Masina "perfecta" & Comment-uri
Poze cu masina "perfecta" pentru fiecare, sau mai exact, masina preferata si ceva detalii , si .. vor aparea si comment-uri :)
Re: Masina "perfecta" & Comment-uri
Incep eu ... :D
Masina "perfecta" e Audi RS4. Motor : V8, DOHC 4 Valve / Cilindru Capacitate cilindrica : 4200 cmc Putere : 420 CP Cuplu : 430 Nm 0-100 km/h : 4.8 sec Dimensiuni Lungime - 4589 mm Latime - 1816 mm Inaltime - 1415 mm Greutate - 1650 kg Astept pareri :) |
Superba sNaP7 da' am si eu o nelamurire, poate-s eu mai de la tzara da ce e aia DOHC :rolleyes2
E cumva: "Department of Health and Children ? :grandpa: Pana am scris postu asta, am gasit ceva interesant :p Deci: "SOHC Engines Vs. DOHC Engines Difference SOHC stands for Single Overhead Camshaft. That means that there is only one camshaft per header. Inline engines will contain one camshaft. V-type and/or flat will contain 2 camshafts. For a SOHC engine there are usually 2 valves per cylinder but there can be more with the addition of cams for each valve. DOHC stands for Double Overhead Camshaft. Now there are 2 camshafts per header. So in an inline there are 2 camshafts because there is only one header, but there is 4 in a V-type or flat engine. These DOHC engines usually have 4 valves. One camshaft for the exhaust valves and the other for the intake valves. Advantages to having a DOHC engine over a SOHC is that the engine has twice as many intake and exhaust valves as a SOHC motor. This makes the engine run cooler and more smoothly, quietly, and efficiently. But the downfall is that DOHC engines cost more for repairs. To ensure against expensive engine repairs, make sure you change your engine's timing belt about every 60,000 miles." Click pe GIF!!! |
Ma bucur ca te-ai lamurit :D E frumoasa, e superba ...
Eu cred k masina perfecta e Seat Leon .....asa cred eu :D
Cupra R imi place mai mult
pentru mine no1 ramane Toyota Celica....
Tip motor 1.8l VVT-i Numar cilindri 4 in linie Mecanism de supape 16 V, DOHC Capacitate cilindrica (cc) 1794 Putere maxima (kW/rpm) 140/6400 Transmisie Cutie de viteze 6, manuala Performante Viteza maxima (km/h) 205 Aceleratie 0-100 km/h 8.7 Sasiu Numar de usi 2 Numar de locuri 2 Dimensiuni Lungime totala (mm) 4350 Latime totala (mm) 1735 Inaltime totala (mm) 1315 cateva poze..... |
:doh: Frumos!!!!! :doh:
Prea frumos ....super....super
....cred ca raman la capitolul "japoneze"....still.........:-P |
Frumoasa masina tune_AKj. E buna de linii :D . Nu am vazut niciodata una live, cred ca doar la SIAB.
Aceleratie 0-100 km/h 8.7 ???? Atata de mare timp are pana la 100 ? Hmm .. interesant .. |
Cam mult 8.7 s pana la 100 .. cel putin pentru o masina de talia ei. Pai .. uite-te la tuning de prin zona la Peugeot-ul acela rosu. E masina mai "mica" si ca talie si ca renume, si face 0-100 km/h in 7.4 sec ..
Dar ca design, nota 10 ;) |
Motor Tip motor 1.8l VVT-i 1.8 l VVTL-i Numar cilindri 4 in linie 4 in linie Mecanism de supape 16 V, DOHC 16 V, DOHC Capacitate cilindrica (cc) 1794 1796 Raport de compresie 10.1:1 11.5:1 Putere maxima (kW/rpm) 140/6400 192/7800 Cuplu maxim (Nm/rpm) 170/4400 180/6800 Consum de combustibil Tip combustibil Benzina fara plumb Benzina fara plumb Extra urban l/100km (93/116/EEC) 5.9 6.6 Urban l/100km (93/116/EEC) 10.1 11.5 Combinat – l/100 km (93/116/CEE) 7.4 8.4 Emisii CO2 (g/km) 185 200 Capacitate rezervor de combustibil (l) 55 55 Transmisie Cutie de viteze 6, manuala 6, manuala Performante Viteza maxima (km/h) 205 225 Aceleratie 0-100 km/h 8.7 7.4 Anvelope si roti Fata/spate 205/55R16 205/55R16 Sasiu Numar de usi 2 2 Numar de locuri 2 2 Capacitate de incarcare Greutate la gol (kg) 1100-1185 1140-1215 Masa totala admisa (kg) 1565 1595 Dimensiuni Lungime totala (mm) 4350 4350 Latime totala (mm) 1735 1735 Inaltime totala (mm) 1315 1315 Ampatament (mm) 2600 2600 Ecartament - Fata (mm) 1490 1490 Ecartament - Spate (mm) 1480 1480 uite cealalta versiune..de 7.4/0-100km |
| All times are GMT +2. The time now is 04:15. |
