Old 22-03-07, 20:17   #1
Treshure
Treshure's Avatar
Default noua generatie de motoare >>super tare<<
Cam asa stau treburile
Equiv. To 32 Cylinder, 4-stroke-cycle Diesel
Bore--mm(in) 76.2(3)
Stroke--mm(in) 95.25(3.75)
Displacement-- Cu in(L) 848 (13.**
Aspiration Normally
Compression Ratio 25:1
Rotation (from Fly Wheel end) CCW/CW
Cooling System Oil Cooling
Lub Oil System--Quart drysump, 5
Weight, Net Dry (Approx.) Kg(lb) including flywheel . 68 (150)
Advertised hp (KW) 850(634) NA 3,000 (2,23 SC/TC.
ID:	235341   Click image for larger version
Old School [email protected]
Treshure is offline   Reply With Quote
Old 23-03-07, 19:33   #2
master1
master1's Avatar
Default Re: noua generatie de motoare >>super tare<<
f tare motorul asta
sa vedem daca reusesc sa il si puna pe vreo masina....
master1 is offline   Reply With Quote
Old 26-03-07, 11:21   #3
Treshure
Treshure's Avatar
Din cate aratau la un show, motorul pt masina ar fi cat un pachet de biscuiti Nu stiu cum o sa transmita atata putere la roata deoarece cutia ar trebui sa fie tot micuta.. si la cuplul ala.. o cam indoaie Motorul pe care l-au prezentat ei (din imagine) are 3000 Hp.. 850 Hp MINIM.. nici gand sa il vezi pe un autoturism
Old 28-03-07, 13:02   #4
BASU
BASU's Avatar
Thumbs up Re: noua generatie de motoare >>super tare<<
New Toroidal Internal Combustion Engine Promises 20:1 Power-to-Weight Ratio
18 April 2006
The Massive Yet Tiny (MYT) engine
A California inventor is developing a new compact and highly efficient engine—the Massive Yet Tiny (MYT) engine—that promises high power output with a very high power to weight ratio (20:1). The inventor, Raphial Morgado, recently won first prize in the 2005 Emhart-NASA Tech Briefs Design Contest for his work on the engine.
The engine moves pistons on different rotors relative to each other to form combustion chambers of variable volume in a toroidal cylinder. The pistons move in stepwise fashion, with the pistons on one rotor travelling a predetermined distance while the pistons on the other rotor remain substantially stationary.
Fuel is drawn into a chamber as one of the pistons defining the chamber moves away from the other, and then compressed as the second piston moves toward the first.
The cycles of the MYT engine. Click to enlarge.
Combustion of the fuel drives the first piston away from the second, and the spent gases are then expelled from the chamber by the second piston moving again toward the first. An output shaft is connected to the rotors in such manner that the shaft rotates continuously while the rotors and pistons move in their stepwise fashion.
The engine fires 16 times on one revolution of the crankshaft, 32 times on two. By comparison, a standard V8 fires four times per crankshaft revolution—one-quarter the number of the MYT. Angel Labs, the company developing the engine, calculates the equivalent displacement of the MYT as 848 cubic inches (13.9 liters), with a 3-inch bore and a 3.75-inch stroke. The company further calculates that the 14" x 14", 150-pound prototype could produce power in excess of 3,000 hp.
[The 3,000 hp rating] is conservatively estimated from 850 CID. A conventional engine can produce 4 hp per CID (when turbo charged). Four times 850 [the equivalent displacement] is more than 3,000. Our data of air motoring (800 lb.ft. of torque from 150 psi of compressed air) extrapolates to more than 4,000 lb.ft. of torque when fuel is ignited, exceeding our conservative estimate.
The design is also modular. Additional MYT units can be connected by removing the rear cover of the engine and connecting another ME chamber assembly. With a dual-assembly configuration, the engine becomes a “64-cylinder” engine with 1,695 cubic inches displacement (27.8 liters), raising the power-to-weight ratio up to a projected 40:1.
The engine uses only about 20% of the number of parts normally found in a reciprocating internal combustion engine, and only 12 of the MYT parts are moving parts, reducing friction and parasitic losses.
Unlike a reciprocating combustion engine, the MYT engine permits a piston dwell at the equivalent of Top Dead Center (TDC)—the starting point for combustion. The current prototype is set for a piston dwell of approximately 12 degrees of the crankshaft rotation. By adding in that delay under combustion before permitting the power stroke, the MYT burns a greater percentage of the fuel and air mixture in the combustion chamber, resulting in a more complete combustion.
All we know is that 12-degrees dwell at the TDC, which no other engine can do, will burn all the fuels completely. Therefore, we expect very clean emissions.
Other features of the engine include:
The ability to support a compression ratio as high as 70:1.
No valves. The MYT uses open ports with no restriction. Airflow action is one way.
The entire engine acts as a heat sink and a radiator. It is both air and oil cooled.
There is no thrust loading on piston skirts.
Pistons do not touch the cylinder walls, only the rings do.
Pistons travel only the same direction. No reciprocation, only stop and go.
There are no cylinder heads, no cam shaft, no valves (the ME is equivalent to the bottom end of a reciprocating engine).
Intake compression and power stroke and exhaust stroke events are happening all at the same time, so there are no load strokes.
The MYT engine is not the first implementation of rotating pistons in a toroidal cylinder—the 1968 Tschudi engine is very similar in concept. (A newer derivative is by Hoose, 2005.) The key to the MYT engine is its timing mechanism.
