INTERFATA DIAGNOZA HH OBD MINI Version Fault Codes Bluetooth Advanced OBD Scan
Functions:
- Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database). - Clear trouble codes and turn off the MIL ("Check Engine" light). - Display current sensor data, including: - Engine RPM - Calculated Load Value - Coolant Temperature - Fuel System Status - Vehicle Speed - Short Term Fuel Trim - Long Term Fuel Trim - Intake Manifold Pressure - Timing Advance - Intake Air Temperature - Air Flow Rate - Absolute Throttle Position - Oxygen sensor voltages/associated short term fuel trims - Fuel System status - Fuel Pressure Supported Software: - Torque(Can be downloaded from Android Market) - Scantool_net113win (Full Version) - EasyOBDII V2.2 (Full Version) - OBD2Spy (Demo Version) - ScanMaster-ELM (Demo Version) - wOBDCRAZY (Demo Version) Multi-Protocol Support: - SAE J1850 PWM (41.6 kbaud) - SAE J1850 VPW (10.4 kbaud) - ISO 9141-2 (5 baud init, 10.4 kbaud) - ISO 14230-4 KWP (5 baud init, 10.4 kbaud) - ISO 14230-4 KWP (fast init, 10.4 kbaud) - ISO 15765-4 CAN (11 bit ID, 500 kbaud) - ISO 15765-4 CAN (29 bit ID, 500 kbaud) - ISO 15765-4 CAN (11 bit ID, 250 kbaud) - ISO 15765-4 CAN (29 bit ID, 250 kbaud) Available cars: - All vehicles after 1996 in US. OBD2 compliant cars in other countries - Color: Black - Dimensions (cm): 7x4.5x2.5 - Weight (kg): 0.06 Package includes: 1x HH OBD Bluetooth Scanner PRET 55RON TEL.0764735494 BUCURESTI TRIMIT IN TARA POSTA SAU CURIER PRET FIX,NU FAC SCHIMBURI TESTAT PE LOGAN SI OPEL |
| All times are GMT +2. The time now is 07:10. |
