Originally Posted by Nemilosu
am spus de ascuns deoarece la noi se vine usor la treaba ca sa nu se auda blow-off-ul cqa sa nu stie lumea ca e turbo, mai ales sa spuna ce are pe masina. asta e romania.
nu stiu cati cp am deoarece nu am masurt niciodata, si nu cred sa am ceva in plus sau f multi deoarece nu am soft.
galeria de evacuare este originala, urmeaza sa o fac tot eu din inox rs2 style.
In cazul in care ai nevoie de soft iti dau o adresa de mail
kaido.tq@gmail.com eu am comandat si azi am primit calc MAC 14 pt Audi 100 MC 2 cod motor Am ales sa imi trimita calc gata chipat ca sa il am originalul de rezerva. Mi-a trimis calc + arcu de la waste gate pt 2.2 BAR. Omul zice ca ar produce 250 HP acum nu stiu ca numai in martie pot proba, el asa se lauda....
MAC-14 – GTQ "Super" Chip – supports boost levels over 2 bar and timing mapped for higher octane fuel – 89 octane or higher recommended. This chip is good for boost pressure adders/regulators to around 2.2 bar. Kit price $185 includes chip, PROM Socket, spring & instructions. Chip & socket $160. Upgrade available to prior GTQ chip customers for $40. Estimated HP is around 250 at 17 PSI of boost.
Prices include shipping in Continental USA. Shipping to Europe or Canada is usually higher.
Pt motorul tau zice cam asa:
For the '91 200 20V turbo quattro:
2.5 Bar chipset and pressure transducer kit for 3B engine and Motronic DME which facilitates 280 HP(208 KW). Chip mapping is comparable to higher priced chipsets and dyno tested at 280 HP without the wastegate spring. Although upgraded wastegate spring is not required, I now include the spring after testing revealed a significant peak and hold gain. Kit now includes Fuel Chip, Boost/Ignition chip, 2.5 Bar Pressure Transducer and wastegate spring at $280 or $235 without the pressure transducer (Use VMAP, Bosch or other suitable 2.5 Bar P.T). Installation $120.
3 Bar kit is now available. Kit includes Fuel Chip, Boost Chip, Wastegate spring, VMAP 40421 switchable pressure transducer (2.5-4 Bar) and instructions. Performance varies with setup, but in the 350+ range. Requires uprated injectors (38-45 lb. recommended) and RS2 equivalent turbo or higher. $465 - installation service $130.
’92-95 S4/S6/100 5 Cyl. AAN – DIY 2.5 Bar (stage 2 for 280 HP) Kit includes Fuel Chip, Boost Chip, PROM Sockets, Wastegate spring $270.
DIY 3 Bar (Stage 3 for 325+ HP) Kit includes Fuel Chip, Boost Chip, PROM Sockets, Wastegate spring, VMAP 40421 switchable pressure transducer (2.5-4 Bar) and instructions. Performance varies with setup, but in the 340+ range. Requires uprated injectors (38-45 lb. recommended) and RS2 equivalent turbo or higher. $475 - installation service $180 and requires installation of PROM Sockets.
SUCCESE !
