Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Instalari diverse
Old 21-03-08, 21:40   #1
V.Roberto
V.Roberto's Avatar
Default Lucrarile mele
De cand ma stiu mia placut electronica si in special sistemele audio mai precis tot ce scoate sunet asa ca am inceput sa fac incinte atat pt masina cat si home,o sa va arat cateva poze pt inceput cateva auto si home sper sa va placa ,in primele poze este o incinta care a castigat trei cupe la db drag (145.4 db)intrun 307 sw,si un set home de 8 ohmi
ID:	490994   Click image for larger version
ID:	490995   Click image for larger version
ID:	490997   Click image for larger version
ID:	490998   Click image for larger version
ID:	491000   Click image for larger version
ID:	491001   Click image for larger version
ID:	491005   Click image for larger version
ID:	491018   Click image for larger version
ID:	491020   Click image for larger version
V.Roberto is offline   Reply With Quote
Old 22-03-08, 19:34   #2
Rafaila
Rafaila's Avatar
Default Re: Lucrarile mele
Frumoase cuti .....si lucrate angrijit , ami plac lucrarile tale,felicitari si.....sa mai vedem vrem!!
Rafaila is offline   Reply With Quote
Old 23-03-08, 11:43   #3
V.Roberto
V.Roberto's Avatar
daca mai vreti va arat alte doua si daca va plac mai pun tot cate doua,o completare ,un sistem de 5.1 ,si buburuzele de la firma la care am lucrat
ID:	492344   Click image for larger version
ID:	492345   Click image for larger version
ID:	492347   Click image for larger version
ID:	492348   Click image for larger version
ID:	492350   Click image for larger version
ID:	492351   Click image for larger version
ID:	492353   Click image for larger version
ID:	492365   Click image for larger version
ID:	492367   Click image for larger version
ID:	492368   Click image for larger version
ID:	492370   Click image for larger version
ID:	492371   Click image for larger version
Old 23-03-08, 12:02   #4
Lil' D
Lil' D's Avatar
Arata bine toate, dar ce nu inteleg eu e chestia ce ai pus-o in porturi.
Daca ai vrut sa simulezi ceva gen "horn"...acele dimensiuni sunt mult prea mici pentru a face ceva util (poate pentru inalte ar face ceva diferenta, dar in cazul bass-ului vorbim de lungimi de unda mult mult mai mari).
Singurul lucru la care par sa ajute e sa limiteze mult dimensiunea portului si sa dea peste cap calculele.
Team SQNLL
Old 23-03-08, 16:17   #5
V.Roberto
V.Roberto's Avatar
Chestia ce am pus in porturi era o chestie bine gandita si nu numai desing ,este o inventie de la Hertz cum functioneaza exact am citit dintrun prospect Hertz dar numai tin minte toate detaliile dar a ajutat la obtinerea unui rezultat destul de bun de peste 145db ,si ca sa nu plec fara poze ....o incinta de pal pt doua difuri de 250 w rms(matiz)
ID:	492602   Click image for larger version
ID:	492603   Click image for larger version
ID:	492605   Click image for larger version
ID:	492606   Click image for larger version
ID:	492608   Click image for larger version
ID:	492609   Click image for larger version
Old 23-03-08, 16:19   #6
Ingerasul99
Ingerasul99's Avatar
ai talent, spor la munca in continuare si cat mai multe lucrari frumoase ca cele de pana acum
Ingerasul99 is offline   Reply With Quote
Old 23-03-08, 17:15   #7
margineanu ovidiu
margineanu ovidiu's Avatar
nu ma pricep bine la cutii dar am ascultat si concurat contra masinii respective si mi-a dat emotii,pe termlab a dat 144,2 si daca nu ma insel era undeva la 47hz,oricum sunau difuzoarele alea in cutia aia de nu mi-a venit sa cred ca sunt mnc
TEAM SQNLL
DIY Mobile Audio
7ch active,audison&soundstream&u dimension
scanspeak D2904/7100,15M ,21W/8554-00,jl12w7,d511r,h701,400bt,2xhollywood spv20,2xspv45
margineanu ovidiu is offline   Reply With Quote
Old 23-03-08, 17:26   #8
Lil' D
Lil' D's Avatar
Sunt foarte sceptic (ca de obicei). Posteaza informatia, scepticismul meu nu inseamna ca sunt inchis....s-ar putea sa ma luminez cu ceva
In momentul in care pui chestia aceea in port tu modifici mult suprafata acestuia, dand peste cap toate calculele si practic modificand frecventa de acordaj.
E pentru prima data cand vad asa ceva si, sincer sa fiu, in toate pozele cu sisteme pentru dbdrag nu am vazut nici un port facut in acel fel.
Ce ma face pe mine sa nu cred in utilitatea acelei chestii e dimensiunea infima comparata cu lungimea de unda a unui ton sub 80hz.
Pentru a avea comportament de "horn" ai nevoie de dimensiuni foarte mari. M-as indoi ca un RLH corect, pentru un singur difuzor, ar incapea in spatiul acela. Si sa nu vorbim de design-urile team toxic bass, care le-as spune praf in ochi.
Old 24-03-08, 19:09   #9
V.Roberto
V.Roberto's Avatar
Eu nu vreau sa te conving despre nimic,daca nu te convinge rezultatul...,de si cutia nu a fost facuta pt db drag ,lam facut ca sa avem ceva din produsele noastre la o expozitie in 2006 ,masina a concurat cu bateria originala de 75ah,cu cablaj de 2awg masina stock fara nici o pregatire dbdrag(nimic izolat,plafonul masini din sticla,etc)eu zic ca a scos bine si inca ceva masina a concurat cu o melodie de sub test care descarca repede bateria ne stiind la ce frecventa lucreaza ,si ca sa nu va las fara poze o masinuta pregatita pt un expo tot in 2006
ID:	494211   Click image for larger version
ID:	494212   Click image for larger version
ID:	494214   Click image for larger version
Old 24-03-08, 21:24   #10
Ingerasul99
cu ce faci gaurile rotunde ?
Old 24-03-08, 22:22   #11
V.Roberto
V.Roberto's Avatar
pe poza nr trei se vad sculele decupirul si raspila...si cateva cutii sealed de 28 l
ID:	494394   Click image for larger version
ID:	494395   Click image for larger version
Old 24-03-08, 22:22   #12
Lil' D
Lil' D's Avatar
Medii si tweetere in subwoofer ? Nu stiati la ce frecv lucreaza ?
M-am cam convins...
Se pare ca tu esti ferm convins ca acea minune a ajutat la acel rezultat...
Tot respectul pentru munca. Si cam atat.
Old 24-03-08, 22:33   #13
V.Roberto
V.Roberto's Avatar
daca stii ce inseamna cuvantul expo nu pui intrebari prostesti sistemul nu a fost alimentat deoarece era doar EXPOZITIE si proprietarul nu nea lasat sa dam gauri in masina deoareca valora mai mult de 100 mi de euroi,si la cealalta intrebare da nu am stiut la ce frecventa lucreaza fiindca era gata inainte de show cu cateva zile si nu am avut timp de masurari ,dar am mai scris ca nu a fost facut pt DB DRAG!!!!si cam atat
Old 24-03-08, 22:50   #14
AT5000.1
tot respectul pentru munca depusa
AT5000.1 is offline   Reply With Quote
Old 25-03-08, 11:38   #15
raptor_123456789
felicitari pentru incinte , dar in privinta portului de la incintele hertz , nu e nici mai mult nici mai putin decat.... doua porturi flared.
raptor_123456789 is offline   Reply With Quote
