Salut . De curand mi-am achizitionat 2 difuzoare powerbass m-124 si as dori sa imi fac incinta doar ca nu ma pricep foarte tare . Va rog a ma ajuta si pe mine
Incinta va fi amplasata intr-un Renault Clio 2 (2005)
Ascult toate genuriile de muzica
PARAMETERS :
VC impedance (Ohms) - 4Ω
Test Impedance (Ohms) - 3.2
Fs (Hz) - 29
SD (sqCM) - 510.7
Vas (Ltr) - 77.3
Cms (M/N) - 212.2
Mms (g) - 139.1
BL - 13,6
Qms - 3.6
Qes - 0.46
Qts - 0.41
No(%) - 0.32
Spl(db) - 92
Xmax - 9.5
Voice coil size (inches) - 2.0
Frequency response (Hz) - 29-450
Motor structure - 164 oz
Mounting Depth - 5.5
power (rms/peak) - 375/750
Optimum Ported Vol. Standard Metric
Gross vb internal 2.0cu.ft 56.63 litri
Circular port 4"x11"D 10.16cmx27.94cm D
Fb( box tuning) 35Hz 35Hz
F3(-3db Cutoff) 33Hz 33Hz
Pe(Watts Rms) 100-375 watts 100-375 watts
Subsonic Filter
Setting If Applicable 33Hz 33Hz
