Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > BMW > Masina mea BMW Seria 5
Old 07-12-15, 14:35   #1
AxL MoDo
AxL MoDo's Avatar
Default BMW - E34 - 520i
De azi mandru posesor de E34! O masina pe care am visato mereu ! Maricica puternica silentioasa si foarte curata ! VIN spune asa :
VIN long WBAHB51040BD94096
Type code HB51
Type 520I (EUR)
Dev. series E34 ()
Line 5
Body type LIM
Steering LL
Door count 4
Engine M50
Cubical capacity 2.00
Power 110
Transmision HECK
Gearbox MECH
Colour ATLANTISBLAU (207)
Upholstery SILBERGRAU STOFF (0412)
Prod. date 1991-12-10
Order options
No. Description
210 ANTI-BLOCKIER-SYSTEM ( ABS )
302 ALARM SYSTEM
314 HEATED WINDSCREEN WASHER NOZZLES
320 MODEL DESIGNATION, DELETION
428 WARNING TRIANGLE
488 LUMBAR SUPPORT DRIVER/FRONT PASSENGER
489 LUMBAR SUPPORT FOR FRONT PASSENGER
510 HEADLIGHT BEAM-THROW CONTR. F LOW BEAM
529 MICRO FILTER
571 BOOSTED POWER SUPPLY
653 BMW BAVARIA C REVERSE II
690 CASSETTE HOLDER
801 GERMANY VERSION
Nu stiu cat de dotata sau nedotata este masina, pentru mine are strictul necesar cu timpul or sa vina mai multe ! Saptamana asta o sa caut sa o bag pe numele meu si apoi incep sa rectific una alta la ea ! Ca defecte are vopseaua umflata pe aripa dreapta (vopseaua originala din fabrica....), plafonul trebuie inlocuit si o rezistenta la aeroterma (merge doar pe pozitia 4 !
Name:	DECEMBRIE 2015 (2).jpg
ID:	3132556 Click image for larger version
Name:	DECEMBRIE 2015 (3).jpg
Name:	DECEMBRIE 2015 (4).jpg
ID:	3132558 Click image for larger version
Name:	DECEMBRIE 2015 (6).jpg
E36 Cabrio - Mein Kater
BMW - E34 - 520i
Sunt pe un forum auto,nu intr-un examen la scoala, d'aia am greseli gramaticale!
"In viata derapezi / Mai repede decat crezi
Pe strada, in parcuri sau canale / Vezi destule dovezi"
AxL MoDo is offline   Reply With Quote
Old 08-12-15, 11:36   #2
Logan4ever
Logan4ever's Avatar
Default Re: BMW - E34 - 520i
Sa ai noroc la el! Arata bine. Dar proiectul cu E36 l-ai abandonat?
Logan4ever is offline   Reply With Quote
Old 08-12-15, 11:50   #3
AxL MoDo
AxL MoDo's Avatar
Nu qm abandonat pisoiul doar ca a stationat si o sa mai stationeze pana dupa sarbatori ! In curand o sa ma apuc si de acela ! Am luato pe asta pentru ca aveam nevoie de o masina cu care sa ma deplasez si evident o masina de "familie"
Old 11-12-15, 16:56   #4
AxL MoDo
AxL MoDo's Avatar
Am bagat masina la fiscal urmeaza sa strang toate documentele de care am nevoie si sa trec pe numele meu masina sa i facem buletin de sector 6 cu numere noi ! Intre timp simteam nevoia unei telecomenzi asa ca mi-am luat modul inchidere centralizata cu cheie tip romb (BMW) ma irita ca nu are sigla BMW pe telecomanda insa sper sa gasesc sticker-ul acesta pe ebay (am vazut ca sunt stickere pentru bord pentru jante cu ///M sper sa fie si cu sigla BMW pentru chei ! Si am o mica intrebare daca cineva stie cum as putea face si deschiderea portbagajului din buton ! Am vazut pe net ceva E34 ce avea deschiderea portbagajului din buton ! Modulul a fost 80 de lei si mi-am mai comandat 2 capsule cu led pentru numarul de inmatriculare care au fost 15 lei !
-Stie cineva daca acest modul se leaga direct la inchiderea centralizata ?
-Cat costa si unde as putea sa fac cheile blanc ? La cineva priceput ca nu vreau sa strice lamele aiurea !
Old 11-12-15, 17:04   #5
Logan4ever
Logan4ever's Avatar
Sigla bmw pentru cheie gasesti la magazine de piese auto, e īn jur de 3 lei, sau pe okazii. Eu am primit sigla gratis cand am luat acelasi tip de īnchidere centralizata de la un magazin de piese auto.
Iar legat de lama, mie īn Satu Mare mi-au cerut 40 de lei pentru copiat, bănuiesc ca tot cam atat ar costa si īn București.
Si pentru portbagaj, electricianul care mi-a montat mie modulul, mi-a spus ca am nevoie de un actuator separat, la fel și pentru ridicarea geamurilor din telecomanda.
