vand o pereche de midbassi (noi doar testati) si o pereche de tweetere (au fost la mine in masina pana vineri), marca Auditor RIP 165S by Focal, estetic si functional foarte bune, se vand cu grile nu am crossoverele le am folosit activ din player,
specificatii mai jos se trimit prin ce doreste cumparatorul
pret 165ron usor negociabil
Nominal power 60W
Maximum power 200W
Sensitivity (2.83V/m) 92dB
Cone Polypropylene
Surround Rubber
Nom. impedance 4 Ohms
DC resistance 3.4 Ohms
VC diameter 25.5mm 1"
VC height
Former Kapton
Layers 2
Wire Copper
Inductance 0.21
Xmax
Magnet 86x15mm 3 3/8 x 9/16"
Magnet weight
Flux density
Gap height
Net weight
Fs 64.77Hz
Vas 11.21 litres
Qts 0.94
Qes 1.08
Qms 7.50
Re 3.4 Ohms
Sd 141.03cm2
Cas 7.98E -0.8m5/N
Mas 75.67kg/m4
Ras
Cms 401µm/N
Mms 15.05g
Rms 0.817kg/s
Ces 762.59mF
Les 7.92mH
Res 24.17 Ohms
BI 4.45 N/A
SPL 86.3dB
Woofer
1" (25.5mm) voice coil on Kapton former
Dual layer voice coil
Phase plug
Polypropylene cone
High rigidity metal basket
Rain cover integrated in basket
Tweeter
Neodynium magnet with ferrofluid
Flush and surface mounting accessories
Crossover
12 dB/octave highpass crossover
