-   Turbine & Blow Off (https://forum.4tuning.ro/465-turbine-and-blow-off.html)
-   -   FJO Progressive Nitrous Mini-Controller (https://forum.4tuning.ro/465-turbine-and-blow-off/371863-fjo-progressive-nitrous-mini-controller.html)
elspa 23-04-13 10:49
Face cam tot ce vreti pentru un kit de nos: 2 stage TPS, window switch, 2 canale, etc.
Features
2 independent channels
Programmable ramp times (0.1 - 10.0 sec)
Programmable delay times (0.1 - 10.0 sec)
RPM or Time based linear ramp or multi-point curve
Integrated wide-open-throttle detection
1st gear lock-out
Works with rising or falling TPS signals
Supports low voltage tach signals as low as 3 volts
Works with irregular tach signals such as V10 and 3cyl
Easy to use graphic set-up menus using PC USB
Inputs for manual enable/disable or transmission brake, throttle position, tach signal
Integrated LEDs for WOT, stage 1 RPM window, stage 2 RPM window
High current solenoid driver with 40 amp load capacity (continuous duty)
pret 900 lei negociabil
http://www.fjoracing.com/products/2stageminicontroller/
0722 340 642