BMW -Sheer Driving Pleasure
BMW E36 Coupe - 316i
Old 11-12-15, 20:45   #6
AxL MoDo
AxL MoDo's Avatar
Intre timp am gasit si unde sa copiez cheile (facebook: multiplicari chei cu cip) baietii sunt din bucuresti am vorbit cu ei la telefon le-am trimis poze pe whatsapp cu modelul de cheie si mi-au raspuns ca 2 exemplare 80 de lei ! Ca e mult sau putin nu conteaza atat timp cat am in total 3 chei pentru masina !
Intre timp astept cuminte si am dat de acest videoclip pe youtube Numai ca am probleme cu doamna engleza si nu inteleg ce vorbeste strainul asta acolo ! Mi se pare ca explica cum a legatmodulul la inchiderea originala si nu imi dau seama cum....a trebuie sa adapteze ceva sau a fost plug and play... Ce mi-am cumparat eu are ca functii:
1. Armare
2. Dezarmare
3. Deschidere porbagaj ( unde este posibil)
4. Cautare in parcare mod luminos
5. Armare automata
6. Indicator led
7. Ridicare automata a geamurilor ( unde este posibil)
Pachetul contine:
1. 2 telecomenzi cu lamela
2. Modul adaptare la inchidere centralizata
3. Cablaj
Mi-ar placea sa fie toate functionale un actuator am eu daca nu ma insel o sa vad cum pot sa il leg...functia ridicarii geamurilor (pe fata, ca pe spate am manual) cred ca se leaga la butoane ori la modulul de confort (daca tin cheia intoarsa pe "inchis" se ridica geamurile ! Cautare in parcare mod luminos nu inteleg la ce se refera (ma gandesc ca ar fi ceva gen fallow me home..Mi-ar placea sa am o schema detaliata a modulelor de pe masina ca sa pot sa leg inchiderea complet.. Ma poate ajuta cineva cu ori ce ? informatie...scheme....nu sunt batut in cap stiu nitica electrica...
Old 12-12-15, 20:55   #7
Logan4ever
Logan4ever's Avatar
Se refera la faptul ca daca masina e incuiata si apesi inca o data pe butonul lock se aprind luminile de avarie de 3 ori. Nu e cine stie ce )
Old 17-12-15, 14:09   #8
hashu_1985
hashu_1985's Avatar
mi-am pus eu modulul ala...l-am comandat de pe net si mi-a venit si cu siglele de bmw. 85 de lei am dat pe el, se monteaza foarte usor.Eu nu i-am legat si ridicarea geamurilor fiindca nu le-am avut originale cu modul pe masina, geamurile electrice le-am montat ulterior.
hashu_1985 is offline   Reply With Quote
Old 04-01-16, 21:28   #9
AxL MoDo
AxL MoDo's Avatar
Saptamana asta programare la RAR ! Si asa o poza mica de sezon !
Old 15-01-16, 21:23   #10
AxL MoDo
AxL MoDo's Avatar
Salutare oameni buni ! Am si eu o mica problema la care nu i dau de cap ! OBC-ul din masinanu afiseaza nimic am crezut ca becurile sunt arse insa le-am schimbat pe toate odata noi se aprind butoanele insa pe display nu arata nimic ! Inainte vedeam niste cifre ceva care stateau slab iluminat si fix dar dupa ce am schimbat becurile nimic....as putea remedia problema sau trebuie inlocuit ?
Old 16-01-16, 10:07   #11
ILo6GEP
Salut, sa l stăpānești sănătos, după cāte văd masina arata bine. Și eu am una dar e vanos tot 2.0 te pot ajuta cu obc ul sa vedem ce problema ai, eu am pățit sa se ardă becurile și nu se vedea nimic. Acum am un obc 4 pentru al meu īl putem proba sa vedem dacă ți merge. Īți las nr de tel 0737938620
ILo6GEP is offline   Reply With Quote
Old 23-01-16, 12:37   #12
shox
shox's Avatar
Apreciez munca care o faci pentru e36 dar parerea mea e sa o tragi pe dreapta si sa te concentrezi pe aceasta masina.
Chiar merita atentie
Arata foarte bine si pare destul de ingrijita .
Sa o stapanesti sanatos.
Route 66
shox is offline   Reply With Quote
Old 01-02-16, 21:31   #13
AxL MoDo
AxL MoDo's Avatar
Momentan pe aceasta ma si concentrez ! Ma pregatesc de schimbul de ulei si filtre trebuie sa schimb discurile pe fata si placutele si abea apoi ma pregatesc de spoiala ! Am nevoie de ajutorul vostru ! Nu vreau sa mai schimb culoarea in talon si totusi vreau sa fac masina un albastru atat de inchis incat sa dea catre negru aveti ceva idei ?
Old 02-02-16, 20:37   #14
Tis-ul
Tis-ul's Avatar
Atat timp cat arata macar putin a albastru, nu au ce comenta.
Tis-ul is offline   Reply With Quote
Old 06-02-16, 20:29   #15
shox
shox's Avatar
Daca ai albastru simplu in talon te poti duce cu nuanta de albastru pana aproape de negru si nu ar fi probleme.
Bafta.
