Masini Din Toata Lumea !!!
La Acest Topic Se Pot Pune Tot Felul De Poze Filme Cu Masini Pe Care Le Stiti Si Vreti Sa Le Vada Si Lumea...tunate,clasice,hotroduri,prototipuri,stock ..etc
Re: Masini Din Toata Lumea !!!
8 Attachment(s)
am sa incep chiar eu fiind posesor de golf 2 cu un golf care...care...
ce sa zic :yikes: si:peace: Asta este omul si asta este ce a facut el: Hi my name is Spyros from Greece. I am trying to reach 1000hp target with my golf. I have tuning center in Greece and i want it as project for my store. These days i convert it from fwd to 4wd. Also i ve finish my new setup with big turbo and some modifications in the engine. At the past setup was with turbonetics T76 turbo. The car will stay for road use and not for race use. Engine: 2ltr block with 16v head,Custom nicasil sleeves, Custom billet cams, custom inconel and berilium valves,custom solid lifters, custom cam springs, titanium custom retainers, custom special material pistons, titanium custom pauter rods, ARP main stud kit,ARP head stud kit,custom main girdle, custom 4340 main bearings caps, custom 4340 billet crank. Custom dry sump system with pace parts. Comp ratio: 11,2:1 Turbonetics turbo Y2k custom order Bbearing (120lbs~ 1200hp capable) , 8 x 850cc fuel injetors, custom intake, custom fuel rails, custom 4 to 1 exsaust steel manifold, turbonetics newgen wastgate,aeromotive 2 x fuel regulators, 3 x bosch fuel pumps, Haltech E11v2 engine managment, msd dis2 ignition, msd 4 x coils, custom 120mm steel exsaust pipe, turbonetics godzila bov, custom intercooler 82cm x 44cm x 8cm. Custom fuel cell. Transmition: 4wd 6speed Wheels: custom order 7 x 19'' work vsxx 5x100. Tires: Pirreli pzero 215/35/19 Brakes: frond 405mm(16'') drilled custom discs with porsche gt3 leman 6piston calipers. Rear 355mm(14'') drilled discs with porsche 4pot calipers. Suspension: Custom Made KW 3 |
na fiecare cu ce ii place...io cu japonezele...dangti16v cu gti-urile bineinteles...
da ca poate fi de mare turbina aia si cu intercooleru OMG.... |
da un adevarat fan golf grecul
frumoasa codita asta si tipsurile ... parca mi-as pune si eu :D
Si un prelude de la mine...........cred ca e dragster...nus....
20 Attachment(s)
Normal ca nu puteam sa nu va arat cateva din preferatele mele....:D
Si inca o masina care dupa mine este cea mai tare ...........HOnda Civic Type R :D
6 Attachment(s)
iar imi fac colectie de poze........inca ceva de la mine....O Honda Civic...iar
Si ca sa nu mai vorbim de aberatii(mai bine zis vise) pun si eu cateva poze cu o masina care am gasit-o mai inainte ... dupa mine se poate cumpara cine vrea sa stie pun si pretul la ea ...este de aprox 14.ooo euroi ...dupa mine face are 130 cp.
La nemti normal... unde vezi tu asa ceva la noi ... ai vazut ce garda la sol are .... sigur trece podul ca sa se duca pana in strand :)))))))))))
| All times are GMT +2. The time now is 10:02. |
