Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > MITSUBISHI > Masina mea Mitsubishi
Old 11-12-08, 21:05   #31
bikks
bikks's Avatar
[Mitsubishi]
[Pole Position Racers]
Default Re: Mitsubishi EVO IX
Masina a mai primit cateva modificari.
ID:	724791   Click image for larger version
ID:	724792   Click image for larger version
ID:	724794   Click image for larger version
bikks is offline   Reply With Quote
Old 11-12-08, 21:21   #32
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
bov ?
Old 11-12-08, 21:23   #33
bikks
bikks's Avatar
[Mitsubishi]
Miercuri sau joi imi ajunge . hks ssq2
Old 11-12-08, 21:25   #34
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
excelent
Old 11-12-08, 22:35   #35
cosminCOX
Originally Posted by Jeff View Post
Eu fac 0-100 in sub 4 secunde, sfertul de mila in 12.01 si multi meseriasi din multe tari zic ca as avea cca. 380CP la motor. Am multe modificari, doar turbina si internele sunt stock. Fiecare cu calculele lui.
JEFF DRAGA OMU ESTE PASIONAT SI ENTUZIAST FATA DE "FIERU" LUI DA DE LA FIER SI DORINTA DE A ABERA[CEL PUTIN CU CAII TAI SAU CU PERFORMANTELE.POATE AI VREO CUTIE SECVENTIALA SAU CEVA DEZVOLTAT PRIN WRC DESII NU CRED]SIMT NEVOIA SA TI SPUN:1.DACA MAI SCADEAI DIN "SUB 4" AL TAU O SEC O DADEAI IN BUGATTI VEYRON SI ALTII MONSTRII CU TRIPLU DE PUTERE PE CARE FENOMENAL TU I OBTII CU 380 SI MAI VB DE MESERIASI DIN ALTE TARI DA ZICI BINE MESERIASI NU PROFESIONISTI CARE CE CUM AU DETERMINAT EI ASTA ASA SA FIU IN TON CU LUMEA DE ACI CA VAD CA ASA SE VB INLOC SA O PUI SUB FORMA DE CONVERSATIE. 2.DACA TU FACI SI NU ZIC CA NU CA NU AM DE UNDE SA STIU SFERTU DE MILA IN [IAR DUBIOS ORI CATERINCA IN FINE]12.01 BINE CA NU E 12.01.234CENTIMIMI DIN MIMILE LU..... ASA EU ITI POSTEZ NISTE FILMULETE DIN SUEDIA DE PE O PISTA DE DRAG SI ITI ARAT ACOLO MASINI CARE SCOT TREABA ASTA SI DUPA MAI DISCUTAM INCA O DATA E POSIBIL NU ZIC CA NU SA SCOTI ASA CEVA DA NU DIN CALUTII CARE I AI TU.[ASTA ASA PE LANGA CUM PUTETI MA BAIETI SA VB SI TOCMAI PE NET UNDE DAI SI DE DRACU DE CHESTII CARE SE VERIFICA ASA CAT DE CAT USOR CREDETI CA HALESTE CINEVA ABERATIILE CARE LE DATI CAND LE DATI VA TI INVATAT DE LA "PRIETENII"VOSTRII CARE DACA I MAI DATI O DATA CU MASINA PE LA 200 E PRIMA DATA IN VIATA LOR CAND VAD VITEZA ASTA SI DUPA CE OPRITI LA VB LE INDRUGI CE VREI SI EI HALESC OK MERGE DA NU SI PE NET CA AICI NU PREA MERGE NU NUMAI CU MINE CA NUS VREUN DESTEPT DA.......CINE SE UITA PE ACI NEA GHEORGHE?IN FINE]SI 3.ACU PE BUNE ZIMI CUM AI CRONOMETRATO SI DACA AI FOST PE AFARA SPUNE UNDE POATE GASIM CEVA PE NET [AM FACUT COMENTU ASTA DUPA CE AM CITIT F MULTE ABERATII SI LA JEFF AM CEDAT NU AM NIMIC CU TINE NICI NU STIU CINE ESTI DA MI AM SPUS PUNCTU MEU CUM FACETI SI VOI DE MULTE ORI DAR FARA SA GANDITI]SI JEFF ZICI CA AI TOT SCHIMBAT INAFARA DE INTERNE OK STAI SA TERMINE OMU MASINA SI ITI PROMIT CA NE INTALNIM SI O DAM SI FACEM FAPTE ASA NU VB CE ZICI? NU E MAI BINE ASA.SI ATUNCI MAI VEDEM CATI CUM CE.SI BINE A ZIS OMU CU 911 TURBO GASIM SI ASA CEVA ASTA ASA LA DISCUTIA CU CAII.UITATE SI TU TE ROG FRUMOS LA {RUF PORSCHE 911 TURBO Rt 600}ASTIA I ARE LA ROATA 0-100 3.5 0-200 10.5 SI ACU TE MAI INTREB NU ZIC CA NU AR FII ADEVARATA UNA DIN ELE.CATI CAI AI?
