Difuzoare midbassi si tweetere Auditor RIP 165 S by Focal!!!
6 Attachment(s)
vand o pereche de midbassi (noi doar testati) si o pereche de tweetere (au fost la mine in masina pana vineri), marca Auditor RIP 165S by Focal, estetic si functional foarte bune, se vand cu grile nu am crossoverele le am folosit activ din player,
specificatii mai jos se trimit prin ce doreste cumparatorul pret 165ron usor negociabil Nominal power 60W Maximum power 200W Sensitivity (2.83V/m) 92dB Cone Polypropylene Surround Rubber Nom. impedance 4 Ohms DC resistance 3.4 Ohms VC diameter 25.5mm 1" VC height Former Kapton Layers 2 Wire Copper Inductance 0.21 Xmax Magnet 86x15mm 3 3/8 x 9/16" Magnet weight Flux density Gap height Net weight Fs 64.77Hz Vas 11.21 litres Qts 0.94 Qes 1.08 Qms 7.50 Re 3.4 Ohms Sd 141.03cm2 Cas 7.98E -0.8m5/N Mas 75.67kg/m4 Ras Cms 401µm/N Mms 15.05g Rms 0.817kg/s Ces 762.59mF Les 7.92mH Res 24.17 Ohms BI 4.45 N/A SPL 86.3dB Woofer 1" (25.5mm) voice coil on Kapton former Dual layer voice coil Phase plug Polypropylene cone High rigidity metal basket Rain cover integrated in basket Tweeter 1" (25.5mm) voice coil Neodynium magnet with ferrofluid Flush and surface mounting accessories Crossover 12 dB/octave highpass crossover |
Re: Difuzoare midbassi si tweetere Auditor RIP 165 S by Focal!!!
rezervate!!!
vandute, auditie placuta, multumesc 4 tuning :-)
Boxele au ajuns la mine. L-am testat se aud foarte bine, fix ce aveam nevoie.
Super de treaba ady, totul a decurs foarte bine in legatura cu tranzactia. |
multumesc sa le asculti cu placere, tinem legatura! :-)
