20-10-10, 09:22
#121
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
22-10-10, 15:28
#122
-Polizor trifazic(380V) dublu PD 500-----430ron
-Dulap metalic tip fiset-----------------230ron
-Dulap metalic 2 usi--------------------350ron
-Masina gaurit cu coloana(380V)-------1400ron
-Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit-----400ron
-Element filtru ulei avion(inoxidabil)---------------------------40ron
-Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
-Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------370ron
-Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg-----------175ron(pentru FREZA FUS22)
-Placute Widia--------------------------------------------------5ron/buc
-Reductor presiune oxigen---------------------------------------100ron
-Trusa pentru sudura oxiacetilenica------------------------------350ron
-Pompa picior(1cilindru)------------------------------------------12ron
-Pompa picior(2cilindrii)-------------------------------------------22ron
-Presostat compresor profesional(220v/10A;Pd-10bar:Pc-7bar------100ron
-Manometru presiune0-250atm.--------------------------------------10ron
-Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
-Cutite strung widia10x10----------------------------------------5ron/buc
-Stativ magnetic ceas comparator--------------------------------120ron
SCULE PROFESIONALE DRAPER-ANGLIA
-Clichet Reversibil(Reversible Ratchet)250mm1/2''Stock no.34398----53 Eur
Legenda:
Stock no.303.......reprezinta numarul index din catalogul DRAPER 2008/2009
-Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron.
-Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)-----35ron,pret nou---30ron.
Telef.0722.121.520
24-10-10, 10:05
#123
Member of: [SKODA]
Buna. M-ar interesa cat ar costa un set de prese de arc (2 prese), si un suport hidraulic de cutie de viteza.
24-10-10, 14:32
#124
Presa arcuri nu mai este de actualitate si suport hidraulic de cutie de viteza,nu am.
24-10-10, 15:13
#125
Member of: [SKODA]
poti sa aduci?
24-10-10, 19:07
#126
Nu....
30-10-10, 09:51
#127
Legenda:
Telef.0722.121.520
04-11-10, 18:45
#128
Legenda:
Telef.0722.121.520
10-11-10, 19:36
#129
Up....
22-11-10, 00:55
#130
-Trusa pentru sudura oxiacetilenica------------------------------320ron
Legenda:
Telef.0722.121.520
28-11-10, 17:36
#131
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron
Alternator Volkswagen Jetta-S.H.-----------------------------90ron
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP-----------350ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron
Placute Widia------------------------------------------------5ron/buc
Reductor presiune oxigen------------------------------------100ron
Trusa pentru sudura oxiacetilenica--------------------------350ron
Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron
Polizor trifazic(380V) dublu PD 500------------------------450ron
Dulap metalic tip fiset---------------------------------------250ron
Dulap metalic 2 usi------------------------------------------400ron
Masina gaurit cu coloana(380V)---------------------------1300ron
Cutite strung vidia--------------------------------------------------5ron/buc.
Set placute vidia(10buc/blister)(12x12)---------------------------150ron
Semeringuri FARTEC-----110x130x13--------------10ron
------80x100x13----------------------------------------8ron
------50x70x10------------------------------------------7ron
-------35x50x8--------------------------------------------5ron
--------26x42x10------------------------------------------4ron
Manometru presiune0-250atm.-------------------------------------10ron
Manometru presiune 0-60atm---------------------------------------8ron
Cutite strung 10x10--------------------------------------------------5ron/buc
Stativ magnetic ceas comparator---------------------------------100ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron
Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron
Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur
Legenda:
Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009
Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron
Telef.0722.121.520
04-12-10, 20:12
#132
Up....
09-12-10, 21:29
#133
Up....
13-12-10, 17:53
#134
Vand:
Mandrina 20/B22-fixare pe con morse-----40ron
Legenda:
Telef.0722.121.520
22-12-10, 10:08
#135
