Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Electrice si Electronica
Old 29-08-14, 06:55   #1
b47bez
b47bez's Avatar
Default INTERFATA DIAGNOZA HH OBD MINI Version Fault Codes Bluetooth Advanced OBD Scan
Functions:
- Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
- Clear trouble codes and turn off the MIL ("Check Engine" light).
- Display current sensor data, including:
- Engine RPM
- Calculated Load Value
- Coolant Temperature
- Fuel System Status
- Vehicle Speed
- Short Term Fuel Trim
- Long Term Fuel Trim
- Intake Manifold Pressure
- Timing Advance
- Intake Air Temperature
- Air Flow Rate
- Absolute Throttle Position
- Oxygen sensor voltages/associated short term fuel trims
- Fuel System status
- Fuel Pressure
Supported Software:
- Torque(Can be downloaded from Android Market)
- Scantool_net113win (Full Version)
- EasyOBDII V2.2 (Full Version)
- OBD2Spy (Demo Version)
- ScanMaster-ELM (Demo Version)
- wOBDCRAZY (Demo Version)
Multi-Protocol Support:
- SAE J1850 PWM (41.6 kbaud)
- SAE J1850 VPW (10.4 kbaud)
- ISO 9141-2 (5 baud init, 10.4 kbaud)
- ISO 14230-4 KWP (5 baud init, 10.4 kbaud)
- ISO 14230-4 KWP (fast init, 10.4 kbaud)
- ISO 15765-4 CAN (11 bit ID, 500 kbaud)
- ISO 15765-4 CAN (29 bit ID, 500 kbaud)
- ISO 15765-4 CAN (11 bit ID, 250 kbaud)
- ISO 15765-4 CAN (29 bit ID, 250 kbaud)
Available cars:
- All vehicles after 1996 in US. OBD2 compliant cars in other countries
- Color: Black
- Dimensions (cm): 7x4.5x2.5
- Weight (kg): 0.06
Package includes:
1x HH OBD Bluetooth Scanner
PRET 55RON
TEL.0764735494
BUCURESTI
TRIMIT IN TARA POSTA SAU CURIER
PRET FIX,NU FAC SCHIMBURI
TESTAT PE LOGAN SI OPEL
ID:	3022751   Click image for larger version
ID:	3022752   Click image for larger version
my ford
b47bez is offline   Reply With Quote
