Go Back   Forum 4Tuning > Comunitati 4tuning locale > Comunitati locale si internationale 4Tuning > Piatra-Neamt
Old 21-01-07, 18:14   #1
dangti16v
Kamikaze Racing Team Member
dangti16v's Avatar
[Kamikaze Racing Team]
Default Masini Din Toata Lumea !!!
La Acest Topic Se Pot Pune Tot Felul De Poze Filme Cu Masini Pe Care Le Stiti Si Vreti Sa Le Vada Si Lumea...tunate,clasice,hotroduri,prototipuri,stock ..etc
Still Kamikaze...
dangti16v is offline
Old 21-01-07, 18:20   #2
dangti16v
dangti16v's Avatar
Default Re: Masini Din Toata Lumea !!!
am sa incep chiar eu fiind posesor de golf 2 cu un golf care...care...
ce sa zic si
Asta este omul si asta este ce a facut el:
Hi my name is Spyros from Greece. I am trying to reach 1000hp target with my golf.
I have tuning center in Greece and i want it as project for my store.
These days i convert it from fwd to 4wd. Also i ve finish my new setup with big turbo and some modifications in the engine. At the past setup was with turbonetics T76 turbo. The car will stay for road use and not for race use.
Engine: 2ltr block with 16v head,Custom nicasil sleeves, Custom billet cams, custom inconel and berilium valves,custom solid lifters, custom cam springs, titanium custom retainers, custom special material pistons, titanium custom pauter rods, ARP main stud kit,ARP head stud kit,custom main girdle, custom 4340 main bearings caps, custom 4340 billet crank. Custom dry sump system with pace parts.
Comp ratio: 11,2:1
Turbonetics turbo Y2k custom order Bbearing (120lbs~ 1200hp capable) , 8 x 850cc fuel injetors, custom intake, custom fuel rails, custom 4 to 1 exsaust steel manifold, turbonetics newgen wastgate,aeromotive 2 x fuel regulators, 3 x bosch fuel pumps, Haltech E11v2 engine managment, msd dis2 ignition, msd 4 x coils, custom 120mm steel exsaust pipe, turbonetics godzila bov, custom intercooler 82cm x 44cm x 8cm. Custom fuel cell.
Transmition: 4wd 6speed
Wheels: custom order 7 x 19'' work vsxx 5x100.
Tires: Pirreli pzero 215/35/19
Brakes: frond 405mm(16'') drilled custom discs with porsche gt3 leman 6piston calipers. Rear 355mm(14'') drilled discs with porsche 4pot calipers.
Suspension: Custom Made KW 3
ID:	204415   Click image for larger version
ID:	204416   Click image for larger version
ID:	204418   Click image for larger version
ID:	204419   Click image for larger version
ID:	204421   Click image for larger version
Old 21-01-07, 19:58   #3
Ali_ump
Ali_ump's Avatar
na fiecare cu ce ii place...io cu japonezele...dangti16v cu gti-urile bineinteles...
da ca poate fi de mare turbina aia si cu intercooleru OMG....
Ali_ump is offline
Old 22-01-07, 15:22   #4
dangti16v
dangti16v's Avatar
da un adevarat fan golf grecul
Old 22-01-07, 21:00   #5
bullibutton
bullibutton's Avatar
frumoasa codita asta si tipsurile ... parca mi-as pune si eu
bullibutton is offline
Old 22-01-07, 21:04   #6
Ali_ump
Ali_ump's Avatar
foarte tare frate...dita tipsurile ....))
Ali_ump is offline
Old 22-01-07, 21:23   #7
Takashy_Vtec18
Takashy_Vtec18's Avatar
Si un prelude de la mine...........cred ca e dragster...nus....
Name:	HONDA prelude HELLA TRICKED OUT.jpg
Takashy_Vtec18 is offline
Old 22-01-07, 22:01   #8
Ali_ump
Ali_ump's Avatar
Normal ca nu puteam sa nu va arat cateva din preferatele mele....
Name:	nissan s15 silvia.jpg
ID:	204928   Click image for larger version
Name:	nissan silvia s15.jpg
ID:	204929   Click image for larger version
ID:	204931   Click image for larger version
ID:	204932   Click image for larger version
ID:	204934   Click image for larger version
ID:	204935   Click image for larger version
ID:	204937   Click image for larger version
ID:	204938   Click image for larger version
ID:	204940   Click image for larger version
ID:	204941   Click image for larger version
ID:	204943   Click image for larger version
Name:	Nissan Skyline_gt-r-1999.jpg
ID:	204944   Click image for larger version
ID:	204946   Click image for larger version
Name:	Yellow Nissan Skyline GTR (Leon's Car).jpg
Ali_ump is offline
Old 22-01-07, 22:09   #9
Takashy_Vtec18
Si inca o masina care dupa mine este cea mai tare ...........HOnda Civic Type R
Old 22-01-07, 22:24   #10
Takashy_Vtec18
iar imi fac colectie de poze........inca ceva de la mine....O Honda Civic...iar
ID:	204954   Click image for larger version
ID:	204955   Click image for larger version
ID:	204957   Click image for larger version
ID:	204958   Click image for larger version
Old 22-01-07, 22:28   #11
Ali_ump
Ali_ump's Avatar
Daca asta arata asa ....ma intreb cum o sa arate type RR celalalt model de la Honda...
Ali_ump is offline
Old 22-01-07, 22:31   #12
bullibutton
Si ca sa nu mai vorbim de aberatii(mai bine zis vise) pun si eu cateva poze cu o masina care am gasit-o mai inainte ... dupa mine se poate cumpara cine vrea sa stie pun si pretul la ea ...este de aprox 14.ooo euroi ...dupa mine face are 130 cp.
ID:	204960   Click image for larger version
ID:	204961   Click image for larger version
ID:	204963   Click image for larger version
Old 22-01-07, 22:36   #13
Ali_ump
Ali_ump's Avatar
La noi sau ...de pe la nemti...? Facuta cu simt masina...finutza...
Ali_ump is offline
Old 22-01-07, 22:38   #14
bullibutton
La nemti normal... unde vezi tu asa ceva la noi ... ai vazut ce garda la sol are .... sigur trece podul ca sa se duca pana in strand ))))))))))
Old 22-01-07, 23:00   #15
Takashy_Vtec18
De unde type RR.....???? exista asa ceva.......zimi ca sa stiu sa ma impusc ...