SAU CE PERFORMANTE AI SI LA CE PUTERE?
cosminCOX is offline   Reply With Quote
Old 12-12-08, 07:47   #36
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Meseriasi din multe tari pot sa spuna ce vor ei.
Pentru a obtine cu greutatea de serie si puterea de serie 12s pe 400m nu iti ajung 400cp.
In curand noi vom importa cel mai bun stand 4x4 care exista in Europa, peste ce au unele fabrici europene. Intradevar e maibun pe unele chestiuni si mai slab pe altele insa este in carcti cu se spune.
Atunci o sa puteti sa va verificati puterea fara probleme.
Pentru Subaru amcateva date interpretate de uni care manaca mult din acest fel:
The following times for 0-60mph and 1/4 mile are only approximations of capability and are provided as an example of what differences in cars, modifications, track conditions and driver ability might produce.
227 hp
319 hp.....
340 hp...
395 hp...
430hp...
5.2-5.6s...
4.5-5.1s...
4.3-4.6s...
4.0-4.4s...
3.8-4.2s...
14.6-14.9 @... 91-95 MPH
13.2-13.6 @ 97-100 MPH
12.9-13.3 @ 99-102 MPH
11.2-12.6 @ 108-110 MPH
11.0-12.5 @ 110-115 MPH
Si la evo trebuie sa tie ceva apropiat.
Professional DynoTuning
sebastian@racingcode.ro
0723691731
Old 12-12-08, 08:37   #37
baubau racing
Parerea mea inainte sa va (iti) dati cu parerea la anumite cifre ar fi mai bine sa verificati nu cred ca este f. greu nu va fi cu exactitate dar va fi pe aproape macar , de asta ma spus sa incerce sa se dea cu un 911 turbo masinile fiind aproximativ la fel din punct de vedere al transmisiei si puterii. Nu va fi exact dar se poate incerca mai usor decit gasi un stand dyno valabil. Sau verificati cu cronometrul dupa tmpii dati de Sebi.
Ai facut modificari dar in ceea ce ma priveste pt a cistiga ceva cai ai uitat de cele mai importante : pompa benzina,axe,aprindere.Cum spuneam din cooler si frime nu cistigi, sint bune pe viitor dar pt moment.....
Mult succes in continuare.
baubau racing is offline   Reply With Quote
Old 12-12-08, 08:43   #38
M I V E C
M I V E C's Avatar
[Mitsubishi]
Originally Posted by baubau racing View Post
Si unde faci un dyno in Rominia care sa fie cit de cit ok? Vitan? Da-te cu un carrera 911 996 turbo cel de 420 cp si vei stii unde stai .
poi saptamana acesta s-a montat la Cluj un DYNO 4x4 si toata saptamana este gratis testarea iar dupa asta va fii undeva la 300 RON testarea,
M I V E C is offline   Reply With Quote
Old 12-12-08, 08:52   #39
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Probabil din cel care e pt testarea franelor si are si functie pt masurare de putere ca si cel din AUTOVIT.
Old 12-12-08, 10:58   #40
Jeff
Jeff's Avatar
Legat de carcoteli, va invit sa dati click pe linkul din semnatura mea.
La mine 0-100 se intampla in cca. 3.8-3.9 secunde - asta am vrut sa zic prin "sub 4".
Bafta la modificari.
Romanian Dragracing Site
Jeff is offline   Reply With Quote
Old 12-12-08, 14:13   #41
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
eu cred sub 4, pentru ca 80% din masinile modificate de RacingCode din gama evo9 scot timpi asemnatori.Atat spun ca pentru 12s e nevoie de mai mult decat 380cp pe cutie de serie si greutate de serie la evo9.
Old 12-01-09, 07:45   #42
wolverine
wolverine's Avatar
masina inca mai e la "renovari"? ca nu am mai vazut`o prin oras....sau n`am avut eu ochi pt ea?)
wolverine is offline   Reply With Quote
Old 12-01-09, 08:52   #43
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Standul de le Cluj cred ca este similar cu cel din Autovit asa ca masurarea pe el trebuie facut intr-o procedura speciala ca sa fie aproape de reaitate.
Oricum in scurt timp o sa va ofer posibilitatea de a masura toate modelelcu orice tip de tractiune pe un stand profi la Bucuresti.
Old 21-01-09, 21:18   #44
andrew 46
andrew 46's Avatar
[Colectionar Machete]
[Toyota]
ce frumos e lancerul
imi plac foarte mult jantele
andrew 46 is offline   Reply With Quote
Old 22-01-09, 10:06   #45
bbm
ce marca sint discurile de frina? etrierii ramin brembo de fabrica sau se schimba?
bbm is offline   Reply With Quote
- Copyright 2025 4Tuning -
