Vand amplificator Ground Zero GZPA Reference 4
6 Attachment(s)
Vand amplificator Ground Zero Reference 4 optic 9.5/10, tehnic impecabil 10/10, nedesfacut etc, plexic 10/10.
Este unul dintre amplificatoarele cu cel mai bun sunet ascultate de mine, un motiv fiind poate si biasul reglabil care duce acest amplificator in stare de functionare aproape de clasa A pura si componentele pasive si active fiind componente de top in clasa Hi-end.(Mundorf, Sanken, etc..).Poze Reale! Datele amplificatorului: Type4 Ch Class AB > A Output Power @ 4 Ohm (CEA*)4 x 150 W Output Power @ 2 Ohm (CEA*)4 x 270 W Output Power @ 1 Ohm (CEA*)4 x 425 W Bridge mode @ 4 Ohm (CEA* / 10% THD)2 x 650 W Bridge mode @ 2 Ohm (CEA* / 10% THD)2 x 1000 W Output power linkmode 2 Ohm- 24 Volt Unit- 18 Volt stable- Lowpass40 - 3000 Hz Highpass40 - 3000 Hz Bandpass40 - 3000 Hz Subsonic- Bassboost- Phaseshift- Adjustable Q-factor- Variable Bias SettingJa / Yes Bass remote- High Level in- Line Out- IlluminationWeiße LED Innenbeleuchtung / white LED illumination Dimensions cm / Inch59 x 6,75 x 23,6 cm / 23.23“ x 2.66“ x 9.29“ Mai mult decat tot ce am scris, acest amplificator are si un look cu adevarat de top.Este foarte serios facut, ingrijit. https://www.youtube.com/watch?v=XbI3f8TP1F0 Pret: 1000 eur Fix Tel:0749.131.077 Fb:Sq Tinu |
| All times are GMT +2. The time now is 21:51. |
