Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 19-03-09, 06:52   #16
KillerINC
KillerINC's Avatar
[Street 4 Cars]
[ALFA ROMEO]
Default Re: Ground Zero in logan
nimic nou ?
KillerINC is offline   Reply With Quote
Old 20-04-09, 21:35   #17
alex_77_marius
Dacia Rally Team Member
alex_77_marius's Avatar
[Dacia Rally Team]
Cand ai montat plasma in bord de ce nu ai schimbat si led-urile de la ace si de la cp de bord?dadeau mult mai bine parerea mea,bine acum fiecare cu gusturile lui.bafta si la cat mai multe modificari
D.R.T Motorsport
2.0 16v F4R 730 engine|KW v1 Coilovers|BORLA exhaust 50mm|Logan VAN front brake calipers|ZIMMERMANN front brake discs 259mm ventilated & perforated|FERODO Premier front brake pads|R19 rear brake calipers|OEM R19 rear brake discs 240mm|OEM R19 rear brake pads|MOTUL brake fluid|ATS DTC 15' rims yellow edition
alex_77_marius is offline   Reply With Quote
Old 26-07-09, 08:51   #18
valitataye
valitataye's Avatar
[SEAT]
spor la munca in continuare si vrem sa vedem progresul
valitataye is offline   Reply With Quote
Old 11-08-09, 13:49   #19
gigilogan
gigilogan's Avatar
asta e progresul:
1:woofer - Ground Zero Radioactive GZRW 30SPL
2:amplificator - Duval vector VT-8000
3:condensator GZNC 1500X
4:BOXE SPATE:GZHF 652X
5:cabluri de 0 awg
dublarea traseelor de + si - s-a facut tot cu cablu de 0 awg
astept pareri
ID:	1041623   Click image for larger version
ID:	1041624   Click image for larger version
ID:	1041626   Click image for larger version
ID:	1041627   Click image for larger version
ID:	1041629   Click image for larger version
ID:	1041630   Click image for larger version
ID:	1041632   Click image for larger version
ID:	1041633   Click image for larger version
_________________________
pioneer deh 4000,GZTC165T,GZHF 652X,0 awg
gigilogan is offline   Reply With Quote
Old 11-08-09, 19:43   #20
Bigu
Bigu's Avatar
scimba acumulatorul si vopseste portul ca arata ca naiba
Old 11-08-09, 20:00   #21
morpheusmaster
morpheusmaster's Avatar
Imi pare rau ca ai reusit sa arzi 1 woofer...e bine ca lai schimbat dar ce nu imi place e cum ai prins boxele alea pe fata, mai exact holsuruburile alea dau in greatza...daca le vopseai capusorul negru sau ceva discret...sa nu se vada. Succes!
P.S. Lasami un Pm cu linkurile alea dp 1 pagina din 1 post in care nu pot sa intru...vreau si eu sa trec pe GZ si vreau sa vad specurile si preturile la ce ai tu acolo.
Numa bine
morpheusmaster is offline   Reply With Quote
Old 11-08-09, 21:05   #22
gigilogan
gigilogan's Avatar
maine postez si poze cu difurile ca am schimbat ce e acolo.cu bateria e mai greu.stiu ca trebuie deep,tot gz vreau dar costa si o mai aman putin.
Old 11-08-09, 21:53   #23
Bigu
Bigu's Avatar
gz nu e deep....
Old 12-08-09, 07:51   #24
gigilogan
gigilogan's Avatar
ok merci.gasesc eu ceva,un odyssey sau stinger.bani sa fie
Old 12-08-09, 14:12   #25
gigilogan
gigilogan's Avatar
asa cum am promis poze cu difurile
ID:	1042811   Click image for larger version
ID:	1042812   Click image for larger version
Old 12-08-09, 23:31   #26
morpheusmaster
Asa DA senior succes in continuare!
Old 13-08-09, 12:32   #27
animalutz
animalutz's Avatar
[Street Gambler]
Te-ai gandit la un amplificator pentru boxele alea ?! Nu o sa scoti nici macar jumate de ele cu H.U.-ul !!
animalutz is offline   Reply With Quote
Old 13-08-09, 13:56   #28
gigilogan
gigilogan's Avatar
m-am gandit la multe dar deocamdata primordiala e bateria deep si terminarea insonorizarii.trebuiesc facute usile pana la amplicarea difurilor.ma gandesc si la alt hu dar deocamdata e bun asta numai ca nu le am eu la reglaje si frecvente
Old 24-08-09, 11:18   #29
gigilogan
gigilogan's Avatar
portul vopsit si schema masinii.o critica ceva,un sfat nimic?
ID:	1056749   Click image for larger version
ID:	1056750   Click image for larger version
Name:	schema audio masina.JPG
Old 24-08-09, 12:18   #30
ceachi
ceachi's Avatar
Vrei neaparat critica?
Difuzoarele de pe polita nu le vad prea bine cu sub-ul in portbagaj!
In rest ce sa zic, felicitari pentru sistem , sa te bucuri de el...
Ca planuri de viitor ar trebui sa ai in vedere : insonorizarea usilor(cum ai zis si tu), amplificator pentru difuzoare (daca tot dai banu macar ia unu bun ca sa nu trebuiasca sa-l schimbi) , playerul (fara time alignment in masina nu prea merge) , bateria (daca asta e obosita la iarna probabil o sa te lase).
CDA-7990R F#1 Status CD Tuner + PXA-H900 F#1 Status Multimedia Manager , BRAX Matrix 1.1 , BRAX Matrix 2.1 , 2*BRAX Matrix 6.1 PP , 4*BRAX X 2000.2 Graphic Edition platinum ,2* BRAX Matrix 10.1
ceachi is offline   Reply With Quote
