Old 16-09-07, 12:38   #1
Detman
Fiat Driver
Detman's Avatar
Default amplificatoare : 2 magnaturi vs 2 mac audio
magnat rx mono
amplificator auto mono
putere
4 ohmi: 1 x 500W RMS (1 x 1000W max)
2 ohmi: 1 x 700W RMS (1 x 1400W max)
1 ohm: 1 x 1000W RMS (1 x 2000W max)
Raspuns in frecventa 5 - 250 Hz
THD < 0,05 % (1 kHz)
filtru LPF variabil 40-250 Hz, 12 dB
filtru subsonic variabil 10-40 Hz, 12 dB
Bass boost variabil 0-15 dB la 45 Hz
dimensiuni: 450 x 50 x 261 mm
intrari / iesiri RCA aurite
control volum remote (telecomanda pe fir)
vs
magnat Rock Mono 1000
amplificator monobloc pentru subwoofer
putere:
4 ohmi: 350W RMS (750W max)
2 ohmi: 500W RMS (1250W max)
1 ohm: 700W RMS (1800W max)
impedanta suportata: 1-8 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
THD < 0,05% (1kHz)
intrare de linie 0,25V - 4V
filtru low pass variabil 40-300 Hz (12 dB)
filtru subsonic (high pass) 10-40 Hz (12 dB)
bass boost variabil 12dB la 45 Hz
circuit de protectie la supraincalzire si scurtcircuit
mac audio fearless 1000
amplificator 1 canal
putere RMS:
1 x 600W (4 ohmi)
1 x 900W (2 ohmi)
raspuns in frecventa: 5Hz - 75KHz (-3dB)
distorsiuni: 0.03% (1KHz)
raport semnal/zgomot: 100dB
filtru LPF variabil: 40 - 300Hz (12dB/oct)
filtru subsonic variabil: 10 - 80Hz (12dB/oct)
Bass Boost: 0 - 12dB (45Hz)
reglaj faza: 0 - 180º
nivel semnal intrare: 400mV - 4V
tensiune alimentare: 12V (9 - 15V)
dimensiuni: 46 x 6 x 29cm
greutate: 6 Kg
Mac Audio MAXIMUS 1.750
Caracteristici
Amplificator auto monobloc
Putere maxima mono la 4 ohmi: 900w
Putere RMS mono la 4 ohmi: 450w
Putere maxima mono la 2 ohmi: 1500w
Putere RMS mono la 2 ohmi: 725w
Frecventa de raspuns: 5 Hz - 400 Hz (-3dB)
SPL: 105 dB
Bass Boost variabil : 0 dB - 12 dB
Dimensiuni: 420 x 59 x 232 mm
vreau sa il folosesc pe
Mac Audio Maximus 3000
Putere maxima 1000W
Putere reala RMS 500W
Impedanta 2x4 ohm
Raspuns in frecventa 21-500 HzSPL 87 dBCon din AluminiuDubla bobina
http://www.mac-audio.de/recopdf/1327033_EN_PDF2.pdf
Detman is offline   Reply With Quote
Old 04-01-08, 20:58   #2
saxo
saxo's Avatar
Default Re: amplificatoare : 2 magnaturi vs 2 mac audio
Puteti spune ca va place sau nu. Nu aveti dreptul sa aruncati cu noroi in niciun brand !
@Madu
Considera un avertisment postul meu.
Old 05-01-08, 08:23   #3
Rafaila
Rafaila's Avatar
Scuze de of topic dar nu ma pot abtine
Sustin parerea lui SAXO an privinta comentarilor lu MADU
Din posturile dansului rezulta CA A VAZUT SI ASCULTAT TOATE SCULELE DE LA TOATE BRANDURILE SI A DEVENIT PROFESOR........ASA CA,,,LA MAI MARE DOMNU....
Rafaila is offline   Reply With Quote
Old 05-01-08, 12:02   #4
basic
Competitor CNCA
basic's Avatar
Ca o parere ,asa de moment, as alege MAC AUDIO fearless one(pare un amplif solid,clasa D,stabil 1 ohm fata de mac audio 1.750 care e stabil doar 2 ohm si nu cred ca e clasa D si nu cred ca il mai gasesti).
Daca e sa consideri si raportul putere/pret in calcul as alege RX MONO dar puterea la magnat este mai mica.
Ideal ar fi sa poti proba ambele configuratii.
Sper sa te fi ajutat mai mult decat dl MADU.
157.7DB...CAN'T STOP THE ROCKs.....
2013=> 158.7DB
basic is offline   Reply With Quote
Old 05-01-08, 12:08   #5
basic
Competitor CNCA
basic's Avatar
Poate ne spui si ce ai ales, avand in vedere ca iti puneai intrebarea in septembrie,eventual o pareree despre alegere.
