Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > BMW > BMW tuning
Old 09-02-06, 12:27   #1
AleXuTz
AleXuTz's Avatar
Default B.M.W E30 >>350<<
B.M.W E30 350 V12
ID:	67596   Click image for larger version
ID:	67597   Click image for larger version
ID:	67599   Click image for larger version
ID:	67600   Click image for larger version
ID:	67602   Click image for larger version
ID:	67603   Click image for larger version
AleXuTz is offline   Reply With Quote
Old 09-02-06, 12:46   #2
ZerO_CooL
ZerO_CooL's Avatar
Inteleg ca iti place, dar aici e sectiunea \"Masina mea\"
ZerO_CooL is offline   Reply With Quote
Old 09-02-06, 12:56   #3
AleXuTz
AleXuTz's Avatar
mmmdap
Old 09-02-06, 13:02   #4
alecsutu1
Pozele sunt luate de pe E30.de nu?
alecsutu1 is offline   Reply With Quote
Old 09-02-06, 13:07   #5
ZerO_CooL
ZerO_CooL's Avatar
Pai eu de aia i-am zis ca e sectiunea \"Masina mea\", ca am vazut ca sunt pozele de pe e30.de
Old 09-02-06, 13:20   #6
Turbo110
Turbo110's Avatar
ce vreti are 15 ani
Turbo110 is offline   Reply With Quote
Old 09-02-06, 18:45   #7
AleXuTz
AleXuTz's Avatar
poate daca vezi ..uite-te akolo in spate scrie V12 parerea mea nu e un un 320,325
Old 09-02-06, 18:49   #8
AleXuTz
AleXuTz's Avatar
fii atent ce scrie pe e30.de
Motor: Alpina B12 5.0 mit 257KW/350PS (leicht modifiziert)
Getriebe: aus 850i/csi; 6-Gang Schaltg.
Fahrwerk: E36 Federbeine, Hinterachse komplett geändert (M-Roadster)
Bremse: Bremskraftverstärkung aus 750i (H31-Anlage), Scheiben+Sättel (V/H) vom E36 M3 3.2
Auspuff: Eigenbau mit Serienkats aus 750i
2TIMPI SI 3 MISCARI
Old 09-02-06, 19:28   #9
horguemtuning
horguemtuning's Avatar
Super bijuterie
horguemtuning is offline   Reply With Quote
Old 09-02-06, 19:33   #10
horguemtuning
Super bijuterie
Old 09-02-06, 20:41   #11
mertan
mertan's Avatar
[Crazy Drivers]
asta nu e m60?
mertan is offline   Reply With Quote
Old 10-02-06, 01:52   #12
scorpion_sd
scorpion_sd's Avatar
Default BMW
E M-70 sua varianta ca poate fii modificat la modelul de 5400cc-M-72..
Ori cum e baza de M-70 100%...
scorpion_sd is offline   Reply With Quote
Old 11-02-06, 15:30   #13
Alex-Rahova
Alex-Rahova's Avatar
pur si simplu nu inteleg cum o rezista caroseria cu asa motor. deja la un motor de 2.5 o cam iau la fuga amortizoarele oricum fara ranforsari ,cu asa motor (5000 cmc) , tre sa schimbi botul masinii odata pe luna si in pozele astea nu prea vad ranforsari,nici macar o bara intre amortizoare,nimic..
2011 Bayerische Motoren Werke AG E92
Alex-Rahova is offline   Reply With Quote
Old 11-02-06, 18:08   #14
scorpion_sd
Default BMW
::ur si simplu nu inteleg cum o rezista caroseria cu asa motor. deja la un motor de 2.5 o cam iau la fuga amortizoarele oricum fara ranforsari ,cu asa motor (5000 cmc) , tre sa schimbi botul masinii odata pe luna si in pozele astea nu prea vad ranforsari,nici macar o bara intre amortizoare,nimic.. :::
Bara nu trebui ei de desupt unde se prine motor pe tampoane e facut mai rezistent si sa spunem ca la eii drumurile sunt bine facute nare rost de bara...
Da amortizatoarele se pun KONI si prujine tari..
Old 11-02-06, 22:31   #15
F_L_R
No Speed Limit
F_L_R's Avatar
-Aceasta masina a aparut acum vre-o 5 ani pe e30.de.
-Este unicata si volumul de munca la ea este enorm.
-Acum vre-o 4 ani niste prieteni au incercat sa faca o replica a acestei masini , dar s-au oprit la pozitionarea motorului. deci un esec si mai ales din lipsa finantelor pentru un asemenea proiect.
-In schimb in 2001 eu am reusit sa scot pe strada primul 550 E34 facut in romania si acum primul serie 6 \"85 cu motor de M5 de 400 CP.
-Inafara de acele poze ale unui E30 cu V12 eu nu am mai gasit nici-un material despre acea masina.
-la 15 anisori ti-se pare ceva formidabil dar.......cata munca si cati bani inghite acest proiect nu se gandeste nimeni......550 a iesit pe strada dupa 11 Luni , serie 6 nu merge nici acum dupa 19 Luni!!!!
NO SPEED LIMIT ROMANIA
F_L_R is offline   Reply With Quote
