Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Amplificatoare auto & stuff
Amplificatoare auto & stuff Amplificatoare Auto, Statii, Cabluri, Condensatoare, Baterii Deep Cycle, audio
Old 03-01-16, 15:29   #1
heyyoupf
Default Vand amplificator Ground Zero GZPA Reference 4
Vand amplificator Ground Zero Reference 4 optic 9.5/10, tehnic impecabil 10/10, nedesfacut etc, plexic 10/10.
Este unul dintre amplificatoarele cu cel mai bun sunet ascultate de mine, un motiv fiind poate si biasul
reglabil care duce acest amplificator in stare de functionare aproape de clasa A pura si componentele pasive
si active fiind componente de top in clasa Hi-end.(Mundorf, Sanken, etc..).Poze Reale!
Datele amplificatorului:
Type4 Ch Class AB > A
Output Power @ 4 Ohm (CEA*)4 x 150 W
Output Power @ 2 Ohm (CEA*)4 x 270 W
Output Power @ 1 Ohm (CEA*)4 x 425 W
Bridge mode @ 4 Ohm (CEA* / 10% THD)2 x 650 W
Bridge mode @ 2 Ohm (CEA* / 10% THD)2 x 1000 W
Output power linkmode 2 Ohm-
24 Volt Unit-
18 Volt stable-
Lowpass40 - 3000 Hz
Highpass40 - 3000 Hz
Bandpass40 - 3000 Hz
Subsonic-
Bassboost-
Phaseshift-
Adjustable Q-factor-
Variable Bias SettingJa / Yes
Bass remote-
High Level in-
Line Out-
IlluminationWeiße LED Innenbeleuchtung / white LED illumination
Dimensions cm / Inch59 x 6,75 x 23,6 cm / 23.23“ x 2.66“ x 9.29“
Mai mult decat tot ce am scris, acest amplificator are si un look cu adevarat de top.Este foarte serios facut, ingrijit.
https://www.youtube.com/watch?v=XbI3f8TP1F0
Pret: 1000 eur Fix
Tel:0749.131.077
Fb:Sq Tinu
ID:	3136831   Click image for larger version
ID:	3136832   Click image for larger version
ID:	3136834   Click image for larger version
ID:	3136835   Click image for larger version
heyyoupf is offline   Reply With Quote
