Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Tobe, Esapamente, Tevi, Intercoolere
Old 22-07-08, 10:19   #1
elspa
elspa's Avatar
Default Kituri intercooler + tevi + silicoane + boost controller - super pret
(1) Front Mount Intercooler:
Brand new unit with 2 mounting tabs welded on
Large design cools down the turbocharged air efficiently
Lightweight aluminum racing intercooler
Brackets create a easy bolt on design
Strong TIG welds will support high PSI levels
2.5" cold outlet & 2.5" hot inlet
Less then 2% pressure drop
27”x 6.5” x 3.5” thick unit design
(1)Universal Intercooler Piping Kit:
Lightweight aluminum piping
Might require modification to fit
(2) straight 2.5” pipes”
(6) 90 degree 2.5“ J bends
(4) 90 degree 2.5” tight bends
(24) stainless steel high strength worm gear clamps
( 2.5” straight silicone couplers
(4) 2.5” 90 degree silicone couplers
(1) Boost Controller:
Control your boost with a precise click
Can be adjusted for any PSI level desired
Can be setup to adjust boost PSI on the fly
CNC machined design
Anodized BLACK aluminum finish
Includes complete install kit
dimensiuni intercooler:
69x17x8.8 cm
vine cu absolut tot ce e in poza
pret 990 ron
0722 340 642
ym: mihai_spanachi
www.srz.ro
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 13-08-08, 08:45   #2
elspa
elspa's Avatar
Default Re: Kituri intercooler + tevi + silicoane + boost controller - super pret
up......
Old 26-09-08, 08:26   #3
Catalin_BMW
este pretul final, ca sa'l am la usa da ?
da'mi un PM te rog cu detalii de plata si durata de livrare (reala), sunt interesat.
Merci
Catalin_BMW is offline   Reply With Quote
Old 26-09-08, 14:22   #4
elspa
elspa's Avatar
sal, nu mai e valabil anuntu lasta, a fost o promotie.
kituri de intercoolere disponibile acum le gasesti aici:
http://www.srz.ro/pagini/Kituri%20in...20complete.htm
transportul prin curier rapid pana la usa ta e cam 30-50 ron inclusiv ramburs.
Old 26-09-08, 16:18   #5
Catalin_BMW
...daca mai apar pe viitor astfel de promotii te rog sa ma anunti
...nu sunt interesat de celelalte oferte.