The stop and go actions can be generated in many different ways, but you can not have active locking mechanism, because it will break under repeated stress. It took Raphial, who usually can invent in a couple of hours per invention, more than two years to come up with this invention (he threw away about 10 different ways of implementation.)
Angel Labs is targeting a number of application: autombiles and trucks, pumps and compressors, aviation (helicopter, fixed wing and UAV), and military. Their goal is to license the technology non-exclusively to everyone. According to Jin Kim, Angel Labs is currently in discussions with Lockheed Margin, Boeing, Ford and several smaller potential licensees.
intr-un cuvant, mic-puternic-economic
incredibil
ID:	238095   Click image for larger version
'06 Skoda Octavia 2 vRS 2.0TFSI 250CP++ >ex '04 Renault Megane Sedan 1.9DCI Privilege >ex '04 Smart Fortwo 0.7 Turbo
'02 Renault Laguna 2 GrandTour 1.9dCi >ex '79 Dacia 1300 Old School
'99 Daewoo Nubira 1 1.6 16v Automata + GPL >ex '12 First Bike Curier >ex '10 Moto Bike 48cc
BASU is offline   Reply With Quote
Old 28-03-07, 21:17   #5
bano
bano's Avatar
poate pt camioane e , sa vezi unu la 200km/o
bano is offline   Reply With Quote
Old 28-03-07, 23:53   #6
Nemilosu
Nemilosu's Avatar
[Fanatik MotorSport]
o sa il impuste careva pe inventator sau o sa aiba un "accident nefericit".
le darama economia la americani si nu numai.
Nemilosu is offline   Reply With Quote
Old 28-03-07, 23:53   #7
Treshure
Treshure's Avatar
si abia e la inceput.. stai sa vezi cand o sa preia patentul altcineva sa bage niste banisori in proiect.. o sa avem in buzunare motoare de 500 cai )
Klar ca tot nu-mi dau seama cum or sa transmita puterea la roata.. prea mic motorashul si prea mare puterea.. cutia o rupe in doua.. asta daca nu descopera si un nou aliaj gen titan, doar ca de 10 ori mai durabil
Old 30-03-07, 18:14   #8
RA_2fast4u
Ford Driver
RA_2fast4u's Avatar
[FOTO]
Astia sunt oamenii la care ar trebui sa le fim toti recunoscatori.. nu la politicieni si afaceristi de nimic... e clar ca motorul e mult inaintea timpului lui si mi s-ar parea chiar periculos sa il pui acum pe masina.. ori cum ce vremuri ar fi... dacia logan stock are cel mai slab motor din gama. doar 850 hp =)) ori cum prea tare sa te chinuiesti sa scazi puterea unui motor ca sa fie ceva mai rezonabil...
RA_2fast4u is offline   Reply With Quote
Old 30-03-07, 20:39   #9
AK-ZER
AK-ZER's Avatar
848 cui din asha mici dimensiuni.. 850+ hp.. that's crazy
are dyno sheet?
AK-ZER is offline   Reply With Quote
Old 02-04-07, 16:51   #10
Treshure
Treshure's Avatar
are dyno sheet?
pai nu prea.. ca nu a fost montat pe nici o masina sa vezi ce putere da la roata.. motorul este un concept in plina dezvoltare.. si legat de ce a scris colegul mai sus.. prea tare.. sa te chinui sa scazi puterea motorului ca e prea mare )
Old 02-04-07, 16:52   #11
Treshure
Treshure's Avatar
are dyno sheet?
pai nu prea.. ca nu a fost montat pe nici o masina sa vezi ce putere da la roata una la mina si doi.. 850 cai pe puterea minima.. de fapt el dezvolta 3000 de cai.. motorul este un concept in plina dezvoltare.. si legat de ce a scris colegul mai sus.. prea tare.. sa te chinui sa scazi puterea motorului ca e prea mare )
Old 02-04-07, 16:59   #12
Nautilus
Transmisia se va face electric, ca la o locomotiva Diesel-electrica - un generator cuplat la motor si cate un motor de tractiune pe fiecare axa sau in fiecare roata
~Nautilus
Nautilus is offline   Reply With Quote
Old 04-04-07, 13:37   #13
Treshure
Treshure's Avatar
[QUOTE=Nautilus;829565]Transmisia se va face electric, ca la o locomotiva Diesel-electrica - un generator cuplat la motor si cate un motor de tractiune pe fiecare axa sau in fiecare roata
~Nautilus[/QUOTE
Nici vorba de asa ceva.. nu are rost sa transmita 3000 de cai catre un generator ce va dezvolta mult mai putin datorita dimensiunilor reduse pe care e obligatoriu sa le aiba dat fiind faptul ca vorbim de un autoturism.. transmisia va trebui facuta printr-o cutie de viteze klar pentru a putea exploata puterea acestui motor precum si pentru a mentine greutatea masinii cat mai redusa.. Practic generatorul nu ar face nimic altceva decat rau.. putere mai scazuta + multa greutate in plus.. Nici nu mai pun la socoteala motoarele pentru tractiune ca ajung la 4 - 5 tone usor cu totul (greutatea totala a auto) Alta idee
Old 04-04-07, 15:02   #14
beck
beck's Avatar
este doar un wankel modificat.....
chestia tare ar fi sa mearga pe diesel, oricum cuplul este mult mai important decat puterea maxima si probabil ca nu are cine stie ce cuplu pt ca ar fi spus macar o cifra.
INOXWORKS
480 hp/t
beck is offline   Reply With Quote
Old 04-04-07, 16:21   #15
BASU
BASU's Avatar
pai chiar pe asta merge :P misto raport de compresie
