[vand] statie si subwoofer ieftin si bun...
am de vanzare o statie Pioneer 200w - GM-x362
"Features PWM Regulated MOSFET Power Supply Bridgeable 1/2/3 Channel Capability Balanced Isolator Input Circuit Screw-Type Power/Ground Terminals Screw-Type Speaker Terminals RCA Inputs Hi-Volt Input Level Control (400mV-6.5V) Speaker Level Inputs Selectable Crossover: 80Hz, -12dB/oct. (LPF) Specifications Continuous Power (14.4V): 40Wx2(4 ohm), 50Wx2 (2 ohm), 100Wx1 (4 ohm) Max Power (14.4V): 80Wx2 (4 ohm), 200Wx1 (4 ohm) Frequency Response: 10Hz - 50kHz (0,-1dB) Total Harmonic Distortion: 0.008% (1kHz, 4W) Signal-to-Noise Ratio: 100dB (IHF-A) Dimensions: 11" x 2-5/16" x 6-3/16" " + sub ROADMASTER nu stiu putere are :sad:, dimensiuni L= 40 cm Diametru 20 cm ambele sunt in perfecta stare de functionare. abia scoase dupa masina. pentru alte detalii intrebati. pret : 300 ron tel: 0743458902 ym: boggy_03 |
Re: [vand] statie si subwoofer ieftin si bun...
un nokia 7210 supernova ?
daca erai din bucuresti...poate.
Un telefon O2 Ice, te interesează?...
http://www.emobil.ro/telefoane_mobile/o2_ice.html |
nu, mersi !
se poate inchide s-au vandut ! |
