Old 07-07-11, 21:27   #1
gigilogan
gigilogan's Avatar
Default pareri Hertz EP4
as vrea cumpar ampliful Hertz EP4 dar m-ar interesa niste pareri despre ea.
Specificatii tehnice pentru Hertz EP4
Output Power (RMS):
60W x 4 @4-ohm
95W x 4 @2-ohm
3 channel mode:
60W x 2 (4ohm) + 190W x 1 (4ohm)
95W x 2 (4ohm) + 190W x 1 (4ohm)
190W x 2 (4ohm)
Filters & Controls:
A Channels: Full / Hi-pass / Lo-pass: 40 - 400Hz @12dB/Oct
B Channels: Full / Hi-pass / Lo-pass: 40 - 400Hz @12dB/Oct
C Channels: Bass Boost: 0-12dB @45Hz
T.H.D. (100Hz @4-ohm): 0.08%
Bandwith (-3 dB): 7 - 60Hz
S/N Ratio (A weighted @1V): 98dBA
Damping Factor (100Hz @4-ohm) >130
Pre-In sensitivity: 0.3-5Volts
Pre-In impedence: 15 kohms
Speaker-In sensitivity: 1.4-24Volts
Speaker-in impendence@ 5kOhms
Power supply voltage: 11 - 15Volts
Idling current: 1A
Idling current when off: 0.02mA
Consumption @2ohm, 14.4VDC: 28A
Remote In: 6-15 VDC - 1mA
Remote Out: 12 VDC - 50mA
Automatic Turn On/Off with speaker in
Fuse: 2x25A
Dimensions (mm): 240 x 350 x 54
_________________________
pioneer deh 4000,GZTC165T,GZHF 652X,0 awg
gigilogan is offline   Reply With Quote
Old 08-07-11, 00:18   #2
groowe
groowe's Avatar
[CITROEN]
Default Re: pareri Hertz EP4
Output Power (RMS):
60W x 4 @4-ohm
95W x 4 @2-ohm
3 channel mode:
190W x 2 (4ohm)
Filters & Controls:
Idling current: 1A
Fuse: 2x25A
Personal nu l-am ascultat, dar din cate am auzit e un amplif bun, usor peste medie. Acuma depinde si la ce pret il iei...nou sau second ?
groowe is offline   Reply With Quote
Old 08-07-11, 15:25   #3
gigilogan
gigilogan's Avatar
il iau scond dar doar pentru ca e pretul foarte bun.mie imi trebuie ceva la 4x125 sau 4x100,ceva gen magnat rx44 sau echivalent
Old 08-07-11, 17:44   #4
groowe
groowe's Avatar
[CITROEN]
Calitativ, Hertzul e cu mult peste magnat, poate si ca putere. Din cate stiu RXurile au mici probleme cu caldura.
Daca ii ieftin, ia-l.
Old 08-07-11, 20:27   #5
gigilogan
gigilogan's Avatar
eu am pe masina difuri ground zero de 100w rms de aceea imi trebuie rx-ul care e mai ok la bani deocamdata.acesta avand ''doar'' 60 w rms nu ma ajuta iar difurile nu prea cu ce sa le schimb acum fara sa investesc peste
