15-05-11, 23:18
#31
![](/images/ranks/6.gif) Stage 5
Re: Dacia Logan sau BMW seria 5?
Volvo nu are motor in el. Au dreptate cei care au lasat commenturi pe youtube.
Ce e nasol e plafonul de sticla de la Modus, care se sparge si toate bucatile cad inapoi in masina...
![](https://forum.4tuning.ro/signaturepics/sigpic21431_4.gif)
Official Porsche hater.
16-05-11, 12:51
#32
Banned
Member of: [2 Roti]
Originally Posted by Bogdan_mb
Omule, daca chiar vrei sa imi demonstrezi contrari-ul macar te rog sa aduci macar UN argument concret nu povesti copilaresti.
1. Ti-am pus doua poze cu ambele mentionate, impact frontal la 64 km/h. Ti se pare ca Loganul sta mai bine la protectia pasagerilor ?
Opel : Front impact
The double pre-tensioner on the driver's seatbelt restrained the dummy so that the knees did not contact the dashboard. The head of the driver dummy bottomed-out the airbag onto the steering wheel. However, head protection was still rated as 'adequate'. The passenger dummy scored maximum points
Logan : Front impact
The stable passenger cell and the single stage non-tethered airbags for the driver and front passenger worked well together but loads recorded by the dummies’ chests, particularly the passenger’s, were on the high side. While the footwell suffered only minimal distortion, poor control of the displacement of the clutch and brake pedal compromised protection for the driver’s feet. The brake pedal was also found to be blocked after the test, putting the driver’s lower legs at further risk. He also risked knee injuries from the steering column and its mounting bracket.
2. Ai pomenit de fizica :
Corsa 1.2 5 usi : 1160 kg
Logan 1.2 5 usi : 1050 kg
Deci poti sa adaugi si cartofii ca tot nu da bine
3. Comparatia cu cobra ma lasa rece, uite aici un contra-exemplu :
https://www.youtube.com/watch?v=qBDyeWofcLY
Sa auzim de bine
Mai omule, cum poti tu care esti pasionat de Benz ca si mine sa crezi povestile astora? Tot zici de argumente, da n-ai adus nici tu NICI UNUL valabil inafara de faza cu corsa care e mai grea cu 100kg decat loganu :P
...cica concluzii...parca habar n-ai de marketing, la astia li-i ciuda ca vindem loganu ca pita calda ieftin si acceptabil la calitate....in loc sa faca cumva sa avem salarii ca si ei ca sa nu mai iasa asa de ieftin....de aceea si sper sa umplem UE cu logane de sa-si taie venele ticalosii!!! Cum a fost ci pocinolul cu loganul rasturnat la nush ce viteza si manevra. Pai ada-mi mie orice masina si iti arat ca, cu jentile si gumele "adecvate" ti-o rastorn pe asfalt curat si cald cu gumele incalzite.....la fel si crash-testurile....am mai vazut undeva ca si smartul si pana si unele Aixamuri au 3 stele la crash-test ca li se deformeaza nush ce, dar totodata NU MENTIONEAZA hotii ca ai parte de o deccelerare atat de puternica a corpului incat iti intra inima in plamani si faci infart...si astfel esti un mort cosmetizat. Tot pe sistemul asta si un drag-steer are rollcage care rezista la impact frontal de 300kmph.....numai ca vezi ca se mai moare pt ca la o asemenea deccelerare te cam faci terci in masina
Legat de link nu-i vad bine pe nici unul din cele de masini, pt ca diferenta de greutate intre cele 2 e si de numai 300kg(dovada: http://carfolio.com/specifications/m...?car=119735)si aici a fost cam tendentios alesa zona impactului pe cele 2 masini, la Renault in zona aceea se afla si motorul care e transversal, deci un plus de masa in zona aia si cica volvo nici nu avea motor(deci hai sa vb de facaturi).....acuma normal ca, intr-o tara unde circuli pe stanga aceea e zona expusa la lovit frontal, dar la noi?
22-05-11, 11:14
#33
General Supervisor
Member of: [Super Moderators] [PARTICIPANT CURSE] [BMW] [MERCEDES] [2 Roti] [ALFA ROMEO]
seria 5 vs logan...
22-05-11, 11:39
#34
loganu nu se bate nici macar cu 324td din 1900...
23-05-11, 09:53
#35
Banned
Member of: [2 Roti]
Un urs 324td din 88 nu vad de ce sa fie inferior unui 520d din 99 plasticat si cu brate din aluminiu si telescoape cu carcasa tot din aluminiu, plus electronica care se strica la greu......zic asta considerand ca ambele sunt in aceeasi stare de intretinere si km.
23-05-11, 10:33
#36
Singurul "defect" al loganului e ca e masina noua si costa putin si deci poate fi comparat cu masini sh mult mai bune care au ajuns la acelasi pret. Ia comparati voi opel corsa cat de cat dotat care costa 13.000E, sau clio de 13k cu BMW sa vedem ce ati alege.
02-12-12, 20:20
#37
![](/images/ranks/5.gif) Stage 4
Member of: [Nissan]
Depinde in mare ce vrei de la o masina, si de ce ai nevoie.Daca vrei o masina sa te duca din A in B cu costuri minime (pret masina, revizie, asigurare, impozit, alte chestii pe reparatii) alegi Logan.
In principal te uiti si la ce ai in buzunar.BMW-ul costa.Nu pune in calcul doar cat dai pe ea.Pune in calcul si ce dai dupa: pe asigurare, impozit, revizie, piese de schimb etc.
In principal eu cred ca cine are bani de altceva mai bun, nu se opreste la Logan.Cine nu are bani, dar vrea masina, isi ia Logan (in rate de obicei).
02-12-12, 20:48
#38
Multumesc pentru informatii si pareri, am optat pentru Logan in cele din urma ca i-am pus husa pe volan(din aia cu snur) si am facut schimb pe schimb cu un Passat TDI cu ,,D" si ,,I" rosu. Si ,,T" argintiu.
E mult mai echipat decat Loganul. Are si icoane cu Piech din fabrica in bord, iar tapiseria este din imitatie de piele ce imita stofa.
02-12-12, 21:03
#39
nu fi ironic acum ca daca alegeai 5-ar dadeai cu pietre in logan
02-12-12, 21:09
#40
E mult mai echipat decat Loganul. Are si icoane cu Piech din fabrica in bord, iar tapiseria este din imitatie de piele ce imita stofa. ![Very Happy](https://forum.4tuning.ro/images/smilies/icon_biggrin.gif)
Fugi ma de aici, te-ai trezit si tu sa raspunzi la topicul tau dupa 1an si jumate. Topic facut la misto.
