Kituri intercooler + tevi + silicoane + boost controller - super pret
(1) Front Mount Intercooler:
Brand new unit with 2 mounting tabs welded on Large design cools down the turbocharged air efficiently Lightweight aluminum racing intercooler Brackets create a easy bolt on design Strong TIG welds will support high PSI levels 2.5" cold outlet & 2.5" hot inlet Less then 2% pressure drop 27x 6.5 x 3.5 thick unit design (1)Universal Intercooler Piping Kit: Lightweight aluminum piping Might require modification to fit (2) straight 2.5 pipes (6) 90 degree 2.5 J bends (4) 90 degree 2.5 tight bends (24) stainless steel high strength worm gear clamps (8) 2.5 straight silicone couplers (4) 2.5 90 degree silicone couplers (1) Boost Controller: Control your boost with a precise click Can be adjusted for any PSI level desired Can be setup to adjust boost PSI on the fly CNC machined design Anodized BLACK aluminum finish Includes complete install kit dimensiuni intercooler: 69x17x8.8 cm vine cu absolut tot ce e in poza pret 990 ron 0722 340 642 ym: mihai_spanachi www.srz.ro |
Re: Kituri intercooler + tevi + silicoane + boost controller - super pret
up......
este pretul final, ca sa'l am la usa da ?
da'mi un PM te rog cu detalii de plata si durata de livrare (reala), sunt interesat. Merci |
sal, nu mai e valabil anuntu lasta, a fost o promotie.
kituri de intercoolere disponibile acum le gasesti aici: http://www.srz.ro/pagini/Kituri%20in...20complete.htm transportul prin curier rapid pana la usa ta e cam 30-50 ron inclusiv ramburs. |
...daca mai apar pe viitor astfel de promotii te rog sa ma anunti :D
...nu sunt interesat de celelalte oferte. |
| All times are GMT +2. The time now is 05:43. |
