Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > HONDA - ACURA > Honda - Acura tuning
Old 05-04-09, 14:59   #1
Achim
Dream Squad Member
Achim's Avatar
[Dream Squad]
[Honda]
Cool EP3 TypeR - 255 hp in RO
O sa aduc mai multe detalii despre masina, cert e ca a ajuns inapoi in curtea SKN si merge senzational de bine.
Dyno sheet'ul indica 257 hp la roti si undeva la 298 la motor. De retinut ca masina este in continuare 2.0 (nefolosindu-se un stroker kit) si electronica si ultimele reglaje au fost facute in Grecia.
Cateva "secrete":
  • axe cu came stage 4
  • Toda goodies
  • Hondata K-Pro
  • compresie 13.5:1
  • redline 9700 rpm (for daily use 9250 rpm)
  • Toyo R888 + OZ Ultrallegera
Achim is offline   Reply With Quote
Old 05-04-09, 15:00   #2
alexcump
alexcump's Avatar
[Hyundai]
Default Re: EP3 TypeR - 255 hp in RO
Interesant !
Ceva poze?
alexcump is offline   Reply With Quote
Old 05-04-09, 15:02   #3
Achim
Dream Squad Member
Achim's Avatar
[Dream Squad]
[Honda]
Dap, am atat poze cat si filmulete dar trebuie sa le descarc ... later on
Old 05-04-09, 15:03   #4
alexcump
alexcump's Avatar
[Hyundai]
Le asteptam cu mare drag. Cat mai repede cu putinta.
Old 06-04-09, 00:07   #5
hmi10494
Honda Driver
hmi10494's Avatar
[Honda]
am si eu o intrebare referitor la compresie. ai folosit pistoane cu dom + valve high comp, sau doar pistoane. bielele sunt stock ? cu cat ai retrogradat aprinderea ?
merci.
hmi10494 is offline   Reply With Quote
Old 06-04-09, 02:11   #6
Achim
Dream Squad Member
Achim's Avatar
[Dream Squad]
[Honda]
nu e vba de masina mea personala si desi stiu raspunsul intrebarilor mai intai va trebui sa double-check pentru a nu enunta ceva aiurea
Old 06-04-09, 11:06   #7
yulasinio
Honda Driver
yulasinio's Avatar
[Honda]
Cred ca a schimbat complet toate internele K20-ul asta raspunde bine la orice modificare (daca e facuta cu cap) asa ca nu ma surprinde puterea iar 13.5:1 compresie e ceva
P.S Altii se chinuie sa scoata cu turbo atata
yulasinio is offline   Reply With Quote
Old 06-04-09, 11:40   #8
Achim
Dream Squad Member
Achim's Avatar
[Dream Squad]
[Honda]
merci.
asa cum a zis si Yula internele sunt complet schimbate, folosindu-se pistoane de compresie marita, alte arcuri de supape si garnitura de chiuloasa tot cu compresie marita
cat despre aprindere, asta e "secretul" celui care a facut softul ...
Old 08-04-09, 21:18   #9
fanete
fanete's Avatar
[Honda]
si poze.....
fanete is offline   Reply With Quote
Old 11-04-09, 20:53   #10
r4mp
r4mp's Avatar
[Street Gambler]
Pozele ca pozele.. dar cifrele sunt intradevar impresionante!
9700rpm
r4mp is offline   Reply With Quote
Old 13-04-09, 12:07   #11
civic_ex
civic_ex's Avatar
[Honda]
Il asteptam cu drag la prima etapa de drag...
banuiesc ca pt asta a fost facuta masina, nu?
civic_ex is offline   Reply With Quote
Old 14-04-09, 12:42   #12
ZooM-ZooM
Honda Driver
ZooM-ZooM's Avatar
[4 Speed Squad]
[Honda]
am avut si eu onoarea sa o vad si sa o aud... pot sa zic decat ca pentru aspirat sunt ceva performante obtinute,dar se poate mai mult !
ZooM-ZooM is offline   Reply With Quote
Old 15-04-09, 12:50   #13
Achim
Dream Squad Member
Achim's Avatar
[Dream Squad]
[Honda]
Din pacate nu gasesc cablul de date al telefonului ca sa pot sa scot pozele si filmele din el.
Nu va impresiona pentru ca totusi ramane un aspirat de 2.0 fara cuplu monumental. A nu se intelege ca va fi lenta...
Scopul ei a fost stoarcerea la maxim a unui K20 fara stroker si cu VTEC.
Andrei (ownerul) a zis ca daca masina nu s-ar fi miscat asa cum trebuie, instant ar fi primit un kit turbo care sa dezvolte o putere impresionanta, fara sa conteze ca pui sau nu puterea jos... ar fi fost doar o goana dupa cp.
In schimb, pe un circuit virajat (fiind si usurata) masina ar face deranj mare de tot.
Se poate mult mai mult cu turbo sau compresor. De asemenea si in varianta aspirat s-ar putea mai mult daca s-ar folosi un stroker dar asta ar reduce turatia maxima si / sau VTEC killer cams dar omori ceva ce nu merita distrus
Inca o varianta este K24 cu stroker si pe acela il poti ridica la ~ 350 cp N/A dar iar, ai rev limiter sub 8000 rpm.
Ah, si tineti minte, acei 255 hp sunt la roata ... putere la motor este de ~ 300 cp N/A
Old 16-04-09, 12:03   #14
cioli17
cioli17's Avatar
[RR]
Daca puterea aia e reala,masinii ii trebuie un sofer bun si gume incalzite si sunt sigur ca va face o treaba foarte buna!Sambata seara nu am vazut nimic relevant,sunt curios de performantele ei intr-o pasa buna,sa spunem asa.
cioli17 is offline   Reply With Quote
Old 17-04-09, 12:19   #15
fanete
fanete's Avatar
[Honda]
ma da toata lumea a vazut masina asta...
