Go Back   Forum 4Tuning > Comunitati 4tuning locale > Comunitati locale si internationale 4Tuning > Hunedoara / Deva
Old 23-10-06, 18:32   #1
sNap7
Honda Driver
[Honda]
Default Masina "perfecta" & Comment-uri
Poze cu masina "perfecta" pentru fiecare, sau mai exact, masina preferata si ceva detalii , si .. vor aparea si comment-uri
sNap7 is offline   Reply With Quote
Old 23-10-06, 18:49   #2
sNap7
Honda Driver
[Honda]
Default Re: Masina "perfecta" & Comment-uri
Incep eu ...
Masina "perfecta" e Audi RS4.
Motor : V8, DOHC 4 Valve / Cilindru
Capacitate cilindrica : 4200 cmc
Putere : 420 CP
Cuplu : 430 Nm
0-100 km/h : 4.8 sec
Dimensiuni
Lungime - 4589 mm
Latime - 1816 mm
Inaltime - 1415 mm
Greutate - 1650 kg
Astept pareri
ID:	166133   Click image for larger version
ID:	166134   Click image for larger version
ID:	166136   Click image for larger version
Dura lex, sed lex!
Old 23-10-06, 20:17   #3
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Post Re: Masina "perfecta" & Comment-uri
Superba sNaP7 da' am si eu o nelamurire, poate-s eu mai de la tzara da ce e aia DOHC
E cumva: "Department of Health and Children ?
Pana am scris postu asta, am gasit ceva interesant
Deci:
"SOHC Engines Vs. DOHC Engines
Difference
SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve.
DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves.
Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs. To ensure against expensive engine repairs, make sure you change your engine's timing belt about every 60,000 miles."
Click pe GIF!!!
F.R.Sonic is offline   Reply With Quote
Old 23-10-06, 21:09   #4
sNap7
Honda Driver
[Honda]
Ma bucur ca te-ai lamurit E frumoasa, e superba ...
Originally Posted by fast_racer_sonik View Post
Superba sNaP7
P.S : Se scrie sNap7
Old 23-10-06, 21:26   #5
Co5m1n eXtreme
Co5m1n eXtreme's Avatar
Eu cred k masina perfecta e Seat Leon .....asa cred eu
Co5m1n eXtreme is offline   Reply With Quote
Old 23-10-06, 21:28   #6
sNap7
Honda Driver
[Honda]
Ok .. dar sunt multe modele de Seat Leon. Vreunul anume ? FR ? CupraR ? ...
Old 23-10-06, 21:33   #7
Co5m1n eXtreme
Cupra R imi place mai mult
Old 23-10-06, 21:34   #8
tune_AKj
tune_AKj's Avatar
pentru mine no1 ramane Toyota Celica....
Tip motor 1.8l VVT-i
Numar cilindri 4 in linie
Mecanism de supape 16 V, DOHC
Capacitate cilindrica (cc) 1794
Putere maxima (kW/rpm) 140/6400
Transmisie
Cutie de viteze 6, manuala
Performante
Viteza maxima (km/h) 205
Aceleratie 0-100 km/h 8.7
Sasiu
Numar de usi 2
Numar de locuri 2
Dimensiuni
Lungime totala (mm) 4350
Latime totala (mm) 1735
Inaltime totala (mm) 1315
cateva poze.....
ID:	166241   Click image for larger version
ID:	166242   Click image for larger version
tune_AKj is offline   Reply With Quote
Old 23-10-06, 21:41   #9
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Frumos!!!!!
Old 23-10-06, 21:43   #10
Co5m1n eXtreme
Prea frumos ....super....super
Old 23-10-06, 21:44   #11
tune_AKj
tune_AKj's Avatar
Frumos!!!!!
Dar parca tot nu ma pot hotara intre Nissan 350Z-Alfa 159-Toyota Celica....
....cred ca raman la capitolul "japoneze"....still.........
Old 23-10-06, 21:47   #12
sNap7
Honda Driver
[Honda]
Frumoasa masina tune_AKj. E buna de linii . Nu am vazut niciodata una live, cred ca doar la SIAB.
Aceleratie 0-100 km/h 8.7 ???? Atata de mare timp are pana la 100 ?
Hmm .. interesant ..
Old 23-10-06, 21:50   #13
tune_AKj
tune_AKj's Avatar
da..frumoasa....eu mor dupa ea..pakat ca-i pretul "ridicat "...si da...8.7
Old 23-10-06, 21:51   #14
sNap7
Honda Driver
[Honda]
Cam mult 8.7 s pana la 100 .. cel putin pentru o masina de talia ei. Pai .. uite-te la tuning de prin zona la Peugeot-ul acela rosu. E masina mai "mica" si ca talie si ca renume, si face 0-100 km/h in 7.4 sec ..
Dar ca design, nota 10
Old 23-10-06, 22:01   #15
tune_AKj
tune_AKj's Avatar
1.8 VVT-i 1.8 VVTL-i
Motor
Tip motor 1.8l VVT-i 1.8 l VVTL-i
Numar cilindri 4 in linie 4 in linie
Mecanism de supape 16 V, DOHC 16 V, DOHC
Capacitate cilindrica (cc) 1794 1796
Raport de compresie 10.1:1 11.5:1
Putere maxima (kW/rpm) 140/6400 192/7800
Cuplu maxim (Nm/rpm) 170/4400 180/6800
Consum de combustibil
Tip combustibil Benzina fara plumb Benzina fara plumb
Extra urban l/100km (93/116/EEC) 5.9 6.6
Urban l/100km (93/116/EEC) 10.1 11.5
Combinat – l/100 km (93/116/CEE) 7.4 8.4
Emisii CO2 (g/km) 185 200
Capacitate rezervor de combustibil (l) 55 55
Transmisie
Cutie de viteze 6, manuala 6, manuala
Performante
Viteza maxima (km/h) 205 225
Aceleratie 0-100 km/h 8.7 7.4
Anvelope si roti
Fata/spate 205/55R16 205/55R16
Sasiu
Numar de usi 2 2
Numar de locuri 2 2
Capacitate de incarcare
Greutate la gol (kg) 1100-1185 1140-1215
Masa totala admisa (kg) 1565 1595
Dimensiuni
Lungime totala (mm) 4350 4350
Latime totala (mm) 1735 1735
Inaltime totala (mm) 1315 1315
Ampatament (mm) 2600 2600
Ecartament - Fata (mm) 1490 1490
Ecartament - Spate (mm) 1480 1480
uite cealalta versiune..de 7.4/0-100km
