amplificatoare : 2 magnaturi vs 2 mac audio
magnat rx mono
amplificator auto mono putere 4 ohmi: 1 x 500W RMS (1 x 1000W max) 2 ohmi: 1 x 700W RMS (1 x 1400W max) 1 ohm: 1 x 1000W RMS (1 x 2000W max) Raspuns in frecventa 5 - 250 Hz THD < 0,05 % (1 kHz) filtru LPF variabil 40-250 Hz, 12 dB filtru subsonic variabil 10-40 Hz, 12 dB Bass boost variabil 0-15 dB la 45 Hz dimensiuni: 450 x 50 x 261 mm intrari / iesiri RCA aurite control volum remote (telecomanda pe fir) vs magnat Rock Mono 1000 amplificator monobloc pentru subwoofer putere: 4 ohmi: 350W RMS (750W max) 2 ohmi: 500W RMS (1250W max) 1 ohm: 700W RMS (1800W max) impedanta suportata: 1-8 ohmi raspuns in frecventa: 5 Hz - 50 kHz (-3dB) THD < 0,05% (1kHz) intrare de linie 0,25V - 4V filtru low pass variabil 40-300 Hz (12 dB) filtru subsonic (high pass) 10-40 Hz (12 dB) bass boost variabil 12dB la 45 Hz circuit de protectie la supraincalzire si scurtcircuit mac audio fearless 1000 amplificator 1 canal putere RMS: 1 x 600W (4 ohmi) 1 x 900W (2 ohmi) raspuns in frecventa: 5Hz - 75KHz (-3dB) distorsiuni: 0.03% (1KHz) raport semnal/zgomot: 100dB filtru LPF variabil: 40 - 300Hz (12dB/oct) filtru subsonic variabil: 10 - 80Hz (12dB/oct) Bass Boost: 0 - 12dB (45Hz) reglaj faza: 0 - 180º nivel semnal intrare: 400mV - 4V tensiune alimentare: 12V (9 - 15V) dimensiuni: 46 x 6 x 29cm greutate: 6 Kg Mac Audio MAXIMUS 1.750 Caracteristici Amplificator auto monobloc Putere maxima mono la 4 ohmi: 900w Putere RMS mono la 4 ohmi: 450w Putere maxima mono la 2 ohmi: 1500w Putere RMS mono la 2 ohmi: 725w Frecventa de raspuns: 5 Hz - 400 Hz (-3dB) SPL: 105 dB Bass Boost variabil : 0 dB - 12 dB Dimensiuni: 420 x 59 x 232 mm vreau sa il folosesc pe Mac Audio Maximus 3000 Putere maxima 1000W Putere reala RMS 500W Impedanta 2x4 ohm Raspuns in frecventa 21-500 HzSPL 87 dBCon din AluminiuDubla bobina http://www.mac-audio.de/recopdf/1327033_EN_PDF2.pdf |
Re: amplificatoare : 2 magnaturi vs 2 mac audio
Puteti spune ca va place sau nu. Nu aveti dreptul sa aruncati cu noroi in niciun brand !
@Madu Considera un avertisment postul meu. |
Scuze de of topic dar nu ma pot abtine
Sustin parerea lui SAXO an privinta comentarilor lu MADU Din posturile dansului rezulta CA A VAZUT SI ASCULTAT TOATE SCULELE DE LA TOATE BRANDURILE SI A DEVENIT PROFESOR........ASA CA,,,LA MAI MARE DOMNU.... |
Ca o parere ,asa de moment, as alege MAC AUDIO fearless one(pare un amplif solid,clasa D,stabil 1 ohm fata de mac audio 1.750 care e stabil doar 2 ohm si nu cred ca e clasa D si nu cred ca il mai gasesti).
Daca e sa consideri si raportul putere/pret in calcul as alege RX MONO dar puterea la magnat este mai mica. Ideal ar fi sa poti proba ambele configuratii. Sper sa te fi ajutat mai mult decat dl MADU. |
Poate ne spui si ce ai ales, avand in vedere ca iti puneai intrebarea in septembrie,eventual o pareree despre alegere.
| All times are GMT +2. The time now is 07:29. |
