Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 23-04-13, 10:49   #1
elspa
elspa's Avatar
Default FJO Progressive Nitrous Mini-Controller
Face cam tot ce vreti pentru un kit de nos: 2 stage TPS, window switch, 2 canale, etc.
Features
2 independent channels
Programmable ramp times (0.1 - 10.0 sec)
Programmable delay times (0.1 - 10.0 sec)
RPM or Time based linear ramp or multi-point curve
Integrated wide-open-throttle detection
1st gear lock-out
Works with rising or falling TPS signals
Supports low voltage tach signals as low as 3 volts
Works with irregular tach signals such as V10 and 3cyl
Easy to use graphic set-up menus using PC USB
Inputs for manual enable/disable or transmission brake, throttle position, tach signal
Integrated LEDs for WOT, stage 1 RPM window, stage 2 RPM window
High current solenoid driver with 40 amp load capacity (continuous duty)
pret 900 lei negociabil
http://www.fjoracing.com/products/2stageminicontroller/
0722 340 642
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
