am de vanzare o statie Pioneer 200w - GM-x362
"Features
PWM Regulated MOSFET Power Supply
Bridgeable 1/2/3 Channel Capability
Balanced Isolator Input Circuit
Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs
Hi-Volt Input Level Control (400mV-6.5V)
Speaker Level Inputs
Selectable Crossover: 80Hz, -12dB/oct. (LPF)
Specifications
Continuous Power (14.4V): 40Wx2(4 ohm), 50Wx2 (2 ohm), 100Wx1 (4 ohm)
Max Power (14.4V): 80Wx2 (4 ohm), 200Wx1 (4 ohm)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 6-3/16" "
+ sub ROADMASTER nu stiu putere are
, dimensiuni L= 40 cm Diametru 20 cm
ambele sunt in perfecta stare de functionare. abia scoase dupa masina.
pentru alte detalii intrebati.
pret : 300 ron
tel: 0743458902 ym: boggy_03
