20-02-10, 17:06
#76
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
01-03-10, 08:22
#77
Up....
07-03-10, 14:16
#78
Up....
14-03-10, 12:32
#79
Up....
17-03-10, 08:03
#80
Nu mai sunt de actualitate(vandute) urmatoarele:
-Strung EMU 250(KART),lungime 1750mm,motor 380V/1.62Kw/1450rot/min/
2 trepte viteza/variator turatie mecanic 42 rot/min--2450rot/min,universal/rollkerner/cutite nefolosite/STARE NOUA------5000ron
Strungul este conservat(uns cu vaselina de protectie)
-Banc lucru profesional(4 sertare,4 usi,locas menghina)-650ron
-Masina gaurit de banc(380V)----------800ron
19-03-10, 10:56
#81
VAND:
-Polizor trifazic(380V) dublu PD 500-----450ron
-Dulap metalic tip fiset-----------------250ron
-Dulap metalic 2 usi--------------------400ron
-Masina gaurit cu coloana(380V)-------1400ron
-Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron
-Element filtru ulei avion(inoxidabil)---------------------------40ron
-Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
-Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron
-Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22)
-Placute Widia--------------------------------------------------5ron/buc
-Reductor presiune acetilena------------------------------------100ron
-Reductor presiune oxigen---------------------------------------100ron
-Trusa pentru sudura oxiacetilenica------------------------------350ron
-Pompa picior(1cilindru)------------------------------------------12ron
-Pompa picior(2cilindrii)-------------------------------------------22ron
-Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------120ron
-Manometru presiune0-250atm.--------------------------------------10ron
-Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
-Cutite strung widia10x10----------------------------------------5ron/buc
-Presa profesionala pivot-capete de bara((copie Draper)------------90ron
-Stativ magnetic ceas comparator--------------------------------120ron
SCULE PROFESIONALE DRAPER-ANGLIA
-Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur
-Set Biti Mecanici(Mechanics Bit Set)40 pieceStock no.21932-------49 Eur.
Total: 102 Eur.
Toate sculele sunt noi la cutie.
Legenda:
Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009
-Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--170 ron.
-Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron.
Telef.0722.121.520
26-03-10, 08:40
#82
Up....
30-03-10, 10:07
#83
Nu mai este de actualitate:
06-04-10, 09:49
#84
VAND:
Legenda:
Telef.0722.121.520
11-04-10, 08:14
#85
VAND:
Legenda:
Telef.0722.121.520
13-04-10, 19:53
#86
Up....
17-04-10, 08:10
#87
Up....
26-04-10, 20:52
#88
Up....
30-04-10, 02:36
#89
Aveti presa pentru pistonul de frana spate la golf IV? Daca aveti Va rog si pretul Locuiesc tot in Bucresti si ma pot deplasa la dumneavoastra eventual.
30-04-10, 06:38
#90
Nu am presa pentru piston frana spate Golf IV.Dar va puteti confectiona una in regie proprie.Materiale necesare placuta veche de frana,o piulita,un surub,aparat sudura arc electric.
