SALUTARE , AM O PROBLEMA CU USA DE PE DREAPTA , NU SE INCHIDE SI NICI NU SE DESCHIDE DIN ALARMA , PROBLEMA E CA MECANIC (DIN CHEIE) SE INCHIDE TOT IN AFARA DE USA DE PE DREAPTA,SI DACA INCHID DE LA USA DE PE DREAPTA SE INCHIDE TOT IN AFARA DE USA DE PE STANGA.
POATE SA FIE DE LA ALARMA? EXISTA VREUN FIR SAU CEVA CE FACE CA CELE 2 USI SA COMUNICE INTRE ELE? AM SCHIMBAT BROASCA CA AM ZIS CA E MOTORASUL,DAR NIMIC,AM SCHIMBAT SI MODUL DE INCHIDERE CA AM ZIS CA E ALA,AM VERIFICAT SI INSTALATIA USII SI NIMIC...
AM VERIFICAT SI FIRELE DE LA PORTBAGAJ SA NU FIE INTRERUPTE
DACA INCHID DE LA PORTBAGAJ MERGE DOAR PORTBAGAJUL SI USITA DE LA REZERVOR
VA MULTUMESC
BMW E36 320 COUPE AN 94
