nu o sa te mai poata repara.
bitnet is offline   Reply With Quote
Old 29-03-13, 10:15   #51
ZAUBER
ZAUBER's Avatar
Exclamation Re: How to Lie With a Dyno
Originally Posted by bitnet View Post
[I] sunt un simplu utilizator de stand MAHA si nu fac parte din echipa de proiectanti, sunt detalii tehnice pe care nu mi le-am propus sa le cunosc.
dc?
mi se pare normal ca unul care se ocupa de softuri si de dyno sa cunoasca ceea ce foloseste! mi se pare amuzant ceea ce ai spus, este un downgrade.
S 600 tunat cu toporul= S 400,4 matic
maybach S62 tunat cu toporul=S 600
ZAUBER is offline   Reply With Quote
Old 29-03-13, 10:37   #52
bitnet
Tu stii totul despre masina pe care o conduci? Instalatia electrica, management motor, transmisie, etc... Si daca nu stii nu inseamna ca esti un sofer prost, poti fi unul foarte bun.
www.powertechperformance.ro
CHIPTUNING, ANULARE DPF TEL: 0722 340 445
0766 658 781
