pareri Hertz EP4
as vrea cumpar ampliful Hertz EP4 dar m-ar interesa niste pareri despre ea.
Specificatii tehnice pentru Hertz EP4 Output Power (RMS): 60W x 4 @4-ohm 95W x 4 @2-ohm 3 channel mode: 60W x 2 (4ohm) + 190W x 1 (4ohm) 95W x 2 (4ohm) + 190W x 1 (4ohm) 190W x 2 (4ohm) Filters & Controls: A Channels: Full / Hi-pass / Lo-pass: 40 - 400Hz @12dB/Oct B Channels: Full / Hi-pass / Lo-pass: 40 - 400Hz @12dB/Oct C Channels: Bass Boost: 0-12dB @45Hz T.H.D. (100Hz @4-ohm): 0.08% Bandwith (-3 dB): 7 - 60Hz S/N Ratio (A weighted @1V): 98dBA Damping Factor (100Hz @4-ohm) >130 Pre-In sensitivity: 0.3-5Volts Pre-In impedence: 15 kohms Speaker-In sensitivity: 1.4-24Volts Speaker-in impendence@ 5kOhms Power supply voltage: 11 - 15Volts Idling current: 1A Idling current when off: 0.02mA Consumption @2ohm, 14.4VDC: 28A Remote In: 6-15 VDC - 1mA Remote Out: 12 VDC - 50mA Automatic Turn On/Off with speaker in Fuse: 2x25A Dimensions (mm): 240 x 350 x 54 |
Re: pareri Hertz EP4
il iau scond dar doar pentru ca e pretul foarte bun.mie imi trebuie ceva la 4x125 sau 4x100,ceva gen magnat rx44 sau echivalent
Calitativ, Hertzul e cu mult peste magnat, poate si ca putere. Din cate stiu RXurile au mici probleme cu caldura.
Daca ii ieftin, ia-l. |
eu am pe masina difuri ground zero de 100w rms de aceea imi trebuie rx-ul care e mai ok la bani deocamdata.acesta avand ''doar'' 60 w rms nu ma ajuta iar difurile nu prea cu ce sa le schimb acum fara sa investesc peste
| All times are GMT +2. The time now is 06:12. |
