06-03-11, 10:53
#151
re: Vand polizor dublu,masina gaurit cu coloana,electromotor U650,alternator U650,etc
Nu mai sunt de actualitate:
Biax profesional CAMPBELL HAUSFELD 25.000rot/min,0.17-6.2bar+set pietre--150 ron.
Biax MPPI-46(I.M.Bistrita)(surubelnita pneumatica)---------------------------------30 ron
12-03-11, 15:44
#152
Vand:
Electromotor Volkswagen Jetta-S.H.--------------------------90ron
Alternator Volkswagen Jetta-S.H.-----------------------------90ron
Element filtru ulei avion(inoxidabil)---------------------------40ron
Mandrina rapida precisa 0-10mm(pe filet)-------------------30ron
Mandrina 20/B22-fixare pe con morse----------------------40ron
Motor benzina ax vertical BRIGGS-STRATTON Quantum Power 3.5HP(masina tuns iarba)-----------350ron
Motor electric,,EUROMOTORI”-0,37/0,44kw;50/60hz; 360-400/435-475/210-230/250-275/Vy=1,05A/Vd=1.82A;Cos Fi 0,83/0,8;2750/3350giri/min;carcasa aluminiu;greutate 6,2Kg(pentru Fresa FUS 22)-----175ron
Placute Widia------------------------------------------------5ron/buc
Trusa pentru sudura oxiacetilenica--------------------------320ron
Rezervor(PVC)Germania 1100 L,cu armatura exterioara zinc si robinet golire,NOU nefolosit------350ron
Polizor trifazic(380V) dublu PD 500------------------------430ron
Dulap metalic tip fiset---------------------------------------200ron
Dulap metalic 2 usi------------------------------------------400ron
Masina gaurit cu coloana(380V)---------------------------1200ron
Pompa picior(1cilindru)------------------------------------------12ron
Pompa picior(2cilindrii)-------------------------------------------22ron
Cutite strung vidia--------------------------------------------------5ron/buc.
Set placute vidia(10buc/blister)(12x12)---------------------------150ron
Semeringuri FARTEC-----110x130x13--------------10ron
------80x100x13----------------------------------------8ron
------50x70x10------------------------------------------7ron
-------35x50x8--------------------------------------------5ron
--------26x42x10------------------------------------------4ron
Manometru presiune0-250atm.-------------------------------------10ron
Manometru presiune 0-60atm---------------------------------------8ron
Ceasuri comparator(precizie 0.01mm)----------------------------40ron/buc
Cutite strung 10x10--------------------------------------------------5ron/buc
Stativ magnetic ceas comparator---------------------------------100ron
Trusa alezaj 15-35mm(precizie=0.01mm)--------------------------450ron
Trusa alezaj 50-160mm(precizie=0.01mm)-------------------------470ron
Microscop centrare(pentru freze si masini gaurit prin cooordonate)--250ron
Clichet Reversibil DRAPER(Reversible Ratchet)250mm1/2''Stock no.34398-----53 Eur
Legenda:
Stock no.343.......reprezinta numarul index din catalogul DRAPER 2008/2009
13-03-11, 15:53
#153
M aintereseaza motor electric.
Deci cat are ca vad cate doua valori la orice .wataj, turatie, tensiune.
Am inteles ca ee la 220 volti.
17-03-11, 10:39
#154
Vand:
Legenda:
26-03-11, 23:24
#155
Up....
28-03-11, 23:48
#156
Poze cu masina de gaurit cu coloana si cea de banc daca le mai aveti, si mandrine, se poate? Multumesc.
Reason: gresit
29-03-11, 09:19
#157
Masina de gaurit de banc nu mai este de actualitate.In schimb aveti un link,unde regasiti foto masina gaurit cu coloana: https://forum.4tuning.ro/528-scule-ec...ml#post3365260
03-04-11, 00:33
#158
Vand:
Legenda:
19-04-11, 21:25
#159
Vand:
Polizor trifazic(380V) dublu PD 300------------------------430ron
Legenda:
26-04-11, 22:46
#160
Up....
02-05-11, 21:18
#161
Up....
06-05-11, 06:58
#162
Up....
14-05-11, 18:55
#163
Up....
20-05-11, 15:27
#164
Up....
31-05-11, 14:54
#165
