Old 02-07-10, 11:37   #1
elspa
elspa's Avatar
Default Ford Mustang 5.4l Turbo - powered by SRZ
Inca o bucata american muscle:
Short block SC Aluminator 5.4l Ford Racing 8.5:1 CR - complet forjat
Chiulase Edellbrock CNC ported
Garnituri chiulasa Cometic MLS
Prezone chiulasa ARP
Axe turbo + arcuri + limitatori COMP CAMS
Kit relocare filtru ulei Moroso
Kit oil feed + oil return Moroso
Turbo Precision Billet 6768 ( GT4288 )
Husa Turbina Tial
WG Tial 38mm
BOV Tial 50mm
Intercooler Moroso
Injectie cu metanol SNOW
Injectoare Ford Racing 800cc
3 Pompe de benzina Lethal Performance
Debitmetru PMAS HPX
Sensor temperatura relocat FORD RACING
Boost controller Turbosmart Street 2
Traseu evacuare 80mm + traseu intercooler + concept - made by SRZ
Galerii + tevile evacuare + turbina acoperite ceramic - made by SRZ
2 harti de putere la 1 si 1.4 bari.
Saptamana viitoare dyno.
ID:	1548072   Click image for larger version
ID:	1548073   Click image for larger version
ID:	1548075   Click image for larger version
ID:	1548076   Click image for larger version
ID:	1548078   Click image for larger version
ID:	1548079   Click image for larger version
ID:	1548081   Click image for larger version
ID:	1548083   Click image for larger version
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 04-07-10, 11:26   #2
Nautilus
Default Re: Ford Mustang 5.4l Turbo - powered by SRZ
Felicitări pentru rezultate, dar...
Ce model era? A fost un Mustang modern (generaţia V, 5.4 litri + compresor) la care aţi eliminat compresorul? A fost un model mai puţin pretenţios, tot din generaţia V, la care aţi īnlocuit motorul cu totul?...
La sistemul de frānare aţi făcut ceva?
~Nautilus
Nautilus is offline   Reply With Quote
Old 04-07-10, 16:15   #3
elspa
elspa's Avatar
e model 2008 Mustang GT V8 4.6l.
Blocul a fos inlocuit cu unul complet forjat stroker 5.4l de la Ford Racing.
la frane nu ceva senzational (discuri + placute ceramice+furtune), dar pentru ca e o masina de accelratie in linie dreapta, nicidecum pe curbe, e de ajuns.
Old 04-07-10, 21:53   #4
Nautilus
Şi are undeva la 500-600 CP. Greşesc?...
~Nautilus
Old 04-07-10, 21:59   #5
elspa
elspa's Avatar
vom vedea....sincer speram la ceva mai mult pe 1.4 bari presiune.
Old 03-11-10, 20:09   #6
elspa
elspa's Avatar
655cp 910nm cu corectie la motor la 1 bar presiune, afr 11:1, 14 grade avans.
a mai fost o tragere si cu methanol + 33 cp fata de graficul de mai jos.
cifrele din grafic sunt la roata, piederi pe transmisie 28%.
asteptam chiulasele Livernois si ajungem la targetul nostru de 1.5 bari presiune si 19 grade avans.
Name:	tr4 1.2 360kw.jpg
Old 04-11-10, 08:28   #7
bikks
bikks's Avatar
[Mitsubishi]
[Pole Position Racers]
655cp 910nm ----- Bravo!!!!! Cuplul cel putin e fenomenal, nici calutii nu sunt departe deloc.
bikks is offline   Reply With Quote
Old 04-11-10, 13:32   #8
Hexer
Hexer's Avatar
Un lucru nu inteleg...cum e ca la 1 bari merge cu 14 grade avans si la 1,5 o sa mearga la 19...
Ori acum nu e setat cum trebue ori atunci o sa fie mult pese ce ii trebue.
Si inca ceva...cum sti inainte de instalare ce avans o sa aiba ... nu e soft custom? Sau e facut dupa simti...
Hexer is offline   Reply With Quote
Old 04-11-10, 17:02   #9
daniwmk
daniwmk's Avatar
28% pierderi transmisie mi se pare foarte mult
e o valoare pentru 4x4 ca pierdere
daniwmk is offline   Reply With Quote
Old 04-11-10, 18:26   #10
elspa
elspa's Avatar
e masina americana plus punte de drag de 10", cardan de 11", cutie Tremec, roti de 11j cu gume 325, etc....totul e cam dublu cat un bmw m3 de exemplu.
oricum nu eu am calculat coeficientul.
Old 04-11-10, 18:30   #11
elspa
elspa's Avatar
e reteta pe ce s-a mai facut in configuratia respectiva, acolo ar trebui sa ajungem, sa zicem ca e un target.
acum merge foarte safe cu avansul respectiv si nu am bagat metanolul in ecuatie inca sa putem sa tragem serios de avans.
softul e custom facut de Eric Brooks.
Old 04-11-10, 22:47   #12
Hexer
Hexer's Avatar
Interesant cu softurile primite...cei drept metanolul da o marja mare de eroare dar e greu sa auzi daca face detonatii ca nui ca la benzina.
Old 05-11-10, 00:51   #13
elspa
elspa's Avatar
il ascultam cu senzorul de detonatii pe casti
Old 05-11-10, 00:57   #14
Hexer
Hexer's Avatar
Degeaba, nu face knock, are total alt sunet...cu EGT sanse mai mari..dar trebue 8 sa vezi daca una incepe sa detoneze...de asta se reglaza cu egt-uri motoarele cu metanol, sa nu zicem de parte ca WBO2 nu paote sa masoare lambda la metanol...adica poate dar max lambda 1 si mai bogat nu.
Dar daca nu e secret de unde faceti rost de metanol...ma itereseaza si pe mine un bidon mai mare...
A, si usor cu ocnductele...caucicul nui place metanolul...
Old 05-11-10, 07:49   #15
elspa
elspa's Avatar
nu mergem 100% meth, e destul de riscant.
kitul de injectie vine cu conducte speciale, nicidecum cauciuc.
cat despre sursa, srry, si mie imi e greu sa procur....
