Old 13-09-11, 12:38   #1
cca_golf
cca_golf's Avatar
Default [AJUTOR] Problema subwoofer/amp
Salutare, azi dimineata cand sa imi pornesc muzica , observ ca subwoofer'ul nu functioneaza. Deschid portbagajul verific daca cablurile nu au "iesit" din "locasul" lor , le misc dar nimic. Amplificatorul functiona , (cel putin era aprins un beculet verde ). Nu am simtit miros de ars . "Sculele" functionau perfect ieri seara + ca mai tot timpului volumul nu trecea de 70%. Cd-playerul' este un VW MCD , care este legat la "high level input" . Care ar putea fi problema ? Ce trebuie sa verific mai intai' ?
Subwoofer :
M.A Audio MA151XQ
15" High Performance Subwoofer
Power Handling:
Peak: 900 watts
RMS: 450 watts
Non-pressed paper cone
High profile triple treated foam surround
Black powder coated stamped steel basket
Platinum plated block terminals
Copper wound voice coil
50oz. Strontium magnet structure
Bumped T-Yoke
Dual laminated cotton spider
Amplificator :
Statie: CRUNCH P2125: 150lei
- 125Wx2CH @ 4 Ohm
- 250Wx2CH @ 2 Ohm
- 500Wx1CH Bridged
Max current draw - 25 amps
Full MOSFET Design
4 & 2 Ohm Stable
PWM Power Supply
Tri-Mode Capable
12 dB per Octave internal crossover and a Bass/Treble Switch
Brushed Aluminum Heat Sink
On-board diagnostics
Incinta:
Dimensiuni:40-44-80cm
Material: MDF
Facut de cei de la Dragster.
Imagini : https://forum.4tuning.ro/560-pachete-...runch-usa.html
Multumesc, astept raspunsurile voastre.
cca_golf is offline   Reply With Quote
Old 13-09-11, 16:10   #2
AlexBanu
AlexBanu's Avatar
Exclamation Re: [AJUTOR] Problema subwoofer/amp
Verifica mai intai adaptorul de nivel si apoi iesirile playerului si apoi amplificatorul.
Old 14-09-11, 17:56   #3
cca_golf
cca_golf's Avatar
Default Re: [AJUTOR] Problema subwoofer/amp
Multumesc pentru raspunsul promt , problema a fost rezolvata relativ simplu,... un contact imperfect .
